HP LA1905WG lcd monitor no backlight
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    #41
    Re: HP LA1905WG lcd monitor no backlight
    just took one apart down to backlight...it appears top left corner of plastic frame around backlight is melted/burned
    • shelby5041
      • Feb 2009
      • 1505
      #42
      will post a pic later...left corner of glass backlight metal frame burnt bad...actually its an end of a ccfl tube....fried........i just peeled it apart and its a tube thats on the uppermost part of frame.....
      • shelby5041
        • Feb 2009
        • 1505
        #43
        yep...just took another one apart.....left corner fried where ccfl wire around metal frame.....ccfl fried
        • shelby5041
          • Feb 2009
          • 1505
          #44
          ok this thread is done
          here are pics of backlight assemblies for the 3 monitors that backight would power on for 2 seconds and then off
          all 3 had electrical failures within the backlight circuit
          seems to have to do with metal frame shorting out on power cable to ccfl
          • shelby5041
            • Feb 2009
            • 1505
            #45
            thanks to all that helped....i spent over 6 months on and off troubleshooting this issue....hundreds of hours..tearing apart power supplies...testing..desoldering...soldering......and was steered in the wrong directions due to my own mistakes.......but im glad to finally find the problem
              • 30979
              if you remove the melted tape & clean it up, you may just need to replace the wire section.
              btw, this is not a surprise, the one i had (17 version) had a cracked tube!
              HP overdrives the tubes in these monitors to get the brightness.
              • shelby5041
                • Feb 2009
                • 1505
                #47
                no.....the end of tube fried....broken./cracked..the reason its like this is these monitors are used in a manufacturing environment....lot of vibration and they are mounted on a fixture that moves back and forth 1200 times a day......thats what csused the problem.....broken monitors are ever day here.....we have about 500 in circulation.....and broken ones are a daily thing.....they throw them away and i sometimes take them....we now have all led style lcd monitors....they work great as lights when screens cracked
                  That is why it is very important to have at least two good known test lamps to test the boards so you will save lots of troubleshooting times.
                  • shelby5041
                    • Feb 2009
                    • 1505
                    #49
                    it was a good learning experience....
                      • 30979
                      you can still take the good tubes from one to fix another
                      • shelby5041
                        • Feb 2009
                        • 1505
                        #51
                        not worth it.........
                        • shelby5041
                          • Feb 2009
                          • 1505
                          #52
                          ill make more selling the boards....the monitors sell for only 20.00 used
                          • Zilicon
                            NEWSYNC B27F165 MONITOR HAS NO BACKLIGHT. board no: JY85QS_UPH_LS_R10.3
                            by Zilicon
                            Greetings everyone.
                            Please I need help with the above monitor.
                            Below is the summary of what happened and what I have done:
                            The monitor started by turning off 2 seconds after it was turned on. It displayed with a backlight when it turned on. However, the standby light remains on after it is turned off on its own, I have to press the power button again to turn it on, but it will go back to standby after 2 seconds.
                            The backlight driver IC is 0b3350cp.
                            I applied a 370k SMD resistor on the CMP pin which is pin 6, while the other...
                            11-07-2023, 09:12 AM
                            by momaka
                            03-15-2023, 10:17 PM
                          • turmix
                            AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                            by turmix
                            Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                            The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                            At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                            During another reassembly, I made a mistake, and...
                            01-29-2024, 03:48 AM
                          • Chiro
                            DIGMA PRO Art M Monitor 5K IPS 60hz only backlight
                            by Chiro
                            The monitor has no visible external damage and has not been dropped. Currently, the backlight is on, but no image is displayed. I have replaced the power and HDMI cables, and connected it to my laptop (the graphics card detects the monitor, but no image appears). The service menu is also unresponsive. Could anyone share insights on troubleshooting or repair options for this issue?
                            07-06-2025, 02:21 PM
                          • triplefour
                            by triplefour
                            09-13-2023, 10:43 PM
