Benq fp71g+ dead. No light no signs. Capacitors look alright
  • Rtech
    • Jul 2010
    • 1095
    Re: Benq fp71g+ dead. No light no signs. Capacitors look alright
    Never seen one glued,,there will be a little pin on each end probably going through the Board and soldered !!
    • sabre504
      • May 2010
      • 449
      • United Kingdom
      On Q601 you don't need to remove the heatsink just undo the screw leaving the heatsink in place
      Sorry to butt in
      • nicoursi
        • 17
        • Italy
        Eureka! Thank you very much! The heatsink is glued, but thye mosfer is not. It was enough to unscrew the mosfet and voila!
        So, testing it again with the multimeter i get:
        a) black probe on pin 1 and red probe on pin 2 - 1 ohm
        b) black probe on pin 1 and red probe on pin 3 - 1 ohm
        c) black probe on pin 2 and red probe on pin 3 - 1 ohm
        I assume the mosfet is dead?
        Without unsoldering i get the same with IC702. Should I unsolder IC702? What other tests should I run?
        • Rtech
          • Jul 2010
          • 1095
          Mosfet has gone short circuit,so you need to measure all the resistors in that area,particularly the one that is Red Red Silver Gold...which should be 0.22Ω.Also test D602..IC 702 take out and measure AND advise the part code...suspect that this regulates the 5V supply when you are back up and running.
          • retiredcaps
            • Apr 2010
            • 9271
            Read the multimeter and mosfet section at
            https://www.badcaps.net/forum/showpo...4&postcount=19
            Then recheck your readings to see if it is really 1.0 ohms or not.
            --- begin sig file ---
            --- end sig file ---
            • nicoursi
              • 17
              • Italy
              #26
              retiredcaps: all the mesurements i have done are according to the multimeter and mosfet section. That's the first thing I read
              When I join together red probe and the black one i get 00.3 ohm
              so here the mesurements:
              R607 (Red Red Silver Gold): 1 ohms;
              R615 (Red Red Silver Gold): 0.5 ohms
              R625 (Red Red Silver Gold): 99.3
              R609: 1 ohm
              R608: 1 ohm
              D601: 1
              D602: 1
              L605: 0.03
              L604: 0.03
              L608: 0.03
              R611: shows some big numbers for a sec and then 1
              R702: 00.9 - 01.0
              R821: 1
              R819: 1
              I didn't take out IC702 yet, but its part number is: KA 431AZ G32
              Is it possible that so much stuff got burnt? And what could have caused all this? I mesured many times to make sure.
              • Rtech
                • Jul 2010
                • 1095
                #27
                Wow........R615 should be 0.22Ω,
                R607 should be 69KΩ IF it is Blue, White,Orange,Gold ??
                R625 should be 2KΩ IF it is Red, Black, Red, Gold ??
                I cannot see properly the colours for R611,702,819 and 821,so unable to advise...You must take one end of EACH of the resistors out and remeasure them all..you need to advise the colours for each as well,BECAUSE R607 IS NOT Red,Red,Silver,Gold as you state above.
                The 'L' components indicate inductors,and they measure OK.
                D601 and D602,again take one end out and remeasure, each one needs 2 readings on resistance..one with the Black lead from your meter on one end and the red on the other, THEN reverse the leads and get the second measurement.The KA 431AZ, does regulate the 5v as advised,and again that needs taking out.
                NOTE,,Ref your meter IF you put the two leads together the meter should read approx zero, this is on resistance...IF the leads are NOT connected together does the meter read '1' or '0' ???
                • nicoursi
                  • 17
                  • Italy
                  #28
                  so this is the situation:
                  R611 - red,red,brown,gold -216 omh -->ok
                  R607 - blue,silver, orange, gold - 68.2 -->ok
                  R603 brown,silver,orange,gold - 17.72 -->ok
                  R625 orange,black,orange,gold -->00.1 omh (!!!) -> UNSOLDERED
                  R615 red,red,silver,gold -->00.6 omh (!!!) -> UNSOLDERED
                  R702 blue,gray,silver,gold -->00.9 omh (!!!) -> UNSOLDERED
                  D601 -->67.7 and 68.2 (with inverted polarity) UNSOLDERED
                  D602 -->.856 (multimeter to 2K); big number then 1 with inverted polarity UNSOLDERED
                  R608 and R609. I couldn't understand how to read the colors.Is it yellow,yellow,purple, gold OR yellow,purple,gold,gold? Anyway with multimeter set on 2M i get a rising never settling value that goes from 0.300 to 0.500. It rises one unit at a time. Example: 0.301,0.302,0.303 etc.
