HP W1907V Squealing
+ More Options
Posts
  • spleenharvester
    • Mar 2010
    • 902
    Re: HP W1907V Squealing
    Hmm. At £7~ a bottle I'm probably better off just buying another board.
    Ah well.
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
    • Rtech
      • Jul 2010
      • 1095
      #42
      Will PM you ref Board.
      • Hondaman
        • Sep 2008
        • 1061
        Quick question -- how did you get it apart? I saw a Youtube video (in Spanish), and I can see how the front bezel comes off. But it looks like my hands aren't strong enough.
        (I can get the top and bottom loose, but not the sides.)
        Did you use any metal instruments to pry under the front bezel? Are there any tricks that I don't know?
        I just want to get the previous owner's nicotine out of it.
        Any help appreciated.
        EDIT: Got it apart. Pried the sides with my fingers until I got a thin refrigerator magnet between the bezel and the panel. Then used a 1.5-inch (37mm) putty knife to pry. Wow that was hard.
        • Hondaman
          • Sep 2008
          • 1061
          Can't edit anymore. Got it apart, put it together, picture is all messed up. Probably a panel problem. Too bad, I really liked this monitor.
          • selldoor
            Slow Learner
            • 7870
            #45
            Ah well.
            If you have really given up on it you could try filling it with superglue
            I have heard of people doing that-dont know if it would work but it would be a good experiment.
              Silicone RTV, Epoxy?
              • spleenharvester
                • Mar 2010
                • 902
                Yeah the bezel was horrible to get off, I damaged a big strip of plastics, nothing double sided tape can't repair tho.
                Was it messed up to begin with? It could be that the video cable has just come loose during reassembly. Check it's pushed in all the way, I made the same mistake.
                As for my own problem - would that surely cause some sort of overheat? I might give it a try but I'm probably buying a board anyways.
                • spleenharvester
                  • Mar 2010
                  • 902
                  Just noticed the solder joints are on the bottom and look quite easy to get at, tempted to give it a try. How easy is it to lift off, and how big is the shock risk? Think I'll need to cover the rest of the board in antistatic material.
                  I thought it was some crazy big SMD component originally.
                  EDIT: Sod it just remembered the price of the varnish lol.
                  • selldoor
                    Slow Learner
                    • 7870
                    #49
                    Im assuming your going to unsolder it with it switched of ha.ha.
                    If its been off for half an hour shock probability is probably nil but just to make sure you can test voltage across the big cap - meter on 600vDC or more. Should just have a residual perhaps 5 vdc or less. If its more you can discharge by connecting a light bulb across it.
                    No need to bother about static.
                    I start by heating the whole area gently with a hair dryer - saves the heat from the iron all being leeched into the board.Find a few different sized things that you can use as levers that will fit into the area - I use a set of watchmaker screwdrivers credit cards plastic knives but remember that underneath the wire is exposed so dont damage it. Stick to the edges.
                    Start on the easiest end pin to get at and just get the solder to melt and remove as much as you can with soldermop.
                    insert your smallest wedge in the small gap between board and transformer then melt the solder again easing in and up on the wedge tool you are working in terms of o.5mm or less at first. leave the wedge in and
                    heat the next pin insert a wedge and so on - I only leave one wedge in place so use the first wedge for the 3rd pin. This is not a job you can do in a hurry - too much pressure and you can crack the body of the inverter.
                    As this is your first I would plan on taking an hour then if you do it in 30mins you will be well pleased. If you think it will take 10 minutes you will get frustrated with it after 15.
                    Its not as hard as it looks though it is easier if it is a faulty one then it doesnt matter if it gets more damaged.
                    EDIT You my find it easier than it sounds - if you can clear most of the solder off the pins it sometimes doesnt take much to get it to release from the holes
                    • spleenharvester
                      • Mar 2010
                      • 902
                      Thankyou very much for that information, was always told monitors were extremely high voltage and could retain charge for a long time, been handling the board with high voltage gloves!
                      I think I'm just gonna leave it and buy another lol. My only worry is if I buy a used board and the seller can't hear the squeal - my brother who's a couple years older than me can't hear the noise due to natural hearing loss etc etc. Then I'm back at square 1.
