LG Flatron starts w. coil whine and power issues
This topic has been answered.
  • Bitvive
    • Oct 2023
    • 14
    Hi ,
    My old LG Flatron recently started with coil beeping. This got worse every day for a few days until it also started having power problems.
    Now it also went off again after displaying the LG logo, then on, off again, then on and so on...
    So far I have measured the power supply unit, which delivers 19.21V and should therefore be OK. I removed the circuit board and connected it to the mains plug so that I could hear the coil beeping.
    During the beeping, I pressed on the coils with a non-conductive tool to see if the sound changed and to find the defective component. That's what I had read.
    Now I probably only have the option of measuring with a multimeter? I still lack the experience and know how to find errors by measuring.
    I don't quite know how to find the faulty component at the moment, can you help me?
    PCB:
    E42V
    EAX64485303
    Bear with me, I'm still learning... :p
  • Answer selected by Bitvive at 08-22-2024, 04:20 AM.
    lotas
    • Jan 2016
    • 4809
    • Russia
    The fact that the power supply produces 19v does not indicate that it is working, it must be checked under load, that is, connect it to the board and measure on the other side of the board at the connector contacts what voltage there will be (this will be under load) if the voltage is low and jump when you turn on the board, then split the power supply and change the electrolytes (capacitors).
    • lotas
      • Jan 2016
      • 4809
      • Russia
      • Bitvive
        • Oct 2023
        • 14
        Thanks for the hint mate.. I should have thought of that myself. It actually only measures 15.42V under load. With the laboratory power supply set to 19V 1.7A,
        the display works and does not emit any coil beeping. It can be that simple, new power supply is ordered
        • lotas
          • Jan 2016
          • 4809
          • Russia
          Ok. Yes, you can repair the original power supply, carefully split the plastic case along the seam, get to the board and replace the capacitors...
          • Bitvive
            • Oct 2023
            • 14
            You were right! The case was a real pain to get open, but I immediately noticed a 680 uF 25V electrolytic capacitor that was blown.
            I replaced it and the monitor now runs with the repaired power supply unit without any coil beeping or errors. Great, thank you
            • lotas
              • Jan 2016
              • 4809
              • Russia
              Ok, congratulations, they have a disease with electrolytes, but they restored the original power supply and did not have to buy a fake power supply....
              • Bitvive
                • Oct 2023
                • 14
                Hi Lotas,
                Now my screen simply switches off after a few hours of operation and can then be switched on again normally. What are you thinking? Replace the large 420V buffer capacitor as well?
                • lotas
                  • Jan 2016
                  • 4809
                  • Russia
                  Hi, it’s better to replace everything there if you don’t have an esr meter (they may look good, but their esr may increase and the capacity decrease) and set better quality ones to 105 * degrees, since the power supply heats up and there is no ventilation him.
                  • 90Ninety
                    Coil Whine , buzzing, identifying parts R9 Fury
                    by 90Ninety
                    I have an R9 Furty Nano ( R9 2XX IIRC ) that I want to put to use , I got it on ebay for quite cheap but, it has some of the worse coil whine I have heard .
                    I tried putting a long tube on my ear and hovered it around the card while in use , I cannot pinpoint it . However I my educated guess is , that it the whine is an inductor coil and it is one or all of these in the picture . Does anyone know what part this is and what part I can replace them with .
                    Perhaps likely is that I am missing something else it could be , here is a stock picture...
                    12-15-2022, 04:18 AM
                  • Uranium-235
                    SMD coil whine "chirps"
                    by Uranium-235
                    Does anyone have high frequency sensitivity hearing and a motherboards have tons of sounds coming from it? Is this just coil whine en masse? When data to the SSD has high I/O I can hear the clicks and chirps. Same with when the graphics drive inits. Network adapters, chirping after I connect the cable
                    I can hear everything. Every time I put my ear to let's say an open Shuttle XH series pc (currently working on) in the next room it sounds like I'm in the middle of a the fucking public bird aviary
                    Of course this isn't just the shuttle, though I think the small case...
                    07-10-2023, 10:06 PM
                  • Jumme
                    Boston Acoustics Soundware 5.1 SUB: Agonizing coil whine!
                    by Jumme
                    So. Had my Boston Acoustics subwoofer for 4 years and it had a terrible coil whine squeal from day one.
                    I RMA'd it twice, but both times it came back (after a 6-8 weeks return time) and had the exact same problem.
                    Said they "swapped the amplifier module". As it didnt help, personally I feel more convinced its the PSU module. Company now bankrupt and I cant stand the noise:
                    Its a high pitch coil whine tone -it's terrible agonizing, when worst, I hear it clearly 4-5 m from the Sub (because sits in corner).
                    It wines without RCA input....
                    02-14-2021, 04:03 PM
                  • Gjackson
                    ADP-160FR ps4 slim PSU, shuts down under load and has severe coil whine.
                    by Gjackson
                    Hi all, the PSU originally had a no 12v issue where as soon as I bridged the 5v standby to the ACDC_stby the psu would switch itself off completely. I monitored the voltage on the main filter caps while doing this and saw that the PFC was bringing the voltage up to around 360vdc before shutting down. Given that I saw that as a little low I replaced the PFC feedback resistors from a donor PSU and that got it to power on, without a load no coil whine is present and there is a stable 12v however as soon as I put it in the PS4 it starts whining really badly, however 12v remains stable but after a...
                    01-13-2024, 10:34 AM
                  • satouri abdellwahed
                    PS4 pro power supply coil whine
                    by satouri abdellwahed
                    I have a PlayStation Pro that has a buzzing and ticking sound from the back on the side of the power supply. I searched for a solutions , i tried to make reflow for some of the components but it did not work. In addition, I used silicone on parts on board without any changement. I discovered that if I make a short on the IC in the left corner, the noise stops. Is that dangerous?
                    03-26-2024, 12:44 PM