                  R819 and R821 orange,black,green,gold I couldn't test because my multimeter doesn't go over 2M.
                  Suggestions?
                  • nicoursi
                    • 17
                    • Italy
                    #29
                    I just tested the transformer T601 and I am afraid there is something wrong with it too
                    To test it i followed the instructions here: https://www.badcaps.net/forum/showthread.php?t=10419
                    So, black pin on 1, red on 2 , and so on (multimeter set on 2k and 200):
                    pin 1 - pin 2-->00.4 ohm
                    1-3-->00.4
                    1-4-->a big number then 1.
                    1-5-->a big number then 1.
                    1-6-->1. nothing happens
                    1-7-->1. nothing happens
                    1-8-->1. nothing happens
                    1-9-->1. nothing happens
                    1-10->1. nothing happens
                    2-3->00.4
                    2-4->nothing happ
                    2-5->1. nothing happens
                    2-6->1. nothing happens
                    2-7->1. nothing happens
                    2-8->1. nothing happens
                    2-9->1. nothing happens
                    2-10->1. nothing happens
                    3-4->1. nothing happens
                    3-5->1. nothing happens
                    3-6->1. nothing happens
                    3-7->1. nothing happens
                    3-8->1. nothing happens
                    3-9->1. nothing happens
                    3-10->1. nothing happens
                    4-5->00.4
                    4-6->1. nothing happens
                    4-10->1. nothing happens
                    5-6 ->1. nothing happens
                    5-10->1. nothing happens
                    6-7-->nothing
                    6-8-->00.4
                    6-9-->00.4
                    6-10-->00.4
                    7-8->nothing
                    7-9->1. nothing happens
                    7-10->1. nothing happens
                    8-9->00.4
                    8-10-->00.4
                    9-10-->1. nothing
                    What should i do next? Please help. Is it still worth fixing this board? Thank you for any help!
                    • selldoor
                      Slow Learner
                      • 7870
                      #30
                      Hi - I will have to llok all through this to see where you are up to but I think you have tested T601 Using a test which is ONLY for Inverter transformers.
                      You can really only test T601 with special equipment.
                      To save you the hassle I have marked the attached pic with what I beleive are the
                      secondary winding pins. POWER OFF Meter on 2000ohms test s1 to s2 and s3 to s4
                      Going back to when you tested a mosfet and came up with 1 ohm on each test did you
                      check that it really was 1 ohm or was it 1 on the left of your meter meaning off scale?
                      ( I think that was what retired caps was hinting at when he asked you to read his guide)
                      • nicoursi
                        • 17
                        • Italy
                        #31
                        Thanks for answering. So:
                        S1 to S2 -->.377
                        S3 to S4 -->.378
                        About the mosfet, yes it is offset. Sorry for confusion I get the 1. on the left no matter where i set the multimeter at.
                        So these ones are the results for mosfet Q601 again:
                        pin1 to pin2-->offset
                        pin1 to pin3-->offset
                        pin2 to pin3-->.906 ohm (multimeter set to 2k)
                        Does this still indicate a shorted mosfet?
                        What can you tell about resistors R608 and R609? I couldn't understand how to read the colors.Is it yellow,yellow,purple, gold OR yellow,purple,gold,gold? Anyway with multimeter set on 2M i get a rising never settling value that goes from 0.300 to 0.500. It rises one unit at a time. Example: 0.301,0.302,0.303 etc.
                        • selldoor
                          Slow Learner
                          • 7870
                          #32
                          Mosfet looks NOT shorted - test again off board if that is on board.