                      The bottle of Lacquer is £8 or so and a new board is £14 or so so I think it's a better option.
                      • spleenharvester
                        • Mar 2010
                        • 902
                        Also a follow up question about measuring the transformer - can someone confirm to me how to do it?
                        I have my multimeter set to 2kOhm, and measuring the secondaries again reads 749 on one and 649 on the other, but only very very briefly before it dips to 003, so I think I'm doing it wrong.
                        • Rtech
                          • Jul 2010
                          • 1095
                          #52
                          There are 8 Pins,ignore the 4 centre ones and measure the other pairs on the end.
                          • spleenharvester
                            • Mar 2010
                            • 902
                            That will be why, I was measuring at the center. Ends both sides measure in at 568 ohms
                            • selldoor
                              Slow Learner
                              • 7870
                              #54
                              my only worry is if I buy a used board and the seller can't hear the squeal - my brother who's a couple years older than me can't hear the noise due to natural hearing loss etc etc. Then I'm back at square 1.
                              Earplugs 30p
                              • spleenharvester
                                • Mar 2010
                                • 902
                                Hahaha, doubt even earplugs could handle this one :p
                                Also thank you all for your help on this, you're all total geniuses, It's pretty crazy.
                                • madisonman
                                  • Nov 2012
                                  Hi I have almost the same problem. I have the squealing without blubs hooked up for about a second or two. Inverter checks out at each end at. (.562 ohms) Will buzz for about 5-8 seconds then go to black if either one pair or both, either end are connected. http://www.lcdparts.net/Images/LIPS/PTB-1773.jpg This is my board.
                                  Help!!!
                                  • RetroComputingGrotto
                                    Viewsonic VA2010wb (High Pitch Squeal At Power On)
                                    by RetroComputingGrotto
                                    I've got a monitor on my workbench at the moment that makes a high pitch squeal (that I cant hear as my ears are too old) when you power it on and lasts a couple of seconds before quitening and apparently it can be heard at regular intervals whilst on.
                                    On opening up the monitor and looking at the PCB the usual suspects showed their heads so I have already replaced all the electrolytic capacitors.
                                    The other issue that was reported with this monitor was the fact it took ages to start displaying anything after pressing the power button.
                                    What component(s)...
                                    02-03-2025, 06:00 AM
                                  • JDC
                                    (SOLVED) - Funai FW55D25F - High Pitched Squeal Upon Power-on.
                                    by JDC
                                    Issue: Funai FW55D25F - High Pitched Squeal Upon Power-on.
                                    Solution: Replace C3208 and C3209 on main board. These are surface mounted capacitors. Values unknown so I just used same physical size capacitors from a donor board.
                                    02-01-2022, 10:25 AM
                                  • dcapper
                                    LN-32A550P3F No screen and squealing
                                    by dcapper
                                    The blue Samsung led in the center at the bottom lights up and the red power light blinks but no backlight. Then after a few seconds, it starts to squeal. I changed all the power supply caps even though they were not bulged. I metered the coils on the inverter board, and all reading fine. So I found another mainboard that I had. I installed it and went into the service menu to change it to the model I that I am working on. Well now the tv turns on, it doesn't squeal and I get video except the video is red. Is the tcon bad?...
                                    03-15-2020, 11:47 PM
                                  • neilc6
                                    Philips 40PFL4908 Power Supply Problems
                                    by neilc6
                                    Reported as TV not turning on and power supply squealing.
                                    Check all transformer output diodes and not shorted.
                                    Schematic and service manual in this thread https://www.badcaps.net/forum/showth...ight=40PFL4908
                                    Disconnected power supply outputs and there is a very quick squeal when plugged in. AMP+13V and P-ON+21V measure half their expected output.
                                    Bridge rectifier diodes test ok. Fuse F602 not blown. Main switching transistor Q601 not shorted. Measuring 168V on drain (expecting 292V from schematic) so the input is half...
                                    05-18-2019, 01:30 PM
                                  • C152Heavy
                                    by C152Heavy
                                    Summary for TL-DR readers:
                                    • VCC pin (18) of PFC...
                                    01-11-2023, 02:53 PM
