rtx 2080 GPU capped at 60 degree
  • dumblejd
    • Dec 2022
    • 10
    My friend has a evga rtx 2080 super, and with liquid cool backplate. I installed for him. 4 month ago it runs good, and recently idk if he played with msi afterburner or not, the gpu slow it's core frequency when it's over 60 degree. I reset setting in msi afterburner, still the same.
    here is a video of it running stress test, the usage is always 100% for sure, but core frenquency drop to 300mhz (should be over 1600mhz normally), when it hit 60 degree.
    https://imgur.com/a/gLMfJid
    at very beginning of stress test, the frequecy can reach 1600+, but as soon as it hit 60 degree, it dropped.
    what I've tried:
    1. install latest nvidia driver (reset setting as well)
    2. reset msi burner setting
    3. check setting in evga pricision software, set to default
    4. raise power limit in msi burner and run stress test again, same.
    note: the liquid cooling system for the gpu is good and running. if it's the cooling issue, it should hit a high temp like 80 degree first than start to lower the frequency.
    any idea what can cause this? and possible fix?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3633
    • slovakia
    Re: rtx 2080 GPU capped at 60 degree
    did u try to flash new vbios?
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3633
      • slovakia
      show gpu-z sensors graph when it ocurs.
        NVIDIA GeForce RTX 2080 Schematic & Board View
        The GeForce RTX 2080 is an enthusiast-class graphics card by NVIDIA, launched on September 20th, 2018. Built on the 12 nm process, and based on the TU104 graphics processor, in its TU104-400A-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU104 graphics processor is a large chip with a die area of 545 mm² and 13,600...
        10-02-2024, 07:57 AM
        NVIDIA GeForce RTX 2080 Ti Schematic & Board View
        The GeForce RTX 2080 Ti is an enthusiast-class graphics card by NVIDIA, launched on September 20th, 2018. Built on the 12 nm process, and based on the TU102 graphics processor, in its TU102-300A-K1-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2080 Ti. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU102 graphics processor is a large chip with a die area of 754...
        10-02-2024, 08:01 AM
      • Inforgalaxie
        Overheating in Stress Test
        by Inforgalaxie
        Hello i have a problem, i have a laptopt Dell E5570 that in stress test without the battery it works good and not turn off.
        But when i conect the battery and made a stress test the cpu temperature go to 95º and turn off. I also was testing with a new battery and the problem is the same in stress test turn off with big cpu temperature (95-100º). What can be this?
        12-13-2023, 03:24 AM
      • Fahd Qureshi
        Missing Capacitors- MSI RTX 2080
        by Fahd Qureshi
        Hi All,
        I recently purchased as MSI RTX 2080 SEAHAWK X, which isn't working. I noticed there are 2 capacitors missing from the back- see images. I am wondering, could this explain why the card won't work? I appreciate any help!
        11-12-2024, 12:20 PM
      • T4H
        RTX 2080 ti (Zotac - triple fan) - No video output / Vcore / Vmem missing
        by T4H
        I have an RTX 2080 ti (Zotac - triple fan) with no video output.
        So far I have measured the following:
        • PS_FBVDD_PH3_SW = 40 ohm to ground (Micron ICs) - Memory should be fine right?
        • 12V power rail present
        • 3.3V power rail present
        • 5V power rail present
        • 1.8V power rail present
        • Vcore power rail missing --> PS_NVVDD_VREF is present. (from uP9512P / U812)
        • Vmem power rail missing --> Not there because Vcore power rail is missing.
        Any idea? I have already tried to flash the BIOS chip (backup got created) - sadly no changes.
        Source: https://www.techp...
        08-19-2023, 08:14 AM
