Dell E153FPB Back Light problem
  • Bobdee
    • Jun 2008
    • 461
    Re: Dell E153FPB Back Light problem
    Originally posted by Bubii
    Hi Guys! I own Dell E153FPB and it has backlight problem. It works for a few secs and than the backlights turn off. The pictuire is there but no backlight. I did change pf751 and resoldered the transformers' contacts and it worked for about 20 mins (I tought it was fixed) and now it is just the same. I know it's easier to trow it in a trash but I spent so much time on research on this s##t...It was said that the problem might be the SG6841S High-integrated Green-mode PWM Controller but before I buy it I wanna know what you suggest. Help...Help...Plz.
    Thanks.
    Check out the 4 transistors on Inverter = Q739, Q740, Q759, Q760
    You are looking for shorts between the pins, if they check out okay then check there solder joints to board of the transistors with about a 10X magnifying glass looking for ring crack or any bad solder joint to resolder
    Do the same to the 2 mosfets as well Q743, Q759
    also check the rest of the board for ring cracks or bad solder joints, Benq boards always have bad solder joints
    • simpyborgs
      • Jul 2009
      Mr Brianh...... i ask how thin is the wire you jumpered in replace with the MS 2A? or what other devices i can replace with that device? can i replace it ordinary fuse?with 2A on its spec?
      • freakytiki4u
        Coolest Member
        • Aug 2009
        • 130
        Originally posted by Nama
        Yet another PF751 bad. Monitor has been on now for 3 hours with no problem. Thank you for you follow up Brianh. Jacob
        Where can these Mini Pico Fuses be purchased?
        • PlainBill
          • Feb 2009
          • 7034
          Mouser, Digikey both carry them.
          PlainBill
          • freakytiki4u
            Coolest Member
            • Aug 2009
            • 130
            Wow, very fast reply from a few of you. I like this forum! Thank you very much. I actually just got off the phone with Digikey and have ordered what I need. Ill post if it works when I receive the parts. You guys rawk! I repair computers for a living and dable in electronics repair so if you ever need anything just ask.
            • freakytiki4u
              Coolest Member
              • Aug 2009
              • 130
              Update.......I ordered the wrong type of fuse . What I ordered were not axial (no legs) they were just square as if they were meant to be popped in. They were the correct voltage and amperage so I decided to solder some legs on and put it in. It works perfectly! I have thrown out sooooo many flat panels with bad inverters that I most likely could have fixed /sigh
              Thank you guys so much for this thread.
              • freakytiki4u
                Coolest Member
                • Aug 2009
                • 130
                The Flat Panel I fixed has stopped working again. Now it just blinks on and off. Any ideas anyone? I was so excited to have it working.
                • EGuevarae
                  • Nov 2008
                  • 1336
                  What did you replace in the unit (and with what)?
                  • ASUS ROG Maximus IX Code
                  • Intel Core i5-7600K 3.8GHz
                  • Windows 10 Pro x64
                  • GeForce GT1050
                  • freakytiki4u
                    Coolest Member
                    • Aug 2009
                    • 130
                    I replaced the PF751 Pico Fuse and the monitor worked for a solid week. Now it just blinks on and off repeatedly.
                    • freakytiki4u
                      Coolest Member
                      • Aug 2009
                      • 130
                      I justy replaced the Pico Fuse again and its working again. What would cause the Pico Fuse to keep burning out? Please be very descriptive about location and part description as Im just a beginner board level repair newbie.
                      • PlainBill
                        • Feb 2009
                        • 7034
                        Probably a leaky transistor. Provide GOOD pictures of the inverter board and we can identify twhat to test.
                        PlainBill
                        • freakytiki4u
                          Coolest Member
                          • Aug 2009
                          • 130
                          ok will do, the picture is attached of the Inverter Board.
                          • PlainBill
                            • Feb 2009
                            • 7034
                            Great picture!! I've marked it up. The four transistors circled in red should be checked with an ohmmeter. We are looking for differences between one pair and the other.
