Samsung 305T Plus black screen
  • andrew1
    • Mar 2013
    • 32
    The power led works but nothing is hapening. if you listen carefully there is a very faint high pitch two tones noise from the back of the monitors after a few seconds. From what I know this monitor start a self test when not connected (alternating RGB colors). Maybe the noise is normal when he does this...but the screen doesn't show anything. Thanks.
    Re: Samsung 305T Plus black screen
    Did you open up the unit to inspect components yet? Pictures?
    • andrew1
      • Mar 2013
      • 32
      Hi budm and thank you for your quick answer. At first glance caps look ok. I will post pictures tomorrow. Could be the tcon board itself? or this is not the usual symptom. Someone did a reflow earlier for altera chip...that's the only thing I saw until now.
      • Lumberjack777
        • 464
        Andrew. What you can do is get the monitor into a dark room. Turn on the monitor, and shine a flashlight on the screen from different angles. See if you can see a faint video image. If so, that means the video is ok; and we can focus on the inverter section and the backlights. That would help narrow it down a lot. And Budm and the others could get you fixed up a little faster. And pictures too like he asked. Thx
        • andrew1
          • Mar 2013
          • 32
          Hi Lumberjack777. Something does happen I'm not sure what...the flashlight spot seams to increases a little when I hear the hi pitch noise and then at the low pitch noise is lowered somehow. I don't see any colors though. I don't have a DVI cable to test it on a PC...but I ordered one this week (tomorrow will arrive).
          • Lumberjack777
            • 464
            Ok Andrew. I don't think I explained it well the first time. My apologies. The way an lcd monitor works is that you have the video going on inside the thin lcd screen. There are thin flourescent lights behind it (ccfl's). They light the video up from the back side. So when you say you have a power led on. And a black screen. I'm thinking maybe the video is there. But the lights behind it are not shining through. By shining the flashlight on the screen you are looking for faint images of the video that is there; but not illuminated by the backlights. Sometimes you can barely see it. That's why you need to look for that video image with a flashlight. Try shining it from different angles. Then you'll need to open it up like Budm mentioned and get some pics.
            • andrew1
              • Mar 2013
              • 32
              I understand what you said. I tried again with a brighter light source. The entire screen seams to have two stages. At least that's what I can see. Gray and black again. Without a light source I can't see anything...so obvious if the backlit does nothing...screen pixels are responsible for this. I will post the pictures tomorrow. Thanks Lumberjack777, you really helped me alot today
              • selldoor
                Slow Learner
                • 7870
                Without a source connected ,as I believe you said you dont have a connector then it may be there is nothing to see - maybe a no signal message might flash on but hard to spot. Give it up until you get a cable
                • andrew1
                  • Mar 2013
                  • 32
                  Ok. I got the DVI cable and did another test with a PC attached. No backlight confimed. I can see the desktop now. I have a soldering gun and a cheap multimeter so let's do it.
                  • selldoor
                    Slow Learner
                    • 7870
                    ok start easy - on the inverter there are at least 2 fuses small white
                    Power OFF Meter on ohms 200 one probe to each side of fuse.
                    In Pic 1 - Power supply in the middle near the legs for the BIG cap there is a green fuse.
                    Same test as above.
                    Main board pictures are not good enough too dark and out of focus
                    • andrew1
                      • Mar 2013
                      • 32
                      Same test as above.
                      Hi selldoor.
                      powersupply - The green fuse is good.
                      inverter - I found two white rectangular devices with silver endings (there is a text on the motherboard pointing to them [5A/125V]. I don't get any readings. (tried both diode and 200ohms methods).
                      New motherboard pictures:
                      • selldoor
                        Slow Learner
                        • 7870
                        Yes those are the fuses.
                        There is no such thing as "no readings" unless your meter has died and you have a blank
                        screen on it.
                        We would expect your meter to read 0.00 or close (is that what the green fuse read)
                        OR it will display a 1 or OL on the left hand side of the meter?
                        On the main board near the B sticker there is a Green rectangle with X20 on it.
                        That is a re-settable fuse- measure the same as before meter on ohms 200.
                        • andrew1
                          • Mar 2013
                          • 32
                          screen on it.
                          Sorry...I mean "1" - so those fuses are bad.
                          X20 - good.
                          Thank you for helping me selldoor .
                          • selldoor
                            Slow Learner
                            • 7870
                            Yes.
                            They are not that easy for many people to get hold of and postage makes them
                            quite expensive.
