Wrong ccfl lamp frame
  • rippergr
    • May 2014
    • 345
    • Ελλάδα
    I ordered some lamps from internet but the frame that has the lamps is bigger.
    Is there anyway to cut the frame without hurting the lamps. Or anyway to fit those in the monitor(maybe I am doing something wrong)
  • HAHOMETP
    • Nov 2012
    • 155
    Re: Wrong ccfl lamp frame
    I'd swap the lamps themselves in their frames. Just be careful. These 3mm glass tubes are extremely fragile.
    • rippergr
      • May 2014
      • 345
      • Ελλάδα
      I am trying to avoid swap the lamps because I broke 4 lamps in the past.
      • HAHOMETP
        • Nov 2012
        • 155
        IMO removing the lamp is easier than say cutting the metal frame with tin snips. Hard to tell from your picture if the tubes are potted in or just placed there on some double sticky tape. If the latter then it should be fairly easy to remove them by gently heating up the metal frame with a heat gun. I use this awesome precision heat gun for everything from peeling off stickers and scotch tape to heat shrinking insulation tubing to even desoldering IC chips from printed boards:
        Off topic: which program do you use to insert callouts into jpegs? I'd rather not build pdf documents for this purpose if there is a simpler alternative.
        • rippergr
          • May 2014
          • 345
          • Ελλάδα
          I finally swap the lamps but now my screen has blue light in a part of it at the begiining and then it kind of fadi and then a white box go up and down ( I think it's the no signal box).
          Does anyone knows what could be that?
          • rippergr
            • May 2014
            • 345
            • Ελλάδα
            ok I've got it. I didn't put a cable correctly.
            Thanks all for your help.
            • rash.m2k
              • Apr 2010
              • 64
              Can you give me the name of this? or a link please where to buy it (UK).
              • selldoor
                Slow Learner
                • 7870
                www.3pointproducts.com/precision-spot-heat-gun/
                Cant see them over here
                  • 31033
                  http://www.dx.com/p/gongjue-8018lcd-...rk-blue-277080
                  • HAHOMETP
                    • Nov 2012
                    • 155
                    It's a Milwaukee 1400 heat gun. There are plenty of them on ebay at any given time.
                      • 31033
                      the one i linked is better, you can set the temp & airflow.
                        • 31033
                        callouts?
                        • selldoor
                          Slow Learner
                          • 7870
                          Yeh - I had not come across it either
                          definition for callout
                          Explanation:
                          callout - A pointer, verbal or graphical or both, to a component of an illustration or a text object.
                          I think this applies to both UK and US English
                          Hmm UK English ?????
                          It means the label put on the picture - I usually fumble something using Paint
                          but I am sure there are better programs
                            • 31033
                            the best is GIMP
                            http://www.gimp.org/
                            and i think the english would be "highlighting"
                            • HAHOMETP
                              • Nov 2012
                              • 155
                              Agree. I've had my eyes on Leister heat guns for quite some time now but just couldn't justify the expense. With the one in your link @ only 42 bux I might give it a try. I like the tightly focused heat source and the temperature regulator is nice to have. Need to find the ~120v version though...
                              No, highlights and callouts are not the same thing.
                              I use callouts extensively in my posts like for example here. For that I have to resort to creating pdf documents which are time consuming create and clumsy to open. I tried making callouts in graphic editors like for example FastStone but they would come out blurred. The callout in the OP looks sharp and crisp, that's why I asked the OP which program he used.
                                • 31033
                                that link shows a pdf with a high res foto in it, i dont see any added text, arrows, circles etc.
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4958
                                  • New Zealand
                                  Originally posted by rippergr
                                  I finally swap the lamps but now my screen has blue light in a part of it at the beginning
                                  Can you explain the problem with the cable? There was someone else who mentioned their monitor backlight showing Blue, I wonder if their problem is the same as yours.
                                  -David VanHorn
                                  • HAHOMETP
                                    • Nov 2012
                                    • 155
                                    Interesting. I have attached a snapshot of that pdf the way it appears on my screen.
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      Shows OK to me though oddly enough the annotation appeared slightly after the picture
                                      • howardc64
                                        by howardc64
                                        Problem
                                        08-04-2024, 10:36 PM
                                      • ttmi100x
                                        HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                                        by ttmi100x
                                        Greetings everyone,
                                        I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                                        The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                                        Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                                        Upon closer inspection...
                                        07-31-2024, 06:36 PM
                                      • mikey5791
                                        Help on Samsung Syncmaster T220 dead ccfl lamp
                                        by mikey5791
                                        This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
                                        Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
                                        10-18-2020, 03:17 AM
                                      • Kemer
                                        Graphics Card mounting frame
                                        by Kemer
                                        Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
                                        As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
                                        I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
                                        What worries me right now is the possibility that...
                                        09-14-2024, 08:57 AM
                                        Design of CCFL Backlight Inverters with Frame & Bar Cores
                                        Summary
                                        Portable devices, such as notebook computers and personal digital assistants are developed rapidly nowadays, which places an increasing demand on display technology. The LCD with cold cathode fluorescent back lighting satisfies the requirements on display performance, size and efficiency.
                                        The backlight inverter plays a crucial role in supplying the power to the lamps of these flat-panel displays.
                                        The frame and bar ferrite cores, described in this brochure, are especially designed...
                                        10-07-2024, 04:26 AM