                            Also, two transformers were circled in blue. Resolder the leads on all of them.
                            PlainBill
                            • freakytiki4u
                              Coolest Member
                              • Aug 2009
                              • 130
                              Thank you very much for the quick reply. I will resolder and check with Ohm Meter tomorrow.
                              • freakytiki4u
                                Coolest Member
                                • Aug 2009
                                • 130
                                If I want to order the 4 transistors on Inverter = Q739, Q740, Q759, Q760
                                for replacement, what would I ask for?
                                • Bobdee
                                  • Jun 2008
                                  • 461
                                  #36
                                  They are either C5707s or 6s
                                  Read the front of one, (you may need magnifying glass)
                                  You can replace 7s with 6s if doing all four, but there are plenty of both on ebay (type in search box 2SC5607)
                                  You can get kits with 4 transistors + 2 fets fu9024n and a 2 or 3 amp p/fuse
                                  • freakytiki4u
                                    Coolest Member
                                    • Aug 2009
                                    • 130
                                    Thank you very much, I found the kits on Ebay and have a few on the way. I appreciate the continued quick replies. You guys really do rock!
                                    • EGuevarae
                                      • Nov 2008
                                      • 1336
                                      Just remember to resolder transformer points and all other cold solder areas that you come across, or either the 07's will fry again ...
                                      • GeForce GT1050
                                      • freakytiki4u
                                        Coolest Member
                                        • Aug 2009
                                        • 130
                                        Will do and thank you for the info
                                        • freakytiki4u
                                          Coolest Member
                                          • Aug 2009
                                          • 130
                                          What is the proper way to test the Transistors? I noticed they have 3 legs each. I tested with my Ohm meter and there are differences but I would like to know specifically what Im looking for and how to properly test to determine defective ones.
                                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                            by sam_sam_sam
                                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                            I am comparing them to a brand new one that I installed
                                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                            I going to let it run for several days before I remount back on the wall next to the...
                                            09-05-2024, 06:48 PM
                                          • multimesut
                                            Dell 2007FPB Yellow Light Problem
                                            by multimesut
                                            Hello friends,
                                            A yellow light was flashing on my monitor. It was like it was constantly cutting power. When I opened it up, I saw that the big capacitor in the high voltage line was leaking. I replaced it. When I turned it on for the first time, it had the same problem again. But then, interestingly, it got better. The yellow light was on steady. But the monitor wouldn't turn on. When I examined them with a thermal camera, I saw that the Fli5961-LF reached 50 degrees Celsius and the EM636165TS next to it reached 100 degrees Celsius and was drawing high current on the motherboard....
                                            11-13-2024, 07:00 AM
                                          • boyebaran
                                            hisense 65k560 back light problem
                                            by boyebaran
                                            hi to all
                                            tv turn on and show logo(backlight on)than backlight turn off than red led in front blinking 7 time. the tv remote control working fine (sound on no picture).backlight changed same problem
                                            in 65k560 how to remove protection of backlight? picture of inverter and sockets attached .
                                            please advise me tnx
                                            05-20-2025, 07:11 AM
                                          • Matias1997caba
                                            Problem with Dell pp35l bios
                                            by Matias1997caba
                                            Hello everyone! I'm having a problem with the BIOS of a Dell PP35L motherboard (DA0RM5MB8E0 Rev:E Y509R Rev:A00). It powers on, beeps 5 times, then 6 times, but there's no display. The problem is that it has two 16MB BIOS files, and all the ones I found online are 1MB and 4MB. I flashed them anyway, but with those BIOS files, the fan doesn't even turn on. Any help would be greatly appreciated! I've attached the BIOS files. Model: Dell PP35L.. Mother DA0RM5MB8E0 Rev:E Y509R Rev:A00. Service Tag: GRZR9M1...
                                            11-26-2025, 08:33 AM
                                          • SDNarcia
                                            Dell 15R-5521 keyboard problem (KBC?)
                                            by SDNarcia
                                            Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                                            As additional information,...
                                            07-20-2024, 10:47 PM
