lg flatron w2286L problem
+ More Options
Posts
  • vagos_89
    • Apr 2014
    • 61
    • Greece
    Hello everyone and first of all sorry for my english! I have the lg monitor above with smps adapter and suddenly when i opened the monitor and appeared the lg logo came two white lines from left to the right. When the windows started i saw that the monitor has broplem and the picture is roil. I first prevented replace all electrolytic capacitors of smps adapter (there wasn't defectives) and i check with multimeter the adapter and is ok. The voltages in regulator is 1,8V and 4V. Here are some photos! Can anyone help me? Thanks in advance!
  • vagos_89
    • Apr 2014
    • 61
    • Greece
    Re: lg flatron w2286L problem
    I tried with diferent pc and other vga and tha problem remains. I didn't try with hdmi cable.
    • selldoor
      Slow Learner
      • 7870
      Hi - is the problem in picture 3 the same as the original problem?
      Was the monitor in use by you before it went wrong.
      Do you still get the 2 white lines when first on or have you fixed that?
      When you tried on another pc did you use a different vga cable?
      The picture suggests a faulty panel or the cable between the panel
      and the main/logic board.
      If it is a flat ribbon cable at the panel end, try cleaning the connectors
      and reseating it.
      • vagos_89
        • Apr 2014
        • 61
        • Greece
        and reseating it.
        Yes, the broblem is tha same as the picture 3, i took a picture of the screen. The monitor was in use and suddenly the screen blurred. I restarted my pc and saw the white lines and from then the screen it is as the picture 3. No i didn't fixed the 2 lines, i still get it. Yes i tried with other vga cable but i didn't try with hdmi. I cleaned the connectors of the cable with toothbrush but the broblem remains..
        • vagos_89
          • Apr 2014
          • 61
          • Greece
          I also tried with a different flat ribbon cable from αnother lg panel and nothing.. I believe that it isn't vga or hdmi or pc broblem because the screen is like picture 3 without signal cable connect. (I have the monitor only with power cable, show me the message "checκ signal cable" and the sreen is like picture 3)
          • selldoor
            Slow Learner
            • 7870
            Hi can only suggest you try with hdmi and dvi.
            Post a picture of an all white screen and all black one someone may
            recognise the problem.
            There are other voltage regulators on that main/logic board have you tested them all. Is 1.8v and 4v correct? 4 is an unusual voltage to see.
            EDIT
            If you unplug the lvds cable do you get a white screen without any coloured lines?
            I am trying to find out if it is a faulty panel.
            • bammbammfran
              • Apr 2014
              • 476
              regulator voltage is 1.8 and 4 ??
              Is that the voltages on two different pins of the one large regulator or the voltages on two separate regulators ?
              what is that regulator part number
              and
              it looks like there might be a smaller regulator on the other side of the blue resistor, what is that one
              • vagos_89
                • Apr 2014
                • 61
                • Greece
                Ok i'll try with hdmi ani dvi cable. The first picture is with unplug lvds cable( i get white screen without lines). The second picture is without signal cable ane i have blurry screen and line. I can detect two regulators, the first which is in red cycle is AZ1086S and i have: pin1->0V, pin2->1,8V, pin3->5,06V. The second which is in yellow cycle is EH16A 920N61(i can't find datasheet) and i have: pin1->0V, pin2->3,3V, pin3->5,1V.
                  Try heating up that main/scaler board with hair dryer for a few minutes to see if it will change the symptom.
                  • selldoor
                    Slow Learner
                    • 7870
                    Those voltage regulators seem ok
                    Perhaps read this thread:
                    https://www.badcaps.net/forum/showthread.php?t=20909
                    It is a different set but had a similar problem to yours which seemed to be
                    on the tcon/panel board.
                    Perhaps put up pictures of that - there maybe voltage regulator to test or may
                    have voltage test points.
                    • vagos_89
                      • Apr 2014
                      • 61
                      • Greece
                      I have already tried to heat the mainboard but nothing.. thanks..
                      • vagos_89
                        • Apr 2014
                        • 61
                        • Greece
                        In my tcon board i can detect one voltage regulator. The RT9164A and i have pin1->130mV
                        pin2->3,6V and pin3->4,65V, these voltages are without signal cable. For a reason that i can't find when i plug the vga the monitor goes to stanby and i have not voltages.
                          When the monitor goes into the standby mode the voltage to the T-CON is switched off to save power.
                          • selldoor
                            Slow Learner
                            • 7870
                            Here is the datasheet for RT9164A Are there no numbers after the part number to indicate a fixed voltage?
