Need to replace CapXon C426 16V 1000uF 20mm x 10mm 105 degree in LG Flatron L1710S
    I'm not an expert at this but have had success with 2 motherboards and a monitor so decided to give it a shot.
    I can't find a cross-reference for the CapXon C426. Have narrowed it down to the Panasonic EEU-EB1C102. Is it a good match?
    I don't know how to go about getting the correct ripple current. The Panasonic is 430mA. The Capxon says KF in front of the 105 degree label. Is this a clue to the series or ripple?
    Thanks!
    Lew
    Re: Need to replace CapXon C426 16V 1000uF 20mm x 10mm 105 degree in LG Flatron L1710
    EB is the general purpose, you should use FM, FR, or FC series low ESR/Impedance type, that are what I use for all my repair works.
    Juts get the correct dimensions that will fit your board.
      Thanks Bud!
      Digikey doesn't populate the ESR column for the selected Panasonic FM, FR, or FC series you specified, so is AEC-Q200 (non-general) application type with 52 mOhm impedance good?
      Of the FM, FR, and FC series, the only Panasonic with my size and these characteristics is their EEU-FC1C102S.
        It is better to download the datasheet for the cap series you are looking at.
        https://www.badcaps.net/forum/showpo...2&postcount=65
          Well that sounds good to me then.
