Dell E153FPB Back Light problem
  • jschiefer
    • Nov 2009
    • 19
    #161
    Re: Dell E153FPB Back Light problem
    Is that (4th) pin, the yellow one, supposed to be 0v?
    • paslug
      • Jan 2012
      • 3
      #162
      Jschiefer, Did you try a different vga cable?
      EDIT: Sorry, I just reread your post where you said you tried a different cable and source. My Bad
      Ray
      • retiredcaps
        • Apr 2010
        • 9271
        #163
        I don't know. The legend is obscured in the picture.
        --- begin sig file ---
        --- end sig file ---
        • jschiefer
          • Nov 2009
          • 19
          #164
          I'll try another cable. I'll grab a new one from work. Maybe I have two bad ones and my other source isn't as sensative. I'll take a better picture of the molecular connector later.
          • retiredcaps
            • Apr 2010
            • 9271
            #165
            That reminds me of another thread. Try to get a quality thick shielded cable. One person has those cheap thin cables and when he replaced it, the problem went away. Unfortunately, I don't remember which thread it was or what the original symptoms were.
            • jschiefer
              • Nov 2009
              • 19
              #166
              Well I hate to admit this but I guess it will be good for the forum. The problem was the cable. I tried a brand new one and it works fine now. I tried the old one on another set up and it is fine too. I guess this monitor is just a little more sensitive than others. (and I have two "bad" cables).
              Thanks for all your help.
              • retiredcaps
                • Apr 2010
                • 9271
                #167
                Glad it was an easy fix.
                • jesusbaqui
                  • Mexico
                  #168
                  Originally posted by brianh
                  Ahhh - finally I've found the problem!!!!
                  After a lot of trial and error I have the CCFL lamps back on!
                  I won't keep you in suspense any longer... The problem was a blown fuse!
                  No... not the big white one, it was a little black one labeled PF751 (see previously posted photo if you're interested - it's on the right side and looks more like a rectifier diode).
                  I can read the letters "MS 2A" on it - so I guess that means that it's a 2 amp fuse. Someone else posted a schematic for a similar Diamond View monitor, which shows a 3 amp fuse. (ref: Inverter Schematic )
                  I've jumpered the fuse with an extremely fine strand of wire, and the CCFL now comes on. I'm giving it a burn-in-test right now. So far 1/2 hour and all is well.
                  I am, however, not willing to call it "fixed" yet - after all... Why did the fuse blow in the first place?
                  Sure... I plan on putting in a proper fuse, but I don't want to re-assemble it and have it blow another fuse (or worse) in a day or two.
                  But hey... after way too many hours on this project - at least I've got something positive!
                  Any thoughts?
                  Thanks man , you save me
                  i was thinking about buy another monitor
                  • larry256
                    • Sep 2012
                    • phillipines
                    #169
                    can i replace fu9024n with c5707's
                    • Rtech
                      • Jul 2010
                      • 1095
                      #170
                      NO, the FU is a P channel mosfet,you could use 2SJ598,FQU11P06,BUT NOT the 5707's
                      • alihomee
                        • Dec 2012
                        • 1577
                        • malaysia
                        #171
                        thanks for this post i tried it and it works
                        • bcstedt
                          • Jun 2011
                          • 59
                          Originally posted by bcstedt
                          Repair kit arrived yesterday and after re-soldering all four Xformers (bent the leads out for better electrical / mechanical connection) and replacing two c5707 Xsistors it is back up and running. Will burn it in for a day, but so far so good.
                          Just wanted to say that everything is still working fine since the fix. Thanks again for the support!
                          • halobender
                            • Apr 2013
                            • 36
                            Anyone having issues with this model should try adjusting the pot on the back of the panel. All fuses, caps, xr's all tested good for me so I tried adjusting the pot and sure enough I went from a screen that would turn on for a moment then go black to a monitor with a screen that stays on. Remember small turns on the pot and I recommend doing it while powered up so you can see changes live.
                              Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                              by sam_sam_sam
                              This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                              I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                              I am comparing them to a brand new one that I installed
                              The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                              I going to let it run for several days before I remount back on the wall next to the...
                              09-05-2024, 06:48 PM
                            • multimesut
                              Dell 2007FPB Yellow Light Problem
                              by multimesut
                              Hello friends,
                              A yellow light was flashing on my monitor. It was like it was constantly cutting power. When I opened it up, I saw that the big capacitor in the high voltage line was leaking. I replaced it. When I turned it on for the first time, it had the same problem again. But then, interestingly, it got better. The yellow light was on steady. But the monitor wouldn't turn on. When I examined them with a thermal camera, I saw that the Fli5961-LF reached 50 degrees Celsius and the EM636165TS next to it reached 100 degrees Celsius and was drawing high current on the motherboard....
                              11-13-2024, 07:00 AM
                            • boyebaran
                              hisense 65k560 back light problem
                              by boyebaran
                              hi to all
                              tv turn on and show logo(backlight on)than backlight turn off than red led in front blinking 7 time. the tv remote control working fine (sound on no picture).backlight changed same problem
                              in 65k560 how to remove protection of backlight? picture of inverter and sockets attached .
                              please advise me tnx
                              05-20-2025, 07:11 AM
                            • SDNarcia
                              Dell 15R-5521 keyboard problem (KBC?)
                              by SDNarcia
                              Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                              As additional information,...
                              07-20-2024, 10:47 PM
                            • Achille15
                              Dell N5110 problem
                              by Achille15
                              so, I have this laptop Dell Inspiron N5110 with a heating problem on both CPU (I7-2680qm) and GPU (GT 525m), I tried many solutions, like changing thermal paste every month, using thermal pads on CPU and GPU, even using thermal pads on CPU nearby coils; but nothing worked, just minutes after booting the laptop shuts itself down so I thought it might be a short problem, so I decided to check what's going on, so I went online and some tutorial (general one) said to check inductors in order to find the shorted circuit, after checking (CPU removed), I found the culprit to be...
                              03-29-2025, 04:41 PM
