Design of CCFL Backlight Inverters with Frame & Bar Cores
    Summary
    Portable devices, such as notebook computers and personal digital assistants are developed rapidly nowadays, which places an increasing demand on display technology. The LCD with cold cathode fluorescent back lighting satisfies the requirements on display performance, size and efficiency.
    The backlight inverter plays a crucial role in supplying the power to the lamps of these flat-panel displays.
    The frame and bar ferrite cores, described in this brochure, are especially designed to build the slender, low profile transformers required for these inverters.
    A worked out design example is given, as well as data sheets of the standard range of 4 sizes frame and bare cores in 3C90 and 3C91, including the dedicated SMD coil formers.​
  • DanPoka
    by DanPoka
    02-15-2025, 05:05 AM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • triplefour
    by triplefour
    09-13-2023, 10:43 PM
  • KYBOSH
    Trying To Fix: Samsung THE FRAME backlight replacment - How to open display???
    by KYBOSH
    I came across this TV (UN65LSO3NAF) and would LOVE to replace the backlights and save it but i do not know how to access it. I attempted this repair not too long ago on a 50 inch model and cracked the display while tryjng to remove the bezel around it. Even after that display crack and i was free to do an autopsy on the remains i could not find a safer/proper way of removing the metal frame around the display. Does anyone know the trick to opening these FRAME TV displays? Im not above carefully taking a dremel to the corners but im pretty sure there is a right way to do this. I have looked...
    09-24-2024, 01:32 PM
  • Comp_Pro
    No Backlight Macbook A1990 820-01041
    by Comp_Pro
    Hello all,
    Am trying to figure out this backlight issue with this A1990 Macbook Pro.
    Tests performed:
    There is no backlight even with a good screen.
    Backlight IC is receiving the correct support voltages.
    Fuse F8400 ok
    Current sense resistor R8400 ok
    Backlight IC is receiving 3.3V on enable pin.
    Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
    Backlight IC receiving 5V from PP5V_G3S
    Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
    I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
    05-06-2024, 10:23 PM
