HP LA1905WG lcd monitor no backlight
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    Re: HP LA1905WG lcd monitor no backlight
    today..i did find a good working board and so far the transformer reading of 2 pins and mosfet reading are all the same among the 3bad boards and 1 known good one
    so need new direction...
    • shelby5041
      • Feb 2009
      • 1505
      i was going to try to swap transformers to see if thats the issue but cant get it off....lead free solder on both sides board......my novice desolder iron not able to remove....was going to try to cut legs off with dremel.....any ideas?
      cant i test trans in circuit to make sure they are good?
        • 31214
        even if both are bad, the chances of them reading exactly the same are very slim.
        if you get the same readings from both then they are probably o.k.
        • shelby5041
          • Feb 2009
          • 1505
          yes same exact reading on the end with 2 pins...on all 4..boards......what the heck could be causing the issue...it must be common....i have 4 of these doing exact same thing......backlight on then off after 3seconds
          • shelby5041
            • Feb 2009
            • 1505
            i have 1 good board.....and the trans had same readings as the bad boards
            • shelby5041
              • Feb 2009
              • 1505
              #26
              hi....update
              the power supplies are good....it must be a backlight/wiring issue....
              i had in my notes that i tested backlights and were good but today i took all the ps and installed in the known good monitor and they all worked....i then installed the known good ps in the other non work ones and the backlight went off after few sec.....so yes the bad monitors all have an issue with backlight or shorted wires or someting in the blight.....
              • shelby5041
                • Feb 2009
                • 1505
                #27
                thanks bud m and to all others who responded to my thread......since it seems to be a backlight circuitry issue i will toss them out and sell the boards on ebay and maybe try to sell the lcd displays?.....im sure i can sell the boards but kinda doubt the lcd displays would sell
                  • 31214
                  or buy some led kits for about $15
                  • shelby5041
                    • Feb 2009
                    • 1505
                    #29
                    what do u mean led kits?.......monitors not worth repairing if more than 5.00 in parts
                      • 31214
                      maybe not for selling, but for personal use it would be worth $10-15 easy.
                      those are nice monitors.
                      led kits:
                      http://stores.ebay.com/lcd-led-parts...sub=5733816011
                      • shelby5041
                        • Feb 2009
                        • 1505
                        #31
                        nah...i have over 40 lcd monitors now....i try to fix them just to learn......ill make more money sling the boards on ebay....
                        • shelby5041
                          • Feb 2009
                          • 1505
                          #32
                          yes they are good monitors..not cheap.....we use them at work.....they throw them away and i take them and fix sometimed....if cracked screen i convert them into work lights .....the led ones are nice n bright i have 3 above my work bench.....very bright
                          • shelby5041
                            • Feb 2009
                            • 1505
                            #33
                            the stands on these monitors are real nice...made of metal frame not cheap plastic.....i have 20 of them
                              • 31214
                              is that the stand with the 90' rotation function they used on the 1740/1940?
                              those are fantastic!
                                So the lamps are bad.
                                I am curious as how you went about testing the lamps before?
                                  • 31214
                                  testing with a cheap invertor for driving pc illumination probably, those dont have overcurrent sensing.
                                  • shelby5041
                                    • Feb 2009
                                    • 1505
                                    #37
                                    yep....the stands are nice built and look nice and rotate 90 and adjust up down....i basically have a lot of these csuse at work they mount monitors with no stand do i get the stands now n then
                                    • shelby5041
                                      • Feb 2009
                                      • 1505
                                      #38
                                      i tested the lamps by taking a simar model monitor back then and had both backs off and just plugged the backlight power cables from suspect monitor into the other monitor ps snd the backlight stayed on.....
                                      • shelby5041
                                        • Feb 2009
                                        • 1505
                                        #39
                                        im going to do some further testing...maybe there is some wire issue....but yes the problem is in the backlight circuit....if i tap the back of monitor real hard the backlihht comes on for 1 sec then off.....and i can repeat it over n over
                                          Bad CCFL, bad wiring:
                                          http://s807.photobucket.com/user/bud...?sort=3&page=1
                                          • Zilicon
                                            NEWSYNC B27F165 MONITOR HAS NO BACKLIGHT. board no: JY85QS_UPH_LS_R10.3
                                            by Zilicon
                                            Greetings everyone.
                                            Please I need help with the above monitor.
                                            Below is the summary of what happened and what I have done:
                                            The monitor started by turning off 2 seconds after it was turned on. It displayed with a backlight when it turned on. However, the standby light remains on after it is turned off on its own, I have to press the power button again to turn it on, but it will go back to standby after 2 seconds.
                                            The backlight driver IC is 0b3350cp.
                                            I applied a 370k SMD resistor on the CMP pin which is pin 6, while the other...
                                            11-07-2023, 09:12 AM
                                            by momaka
                                            03-15-2023, 10:17 PM
                                          • turmix
                                            AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                                            by turmix
                                            Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                                            The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                                            At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                                            During another reassembly, I made a mistake, and...
                                            01-29-2024, 03:48 AM
                                          • Chiro
                                            DIGMA PRO Art M Monitor 5K IPS 60hz only backlight
                                            by Chiro
                                            The monitor has no visible external damage and has not been dropped. Currently, the backlight is on, but no image is displayed. I have replaced the power and HDMI cables, and connected it to my laptop (the graphics card detects the monitor, but no image appears). The service menu is also unresponsive. Could anyone share insights on troubleshooting or repair options for this issue?
                                            07-06-2025, 02:21 PM
                                          • triplefour
                                            by triplefour
                                            09-13-2023, 10:43 PM
