DIGMA PRO Art M Monitor 5K IPS 60hz only backlight
  • Chiro
    • Jul 2025
    • Estonia
    The monitor has no visible external damage and has not been dropped. Currently, the backlight is on, but no image is displayed. I have replaced the power and HDMI cables, and connected it to my laptop (the graphics card detects the monitor, but no image appears). The service menu is also unresponsive. Could anyone share insights on troubleshooting or repair options for this issue?
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4476
    • Italy - Milan
    Can you post the photo of interface card? Have you checked dc dc converters on interface card? The interface has probably a software problem, no exit from this situation commonly... prepare to throw all away.. and change brand
    • lotas
      • Jan 2016
      • 4759
      • Russia
      If this monitor cost pennies, it could be thrown away, but its price is $800.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4476
        • Italy - Milan
        I'm saying finding softwares, for free or not it's rare today..
        • lotas
          • Jan 2016
          • 4759
          • Russia
          So maybe the problem is in the panel, not in the software, diagnostics are needed first.
          • Chiro
            • Jul 2025
            • Estonia
            Gave it to the service center, repair $60, repair or replacement of the board, which one I did not ask. Asked them if they could put in a cooling system, they said there is enough there.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4476
              • Italy - Milan
              i recall in Italy is mandatory the part code described in the invoice..
              • DanPoka
                by DanPoka
                02-15-2025, 05:05 AM
              • Zilicon
                NEWSYNC B27F165 MONITOR HAS NO BACKLIGHT. board no: JY85QS_UPH_LS_R10.3
                by Zilicon
                Greetings everyone.
                Please I need help with the above monitor.
                Below is the summary of what happened and what I have done:
                The monitor started by turning off 2 seconds after it was turned on. It displayed with a backlight when it turned on. However, the standby light remains on after it is turned off on its own, I have to press the power button again to turn it on, but it will go back to standby after 2 seconds.
                The backlight driver IC is 0b3350cp.
                I applied a 370k SMD resistor on the CMP pin which is pin 6, while the other...
                11-07-2023, 09:12 AM
                by momaka
                03-15-2023, 10:17 PM
              • turmix
                AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                by turmix
                Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                During another reassembly, I made a mistake, and...
                01-29-2024, 03:48 AM
              • triplefour
                by triplefour
                09-13-2023, 10:43 PM
