Need to replace CapXon C426 16V 1000uF 20mm x 10mm 105 degree in LG Flatron L1710S
  • Lew
    • Jan 2010
    • 11
    I'm not an expert at this but have had success with 2 motherboards and a monitor so decided to give it a shot.
    I can't find a cross-reference for the CapXon C426. Have narrowed it down to the Panasonic EEU-EB1C102. Is it a good match?
    I don't know how to go about getting the correct ripple current. The Panasonic is 430mA. The Capxon says KF in front of the 105 degree label. Is this a clue to the series or ripple?
    Thanks!
    Lew
    Re: Need to replace CapXon C426 16V 1000uF 20mm x 10mm 105 degree in LG Flatron L1710
    EB is the general purpose, you should use FM, FR, or FC series low ESR/Impedance type, that are what I use for all my repair works.
    Juts get the correct dimensions that will fit your board.
    • Lew
      • Jan 2010
      • 11
      Thanks Bud!
      Digikey doesn't populate the ESR column for the selected Panasonic FM, FR, or FC series you specified, so is AEC-Q200 (non-general) application type with 52 mOhm impedance good?
      Of the FM, FR, and FC series, the only Panasonic with my size and these characteristics is their EEU-FC1C102S.
        It is better to download the datasheet for the cap series you are looking at.
        https://www.badcaps.net/forum/showpo...2&postcount=65
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          Well that sounds good to me then.
          • dumblejd
            rtx 2080 GPU capped at 60 degree
            by dumblejd
            My friend has a evga rtx 2080 super, and with liquid cool backplate. I installed for him. 4 month ago it runs good, and recently idk if he played with msi afterburner or not, the gpu slow it's core frequency when it's over 60 degree. I reset setting in msi afterburner, still the same.
            here is a video of it running stress test, the usage is always 100% for sure, but core frenquency drop to 300mhz (should be over 1600mhz normally), when it hit 60 degree.
            https://imgur.com/a/gLMfJid
            at very beginning of stress test, the frequecy can reach 1600+, but as...
            12-11-2022, 11:17 PM
          • Bitvive
            LG Flatron starts w. coil whine and power issues
            by Bitvive
            Hi ,
            My old LG Flatron recently started with coil beeping. This got worse every day for a few days until it also started having power problems.
            Now it also went off again after displaying the LG logo, then on, off again, then on and so on...
            So far I have measured the power supply unit, which delivers 19.21V and should therefore be OK. I removed the circuit board and connected it to the mains plug so that I could hear the coil beeping.
            During the beeping, I pressed on the coils with a non-conductive tool to see if the sound changed and to find...
            08-18-2024, 06:34 PM
          • corrize
            858D hot air station provide air at 200 degree instead of 500
            by corrize
            Hello, I noticed that was become almost impossible to desolder component with my hot air station. I measured with meter : air at output is at 220 degree celsius max, even set at 500 degree. So something is bad. Maybe temperature probe inside ?
            Not yet disassembled, have you see some « well know » ou frequently issues to this sort of tools pls ?
            09-23-2022, 12:10 PM
            KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
            by momaka
            For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
            http://www.rmac.kingwin.com/products.../abt_650MM.asp
            I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
            What mostly drew me into buying it is its 2x PCI-E power connectors...
            03-29-2022, 11:34 PM
          • conrado.g
            LG Flatron W2353V no power on, nothing.
            by conrado.g
            Hi folks,
            This is my first post. Richard over at YT Learn Electronics Repair recommended this forum in one of his videos. I am learning electronic repair now in my thirties.
            I have an LG Flatron W2353V that doesn't power on. It just stopped working from one day to the next. No lights, no nothing, and I don't know how to test the keypad since it doesn't have buttons, just a touch keypad. I took out the power supply board, and am attaching pictures. Some of the capacitors are bulged. I have a multimeter and have tested voltage at several places:
            Capacitors:...
            06-01-2023, 09:07 AM