                          Have you tried here
                          http://www.hobby-hour.com/electronic...calculator.php
                          Yellow purple gold gold = 4.7ohms
                          yellow yellow purple gold = 440 Mohms - Unlikely value
                          Have you no others the same on the board to compare
                          Try cleaning them see if the colours come up better.
                          • nicoursi
                            • 17
                            • Italy
                            #33
                            So this is the resume of the situation and I don't know what to do now:
                            tested all resistors and found three of them with bad readings (R603, R607, R611 test as they should):
                            tested for resistence mosfet Q601 (part number: K3530):
                            black on S,red on D= no readings
                            black on S, red on G=no readings
                            black on D, red on G= .901 (set to 2k)
                            the resistor has been taken out of board. I don't know if I should consider this mosfet Ok or not.
                            tested for resistence transistor IC702:
                            black on S,red on D= .999 (set to 2k)
                            black on S, red on G=1.002 (2k)
                            black on D, red on G= 17.29 (set to 20k)
                            This means the transistor is ok?
                            tested resistors R608 and R609. they are both yellow violet yellow gold (I had some trouble to understand the colours of these ones, I hope it is the right one!) and I get a strange reading. With multimeter set on 2M I get a rising never settling value that goes from about 0.200 and can get up to 0.400 or maybe more. It rises up one unit at a time so it takes a while.
                            How should I consider this resistor? In bad shape, so replacement needed? They both (R08,R609) act similarly.
                            tested this:
                            These are the readings i get:
                            S1 to S2 -->.377
                            S3 to S4 -->.378
                            Thank you for any guidance!
                            • selldoor
                              Slow Learner
                              • 7870
                              #34
                              Not sure what happened here I must have missed the reply
                              Those readings are good
                              • seppde
                                Benq Zowie XL2540K / Power board failure / 6Pin-SOP-Chip identification
                                by seppde
                                I've got a Benq power board of a XL2540K monitor which suffered from a power cut and is since defective / won't turn on. It's got obvious defects, some blown resistors, some burning around the drain pin of a MOSFET...
                                ... and some 6-pin IC I struggle identifying, that is driving said MOSFET.
                                The IC is labeled as IC601, so someone with a circuit schematic could probably identify it really quick, unfortunately I can't find the schematics.
                                In other power boards of Benq for which I did find the schematics, IC601 is an 8-pin NCP1200 PWM controller - I suppose...
                                02-09-2024, 05:19 AM
                              • AJ847.63e
                                BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
                                by AJ847.63e
                                Hi All.
                                Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
                                The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
                                09-18-2023, 06:42 PM
                              • KYBOSH
                                Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
                                by KYBOSH
                                I picked this one up today.
                                Previous owner says no signs of life.
                                TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
                                Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
                                The TV model is QN65LS03BAFXZA - version: CB06
                                The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
                                I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
                                Will keep you all...
                                04-05-2025, 08:32 PM
                              • ChatBTC
                                Benq EX3501R
                                by ChatBTC
                                Hi!
                                I am new to this site, and found it via LLM ChatGPT.
                                I got a BenQ Ex3501R monitor which i have had for a while now, it works pretty good until recently, it struggles to turn on, i can see the purple welcome screen is shown for a brief time before it vanish again, usually it stays on for a couple of seconds before the main computer screen is shown, but image is still kept black, before i just had to turn it off and on a few times and that would leave it on, but now it takes ever longer to stabilize the image on the screen, ocasionally i can see the computer desktop...
                                01-24-2025, 08:49 PM
                              • tranquility
                                HP EliteBook 850 G5 without signs of life
                                by tranquility
                                hello, i have a problem with HP EliteBook 850 G5
                                shoring no signs of life. led near charging port and on/off button are off.
                                board it taking just a few mA..i think it was 10mA
                                i measured some things but i don“t find anything
                                the ACOK ? pin 24 FRWPG (pin 24) am ISL9538h is low with 0V
                                but i dont know why
                                i cant really understand what the mosfets in the pictures are doing for crazy things.
                                i measuered voltage on coils....but now on mosfets near the coils too and they all had more than 10v i think one was there with 8v or something....so...
                                12-02-2024, 05:57 AM
