Samsung 305T Plus black screen
    Re: Samsung 305T Plus black screen
    See the specheet of the MOSFET 4614:
    Check Source and Drain pins.
    https://cdn.badcaps-static.com/pdfs/...df367ff0cc.pdf
    • andrew1
      • Mar 2013
      • 32
      Let's see. So I have to measure pins:
      1-5 / 1-6
      3-7 / 3-8
      (2 MOSFET from LEFT to RIGHT) short S2 - D2 pins / S1 - D1
      This is definatelly bad.
      (6,7, 9, 10 MOSFETS) "1 aka OL" S2 -D2 at first trial but will charge after a few attempts to measure them.
      Last two MOSFETs (9, 10) - first time I got short only between S1 - D1.
      After a few trials I found out that last two give me a few readings.
      0.72 / 0.450/ 0.470 / 0.270 / 0
      Picture attached.
        Put meter in 200 oHms scale and see if it show real low Ohm. When semiconductor shorted out, it will be just like reading low Ohm resistor, no need to use Diode mode for testing them.
        So many MOSFETs are on that board?
        • andrew1
          • Mar 2013
          • 32
          budm. I think so, alot of them, all in the first row have the same code.
          Tried your method with 200 Ohms scale.
          Now it show "1" everywhere with one exception - 2nd MOSFET. The one I was sure it was bad.
          Can you verify if these are the right pins?
          1-5 / 1-6
          3-7 / 3-8
          Thanks.
            If just one is shorted it, I would not think it will blow both fuses since they are separated from each other.
            I would order a bunch of the MOSFETS for now and replace the shorted oout one.
            • andrew1
              • Mar 2013
              • 32
              So we have two fuses / one MOSFET but the main problem is not yet found. I will replace that mosfet later...for now let's move on to the next step.
              I want to ask you a question. How we found out that we have a short circuit in the inverter? Is because I got a short between ground and one end of the fuses? or is just because these bad fuses show an increase in current after...not before them. I wonder what would happen if I connect the mainboard to the inverter and measure the ohms between mainboard ground and the other end of the fuses. Make sense?
              • Lumberjack777
                • 464
                #27
                OK Andrew. You don't have to do that. The reason we suspected the inverter was out was because the backlights were not lighting up. A short on the mosfet will cause the fuse to blow. I'd just do what budm suggested and buy a couple fuses. And buy a few mosfets. That should be all you'll need to get fixed up. It's just a matter of if it was a single mosfet that went out, or another one somewhere. This is a common repair in inverters. Mosfets and fuses.
                  Just make sure that you have really verify all the MOSFETs real well since it still does not make sense why the other fuse that feed the other set of MOSFETs which shown as tested OK had blown the fuse.
                  Make sure there is not hidden MOSFET under the white glue.
                  Those yellow caps should also be replaced at the same time.
                  By the way:
                  "Can you verify if these are the right pins?
                  1-5 / 1-6
                  3-7 / 3-8"
                  This is how the pins are setup:
                  Pin 1 (dot) =S2
                  Pin 7~8 = D2
                  Pin3 = S1
                  Pin 5~6 = D1
                    OK, I look at the inverter transformer drive circuits setup.
                    There are 5 sets of transformer drivers.
                    The set at both ends of the board uses one set of MOSFETS to drive one transformer, the other 3 sets have the transformer's primary windings connected in parallel and driven by one set of MOSFETS per two transformers.
                    I would inspect the two MOSFETs on the right side of the board since it is setup the same as the set on the left side of the board that has shorted MOSFET.
                    • andrew1
                      • Mar 2013
                      • 32
                      By the way:
                      1-5 / 1-6
                      3-7 / 3-8"
                      Pin 1 (dot) =S2
                      Pin 7~8 = D2
                      Pin3 = S1
                      Pin 5~6 = D1
                      Hi budm. Thank you for corections. I forgot how to read pin order but multimeter was used the right way.
                      Now that you're mention there is something strange with those two MOSFETs on the right side (S1/D1 only). If you see the last picture I got a few random readings . In 200ohm mode everything is fine "1" but if I switch to diode mode and I measure them a few times at some point I get "0". and if I go back to 200 ohm mode fast there is "0" also for a few seconds.
                      I just now measured S1/D1 in diode mode:
                      0.67
                      0.147
                      and last 0.532 which is the quite usual for other S1/D1 MOSFETS.
                      Both give me identical readings when the value change.
