My monitor (lg flatron w1924s) is acting odd. When i press the on button he does not turn blue (the button doesnt turn blue) instead it starts blinking on and off for 15 minutes and after that the monitor works fine. Whats wrong with it? Pls just help understand the problem so i can know if i can repair it or just buy a new one ( witch is expensive for me now). Thx and i hope not to disturb you much. Sorry for writting errors...
lg w1924s start button blibking for 15 minutes
Re: lg w1924s start button blibking for 15 minutes
First thing to do is to open up the unit and inspect the board for any caps with bulging tops.
Your board will be similar to this example:
http://s807.photobucket.com/user/bud...?sort=3&page=1
Bad caps example:
http://s807.photobucket.com/user/bud...?sort=3&page=1Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
from all 8 caps that i have only 1 is the same. For example. I have 1mF/450 and he gaved me 1mF/400. i have 470mF/25 he gave me 470/35. I have 22mF/50 he gave me 22/63. Is it something wrong with me that i think i should replace only with the same value or it is ok if i replace them with what he gave? Pls heeelpComment
You can go a voltage higher so they are good.
The Big cap would be better at 450v but 400v is acceptable.
If the big cap you have doesnt look bulged or leaky try without changing it as tron said.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
It seems like you did not properly seat the cable between the logic board and the LCD panel where the T-CON board is, or the T-CON board is dead, or the logic board is not sending the 5V (or 12V) to the T-CON board.Never stop learning
Do you have a pc connected to it?Please upload pictures using attachment function when ask for help on the repair
i have turn it on. Works but... I see vertical white lines. Its like this... One line in coloured and one is white. And it goes all over the monitor. Could it be cause i have changed only that bad cap?Comment
Could be a faulty screen - was it your monitor - did it work without lines before?
If so, take off the lvds cable mentioned by budm clean both ends (if a flat cable use an eraser) then replace.Please upload pictures using attachment function when ask for help on the repair
If you have cleaned the lvds - check any other cables are secure and try again
Have you got a PC connected - is the resolution correct?
Then I would put in the rest of the new caps- that will give a good base for any more testing.Please upload pictures using attachment function when ask for help on the repair
Unlikely, check the cable from the PC to the monitor is ok.
Do you get dots on White Yellow Blue Red Screens?Please upload pictures using attachment function when ask for help on the repair
those green dots are observed only when the monitor is in save energy mode or when not connectec to a pc. It has to be a black screen so i can see them. Once i connect the pc to it those dots are gone but the monitor goes like... one vertical line is coloured and one white. A line mean a vertical row of pixels from top un to bottom down. One line coloured and one white. The rest is ok. Resolution ok and all the buttons work.Comment
If you have tried cleaning all the cables , do you have another monitor you can try on the pc or anther pc/laptop you can try this monitor on ? That will rule out a video card/processor problem. You may have damaged the panel taking the monitor apart causing the lines. I dont know what is causing the green spots.Please upload pictures using attachment function when ask for help on the repair
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
by ant3202Hi Everyone
Lately I am experiencing the deja-vu incident on one of the led monitor like this.
https://www.badcaps.net/forum/troubl...lashing-on-off
The monitor is HP 27es LED Monitor
https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
The monitor will randomly blackout and display no signal and will recover again.
Sometimes need to power and off again to restore the display but...-
by momakaLooking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
When I saw the Craigslist post, I wasn't...-
by Rick_1234Good evening, gentlemen.
I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
https://drive.google.com/file/d/1L6S...ew?usp=sharing
Things I tried
- Bought a new AC adapter thinking that was the problem but the problem...-
by usbdeviceHi all
There's two other threads about this monitor with seemingly the same problem. The problem was resolved in one case by replacing the entire PSU board and in the second one by replacing an unknown IC.
https://www.badcaps.net/forum/showthread.php?t=50657
https://www.badcaps.net/forum/showthread.php?t=40512
The first one has pictures of the pcbs and I noticed that there's one IC and assorted caps not populated on mine (but the PCB itself looks identical) so I thought that'd warrant a new thread.
It's my dad's old monitor. He...-
- Loading...