                            http://pdf1.alldatasheet.com/datashe...K/RT9164A.html
                            If not it is an adjustable one and if so may be faulty. On an adjustable the
                            voltage difference should be 1.25 not 1.05. maybe that is enough to cause the problem - perhaps budm will advise better.
                            Any electrolytics on that board?
                            • vagos_89
                              • Apr 2014
                              • 61
                              • Greece
                              Thanks budm and selldoor, the problem with the standby mode solved. Yes, there are numbers after the part number, is RT9164A 33GGBGD04. The voltageis now are: pin1->114mV, pin2->3,45V, pin3->4,8V. No there aren't electrolytics capacitors on tcon board.
                              • bammbammfran
                                • Apr 2014
                                • 476
                                That should be putting out 3.3v
                                Your readings now are a little different than last time.
                                Are your tester batteries good ?
                                • vagos_89
                                  • Apr 2014
                                  • 61
                                  • Greece
                                  Yes are good. I don't know, maybe because the first measurements became without signal cable, because as i said above the monitor went to standby mode when i plugged the vga.
                                  • bammbammfran
                                    • Apr 2014
                                    • 476
                                    well
                                    the 3.3 is high and it looks like the 5 is a little low
                                    I have seen voltage regulators on main boards cause picture some issues
                                    so there is a chance that this is the part that might be causing the static.
                                    • vagos_89
                                      • Apr 2014
                                      • 61
                                      • Greece
                                      well
                                      So, you sugest me to replace this voltage regulator? Is there anything else that i could to do?
                                      • selldoor
                                        Slow Learner
                                        • 7870
                                        Pictures are not really clear enough are there any test points for the 5 volts?
                                        That should be coming from the main board so is there a 5v testpoint on or near the
                                        socket on the main board
                                        • Askic
                                          Problem with monitor DS-D5022QE-B
                                          by Askic
                                          Hello to all,
                                          I have a problem with monitor that is delivered together with CCTV system.
                                          The monitor appears to be completely dead, there is no LED power diode and it doesn't react to pressed power button.
                                          I have disconnect display and check many components on the power supply part of the board. There is no anything obvious and monitor is about 3 years old. There are no bulged caps. When measuring voltages on the output connector to VGA board I can measure stable 14.5 V on 12V pins and stable 5.07V on 5V pins. So I assumed that this part of the board is OK....
                                          05-31-2023, 03:14 AM
                                        • CptChronic
                                          Samsung LU32J590UQUXEN Monitor display problem
                                          by CptChronic
                                          I have an intermittent display problem with my monitor, when I plug in the HDMI cable to my (or any) laptop, you see the connection screen shrink on the laptop as it usually would before displaying on the monitor but 95% of the time the monitor display stays black.
                                          Before it cut out all together, tapping the monitor control button a fair few times would make the screen display, and everything work fine.
                                          But now it never does it. Not sure what's going on, hoping someone can help. I'm capable of stripping the thing down and soldering in new parts if needed, or programming...
                                          04-24-2023, 04:33 PM
                                        • tmhobadcap
                                          LG 24MP56HQ-P Monitor Backlight problem?
                                          by tmhobadcap
                                          I have a few successful experience in fixing tv backlight problem. But for monitor, I have no experience. However, I think they are more or less the same. Am I correct?
                                          Recently, I got the captioned monitor and the owner said it could not be turned on. I open it up and found that one of the SMT capacitors seemed to be bad. I replaced it as well as the other one. The monitor still could not be turned on.
                                          I found the power indicator is on. When I shine a flashlight on the screen, I can see the image. Therefore, I think it is with backlight problem. I took out the led strip....
                                          10-13-2021, 01:52 PM
                                        • tmhobadcap
                                          by tmhobadcap
                                          10-12-2021, 01:43 PM
                                        • Phil Stasik
                                          Pioneer PRO-FHD1 Elite Plasma Monitor Start-Up Problem
                                          by Phil Stasik
                                          Pioneer Pro-FHD1 Elite. Failure to power on.
                                          I'm new to this awesome forum, and have been reading like mad, but have not seen the answer to my challenge.
                                          We bought this Panasonic plasma monitor 16 years ago and it has never been serviced, so all parts are original, and the unit has never malfunctioned -- until about a month ago. The system fails to power on. At first (a month ago) this happened rarely. We learned to unplug for a few minutes to drain the caps, then re-plug, and the monitor would start normally. Now, we plug-in, turn on the main power switch, and the...
                                          01-19-2023, 01:22 AM
