Dell E153FPB Back Light problem
There are 10 kind of people in this world: those that understand binary, and those who don't.- ASUS ROG Maximus IX Code
- Intel Core i5-7600K 3.8GHz
- 16gb GSKILL TridentZ RGB DDR4-3200
- 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
- Windows 10 Pro x64
- GeForce GT1050
2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job)
Re: Dell E153FPB Back Light problem
Originally posted by freakytiki4uWhat is the proper way to test the Transistors? I noticed they have 3 legs each. I tested with my Ohm meter and there are differences but I would like to know specifically what Im looking for and how to properly test to determine defective ones.
Red probe on B and Black on C, Should read about 600
Red probe on B and Black on E, Should read about 600
Testing for shorts between pins set MM to Buzzer and check
B + C
B + E
C + E
Probes both waysComment
Thank you for the info. I tested and found bad transistors. I ordered a few kits from Ebay and after repair the Monitor is working just fine. A friend gave me 2 more 19" monitors and I have also repaired them. I found several cold solder joints too and fixed those also. Thanks to all of you who helped and if I can ever do anything for you just ask. I will try my best.Comment
Originally posted by freakytiki4uThank you for the info. I tested and found bad transistors. I ordered a few kits from Ebay and after repair the Monitor is working just fine. A friend gave me 2 more 19" monitors and I have also repaired them. I found several cold solder joints too and fixed those also. Thanks to all of you who helped and if I can ever do anything for you just ask. I will try my best.For a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
Originally posted by PlainBillCongratulations!!!There are 10 kind of people in this world: those that understand binary, and those who don't.- ASUS ROG Maximus IX Code
- GeForce GT1050
I have just aquired an E153FPb which was showing a green light but no display. After reading this thread I tried the fuse PF751 and that has brought the backlights on. However there is no display. Enthused by moving a stage forward I did a bit more googling to see if I could find any similar experiences and came across the folowing:- http://www.elbase.ru/files/cd/monito.../BENQ%20FP531/ This is an index of Benq technical sheets, diagrams and fault finding flowchart for the Benq FP531. The E153FPb is based on the Benq FP531 (denoted by the b). There are some variations depending on the LCD manufacturer (eg. LG, AU) This may prove useful to anyone visiting here in the future. I am currently trying to source the components I need locally and if the thread is still running when I've got them I will leave an update.Comment
Originally posted by GeordieboyI have just aquired an E153FPb which was showing a green light but no display. After reading this thread I tried the fuse PF751 and that has brought the backlights on. However there is no display. Enthused by moving a stage forward I did a bit more googling to see if I could find any similar experiences and came across the folowing:- http://www.elbase.ru/files/cd/monito.../BENQ%20FP531/ This is an index of Benq technical sheets, diagrams and fault finding flowchart for the Benq FP531. The E153FPb is based on the Benq FP531 (denoted by the b). There are some variations depending on the LCD manufacturer (eg. LG, AU) This may prove useful to anyone visiting here in the future. I am currently trying to source the components I need locally and if the thread is still running when I've got them I will leave an update.
Badcaps does not close Threads its always glad to recieve new Info at any time
Look forward to your update
bobComment
I have a Dell E173FPs. Symptoms: Green power light just flashes quickly. No picture at all. I found 2 swollen caps and replaced them, still same thing. Green light just flashes quickly. The Power and Inverter board is model # IP-35135A (photo attached.) Anyone have any ideas what may cause this? I am looking for cold solder joints in the meantime. I have found it a good idea to just go ahead and resolder the transformers anyway as cold solder joints are so common. Srry if this is considered hijacking the thread.Comment
Originally posted by freakytiki4uI have a Dell E173FPs. Symptoms: Green power light just flashes quickly. No picture at all. I found 2 swollen caps and replaced them, still same thing. Green light just flashes quickly. The Power and Inverter board is model # IP-35135A (photo attached.) Anyone have any ideas what may cause this? I am looking for cold solder joints in the meantime. I have found it a good idea to just go ahead and resolder the transformers anyway as cold solder joints are so common. Srry if this is considered hijacking the thread.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Im having trouble uploading better pics due to size. Not sure how to make them the right size. lolComment
Originally posted by freakytiki4uIm having trouble uploading better pics due to size. Not sure how to make them the right size. lol
I downlaoded the trial but it watermarks. lol, anyway I could email the pics to ya?Comment
EduardoThere are 10 kind of people in this world: those that understand binary, and those who don't.- ASUS ROG Maximus IX Code
- GeForce GT1050
Originally posted by eguevaraeTry Fotosizer. You drop in an image, specify a new size either in percentage of the original or in pixels, and it resizes it either replacing your original or saving it to another place (or the same place with another name). It is what I sometimes use when I have to meet size (either in Kb or in pixel dimensions) reqs.
Eduardo
Wow, ty, very very easy to use and free, cant ask for more than that! lol Pics are attached as you asked ofr.Comment
Originally posted by freakytiki4uWow, ty, very very easy to use and free, cant ask for more than that! lol Pics are attached as you asked ofr.
I also circled two ICs in blue. If these were shorted it could cause the problem. What is the part number of the ICs?
Voltages are solid 10 volts testing each pos with all 3 neg. Same 10 volts on all.
Numbers on IC's are the same. Each has 4501GM and S05034 (might be 505034, hard to tell they are so small)Comment
I did not have the bulbs hooked up when testing voltage incase that makes a difference but it was hooked to the logic board.Comment
Originally posted by freakytiki4uVoltages are solid 10 volts testing each pos with all 3 neg. Same 10 volts on all.
I checked again on 50 volt range with analog meter, still reading 10 volts, checked on 10 volt range reads maxed out, just a hair over 10 volts ACComment
by sam_sam_samThis happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
I am comparing them to a brand new one that I installed
The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
I going to let it run for several days before I remount back on the wall next to the... -
by multimesutHello friends,
A yellow light was flashing on my monitor. It was like it was constantly cutting power. When I opened it up, I saw that the big capacitor in the high voltage line was leaking. I replaced it. When I turned it on for the first time, it had the same problem again. But then, interestingly, it got better. The yellow light was on steady. But the monitor wouldn't turn on. When I examined them with a thermal camera, I saw that the Fli5961-LF reached 50 degrees Celsius and the EM636165TS next to it reached 100 degrees Celsius and was drawing high current on the motherboard....1 Photo-
11-13-2024, 07:00 AM -
by boyebaranhi to all
tv turn on and show logo(backlight on)than backlight turn off than red led in front blinking 7 time. the tv remote control working fine (sound on no picture).backlight changed same problem
in 65k560 how to remove protection of backlight? picture of inverter and sockets attached .
please advise me tnx4 Photos05-20-2025, 07:11 AM -
by SDNarciaHello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
As additional information,... -
by Achille15Hello everyone,
so, I have this laptop Dell Inspiron N5110 with a heating problem on both CPU (I7-2680qm) and GPU (GT 525m), I tried many solutions, like changing thermal paste every month, using thermal pads on CPU and GPU, even using thermal pads on CPU nearby coils; but nothing worked, just minutes after booting the laptop shuts itself down so I thought it might be a short problem, so I decided to check what's going on, so I went online and some tutorial (general one) said to check inductors in order to find the shorted circuit, after checking (CPU removed), I found the culprit to be... - Loading...