                      Another strange thing is that a couple of MOSFETs show "1" for S2/D2 in diode mode. "1" is to low I think.
                      Should I use the gate to charge/discharge the transistor first to get a good reading?
                        "1" on the meter means Over range.
                        • andrew1
                          • Mar 2013
                          • 32
                          Thank you all for your support.
                          Last question. How many MOSFETs should I buy. 2, 3 ,5?
                            Since it uses 5 pair (10 pieces to make it worth shipping charge), I would oder 10. You should replace them in a pair, since when one shorted out it may have weaken the other one. Make sure to replace those 6 yellow caps at the same time, get PANASONIC FM/FR/FC series.
                            • andrew1
                              • Mar 2013
                              • 32
                              I bought everything I need but I have to wait two weeks. I'll keep you posted
                              • Lumberjack777
                                • 464
                                #35
                                Thanks Andrew. Please do! It gets frustrating when some of the techs spend so much time volunteering to help a person. The person get the parts. Fixes it. And we never hear from them again, or even know if it was fixed. And another person comes along with a similar problem; reads the thread, and has no idea what fixed the problem.
                                Make sure to get those caps like budm mentioned. What probably happened was the caps started going high esr. That caused the mosfets to short out. Which then caused the fuses to blow. By replacing all 3 types of parts the repair will most likely last.
                                • andrew1
                                  • Mar 2013
                                  • 32
                                  Still doesn't work. Was tested a few seconds. Fuses are ok but I don't want to try again. Maybe I should find a service.
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    #37
                                    Are you sure you have it all connected up? Check all the cables.
                                    Are the fuses still ok on the inverter and with a source connected can you
                                    see anything on screen. Did it make any pops or ticking is the power light on.
                                    Check you put the caps in the right way round - it does happen
                                    • andrew1
                                      • Mar 2013
                                      • 32
                                      I realised that I can't do it by myself...mosfets have 8 pins and I need a heat gun to change them. Everything was done in a service. I told the guy from there to change caps and mosfets but he said one mosfet is bad...and the rest are good. When I went home I saw the same problem...so I decided to let him take a look at SMPS, MAIN & INVERTER. Maybe the problem is not so simple...or he did a mistake by not changing all four mosfets and caps...not sure. Anyway I don't have any experience and is to complicated for me. Maybe there are some bad rezistors or caps on the mainboard to.
                                      • selldoor
                                        Slow Learner
                                        • 7870
                                        #39
                                        Mosfets nearly always should be changed in pairs or groups and as it was suspected the caps caused the problem with the mosfets ( at least two of us
                                        said they should be changed) then they should have been changed. Did the service not have the whole set to test the board after their work?
                                        • andrew1
                                          • Mar 2013
                                          • 32
                                          Yesterday I took with me only the inverter. But after I saw the same problem I went back with the other two boards (SMPS and MAIN). They can't do a full test...I called an hour ago and they have no clue about the problem. BTW is not a certified service or anything. Maybe you still can help me find the problem. I'm thinking if both fuses are blown...the problem should be with the inverter or maybe CCFL lamp? Thanks.
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • HTR-Informatique
                                            by HTR-Informatique
                                            02-09-2025, 06:51 AM
                                          • withalligators
                                            Yet another Samsung 305T post - black screen w/backlight, occasionally works
                                            by withalligators
                                            Hey folks,
                                            I picked this neat monitor up from a recycling center years ago, and it worked fine for a long time. I know they are prone to T-con issues with the Altera chip, but I've yet to experience any symptoms of that going. I always perform scaling on the GPU though. It had occasionally thrown a black screen at me, that was usually reset by powering it off, and reseating the DVI-D cable in the sole input. I gave it to my brother who said the problem got worse, and it would be very difficult to get it to display a picture, it took lots of fiddling. As far as I understand him, it always...
                                            03-25-2022, 11:24 AM
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • totof
                                            Samsung UE50KU6070 black screen
                                            by totof
                                            I have my TV model UE50KU6070 which I am trying to repair.
                                            BN41-02528A / BN94-10800C motherboard.
                                            If I disconnect the motherboard from the power board, the backlight works. When the motherboard is connected the backlight works but the screen remains black.
                                            When I plug the TV into the electrical outlet, the standby LED lights up but no reaction to an attempt to start it with the remote control for about 1 minute. During this minute the TV consumes about 20W.
                                            After one minute the consumption drops to 0W and the TV can turn on with the remote control but...
                                            09-26-2022, 02:34 PM