                            If you are very careful (for test purposes only)you can get away with 5A Car fuses, Well Insulated and wired up. You can solder them
                            to the existing fuses, saves wear on the board.
                            When you get the proper fuses they can also be piggybacked on top of the old fuses, again it seems easier to solder and saves making an error on the board.
                            • andrew1
                              • Mar 2013
                              • 32
                              Yes.
                              quite expensive.
                              5A is the nominal fuse current? or the breaking capacity. I found something with 5A In / 8A breaking capacity.
                              Waiting the next step. We have to find the reason why these fuses had to stop the current. There are two of them so I think is not a coincidence.
                              Service Manual attached.
                              • selldoor
                                Slow Learner
                                • 7870
                                You are correct but I suspect it will be very difficult to trace.
                                What I suggest is you set your meter on ohms 2000 and test from each side of each fuse to ground. (if it goes to "1" move up the range)
                                These fuses are often rated quite close to the amps on the board so they do blow quite frequently. I am wondering if they have been put under extra stress
                                as the caps are Samyoung so may well be shot ( are only reckoned to be mediocre at best. I cant tell from the picture if they are bulged at all - inspect them .Perhaps replace them whatever.
                                • andrew1
                                  • Mar 2013
                                  • 32
                                  ground connection test.
                                  Both fuses have one side connected to the ground. The other end is "1" with any scale.
                                  I can go to a professional service if you think that we can't trace the actual problem like this. Or you can let someone else continue what you started if you got tired...no problem. I really enjoy working at this project. Would be nice to do it myself if can be done. I have a diploma in electronics but I never repaired something all I can do is try to follow directions.
                                    I can see at least 10 MOSFETS that drive the inverter transformers, they should be check for Source to Drain short.
                                    We need good close up pictures of the inverter board.
                                    • Lumberjack777
                                      • 464
                                      So the white fuse on the left side of the inverter board is out. And the white fuse on the right side is out too? In my experience bad caps or a bad mosfet will only take out one fuse. The side that has the bad cap or mosfet. I wonder what would take out the fuses on both sides?
                                      Andrew, can you test them both again and make sure they are both out. Thx.
                                      And test those mosfets and get some good pictures like budm asked. As soon as we can determine what caused the fuse(s) to blow. We should be able to get you fixed up. I love fixing electronics and bringing these dead monitors back to life. Hope you do too
                                      • andrew1
                                        • Mar 2013
                                        • 32
                                        Lumberjack777. Both are out. I tested them a few times. I even tried to scratch the surface in case someone applied some transparent resin there. This monitor was good a few weeks ago not sure what happened. If we don't have any luck I will call a repair centre but for now I want to learn some basics about electronics and this is the best forum I found around the internet
                                        One more thing: I don't know how to test those mosfets. If I recall was something like: pin 1-2 ,2-8, 4-5 can you explain the whole task and multimeter settings?
                                        Pictures attached.
                                        Correct order from left to right (first four pictures, in order)
                                        jpg names: <--- leftside, second, third, rightside --->
                                        You can see better the numbers on the mosfets in the other pictures. closerview1, closerview2...and so on.
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • HTR-Informatique
                                          by HTR-Informatique
                                          02-09-2025, 06:51 AM
                                        • withalligators
                                          Yet another Samsung 305T post - black screen w/backlight, occasionally works
                                          by withalligators
                                          Hey folks,
                                          I picked this neat monitor up from a recycling center years ago, and it worked fine for a long time. I know they are prone to T-con issues with the Altera chip, but I've yet to experience any symptoms of that going. I always perform scaling on the GPU though. It had occasionally thrown a black screen at me, that was usually reset by powering it off, and reseating the DVI-D cable in the sole input. I gave it to my brother who said the problem got worse, and it would be very difficult to get it to display a picture, it took lots of fiddling. As far as I understand him, it always...
                                          03-25-2022, 11:24 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • totof
                                          Samsung UE50KU6070 black screen
                                          by totof
                                          I have my TV model UE50KU6070 which I am trying to repair.
                                          BN41-02528A / BN94-10800C motherboard.
                                          If I disconnect the motherboard from the power board, the backlight works. When the motherboard is connected the backlight works but the screen remains black.
                                          When I plug the TV into the electrical outlet, the standby LED lights up but no reaction to an attempt to start it with the remote control for about 1 minute. During this minute the TV consumes about 20W.
                                          After one minute the consumption drops to 0W and the TV can turn on with the remote control but...
                                          09-26-2022, 02:34 PM
