HP W1907V Squealing
  • spleenharvester
    • Mar 2010
    • 919
    HP W1907V Squealing
    Hello!
    I bought a HP W1907V for 30 quid. Got it today. Absolutely beautiful monitor and "works" fine but there's a horrible squeal.
    There's seriously loud rattling/buzzing sound from one area and a really high pitch whine from another.
    Does this sound like a badcapped case? Its brother, the W2207, seems to be a known badcapped monitor. So I can't help but wonder.
    I've been trying to get the thing open for half hour.
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • spleenharvester
    • Mar 2010
    • 919
    Re: HP W1907V Squealing
    Okay, some update on this. I've got the thing open. The power board is a PTB-1773, the same type as used in the HP W2007.
    All caps look fine visually. I'm pretty sure the squeal is coming from the big rectangular component near the inverter connections :/ where does it look most likely to be coming from?
    This one:
    http://www.lcdparts.net/Images/LIPS/PTB-1773.jpg
    • Rtech
      • Jul 2010
      • 1095
      This one:
      Disconnect the lamps from the 4 sockets on the board, and then switch it on ????/
      • spleenharvester
        • Mar 2010
        • 919
        Just did, it's completely silent without them.
        • Rtech
          • Jul 2010
          • 1095
          The Power supply on these models are excellent, and 95% of faults are caused by problems with the backlights and or the wiring to them,normally the top backlight being the culprit.Have you got a test lamp ??//to find if the problem is top or Bottom.Try putting in the Top pair only and see what happens ?? and then the bottom pair only ??, the lamps will only go on for a short time,but may give you an indication where to go next.
          • spleenharvester
            • Mar 2010
            • 919
            No test lamp unfortunately. But I tried the top pair and the bottom pair separately and the hiss comes from the transformer in both tests.
            • Rtech
              • Jul 2010
              • 1095
              Then measure the Resistance of the secondaries on the transformer,if I remember correctly they should both measure about 630Ω, but both must be very close to each other.
              • spleenharvester
                • Mar 2010
                • 919
                They are both very close to that indeed :p
                • selldoor
                  Slow Learner
                  • Dec 2010
                  • 7870
                  If the leads are long enough try swapping the top light leads and bottom light leads where they plug into the power board
                  • spleenharvester
                    • Mar 2010
                    • 919
                    They don't seem to be unfortunately! Cheers
                    • spleenharvester
                      • Mar 2010
                      • 919
                      Found something interesting, if the PCB is flexed slightly (by wiggling AC plug or CCFL plugs) the frequency of the hiss changes. Dry joint somewhere?
                      • Rtech
                        • Jul 2010
                        • 1095
                        Up the Creek without a paddle then.....You need a set of test CCfl's,as the fault is either both lamps/wiring,OR the Inverter part of the Board,only a good pair of Backlights or a Good board, can eliminate which is the problem,suggest a visit to a 'tip' maybe and try for a broken Monitor, 15",17",or 19", as long as one set works.maybe even a wanted Ad on Freecycle or Freegle,if you have one of them, as i don't know what part of the World you are in ??
                        • Rtech
                          • Jul 2010
                          • 1095
                          If its a 'Hiss' then Backlights would be my preferred option.
                          • Rtech
                            • Jul 2010
                            • 1095
                            You could try re-soldering the Transformer and around that area.
                            • selldoor
                              Slow Learner
                              • Dec 2010
                              • 7870
                              Unlikely - does the screen look pink at all? it sound as though one or more
                              bulb or its wiring is wearing out putting the transformer under pressure by moving the board you just change slightly the physical pressure on the transformer.
                              One thing you might try is to resolder the all the transformer pins.
                              The ccfl leads may be long enough to swap if you turn the board over?
                              • Rtech
                                • Jul 2010
                                • 1095
                                You can try swapping the leads over, but from the tests you have already done,I would not think it will make any difference.
                                • spleenharvester
                                  • Mar 2010
                                  • 919
                                  Screen is literally perfect, as is rest of the monitor, aside from this hissing issue. Such a shame, it's an amazing monitor.
                                  Would it be worth just buying a replacement inverter board for ~£15 and seeing where it goes from there?
                                  Also, would a faulty backlight make a transformer hiss? The hiss is definitely coming from the transformer and nowhere else.
                                  • selldoor
                                    Slow Learner
                                    • Dec 2010
                                    • 7870
                                    Post good clear pictures of the back and front of the power supply - we may be able to spot something you have missed.
                                    • spleenharvester
                                      • Mar 2010
                                      • 919
                                      Yessir. Lemme know if they're not clear enough. http://imgur.com/a/xeZMO
                                      • Rtech
                                        • Jul 2010
                                        • 1095
                                        As I stated at the beginning 95% of faults are not the Board.I usually have one on Ebay, and then get people to test the backlights, and that is where the fault is.
                                        • kotel studios
                                          Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
                                          by kotel studios
                                          Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
                                          State I got it in:
                                          Squealing from the PSU
                                          After logo I get a blank screen
                                          After 10 seconds of having a blank display w/ backlight the TV dies
                                          Give it 7-10ish seconds again and it starts to bootloop.
                                          What I did so far:
                                          Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
                                          Checked all voltage rails:
                                          5VSB - 4.8V
                                          AMP+13V - 14.4V
                                          13V - 12.98V (in manual 12V)...
                                          09-21-2025, 02:00 AM
                                        • RetroComputingGrotto
                                          Viewsonic VA2010wb (High Pitch Squeal At Power On)
                                          by RetroComputingGrotto
                                          I've got a monitor on my workbench at the moment that makes a high pitch squeal (that I cant hear as my ears are too old) when you power it on and lasts a couple of seconds before quitening and apparently it can be heard at regular intervals whilst on.
                                          On opening up the monitor and looking at the PCB the usual suspects showed their heads so I have already replaced all the electrolytic capacitors.
                                          The other issue that was reported with this monitor was the fact it took ages to start displaying anything after pressing the power button.
                                          What component(s)...
                                          02-03-2025, 06:00 AM
                                        • JDC
                                          (SOLVED) - Funai FW55D25F - High Pitched Squeal Upon Power-on.
                                          by JDC
                                          Issue: Funai FW55D25F - High Pitched Squeal Upon Power-on.
                                          Solution: Replace C3208 and C3209 on main board. These are surface mounted capacitors. Values unknown so I just used same physical size capacitors from a donor board.
                                          02-01-2022, 10:25 AM
                                        • dcapper
                                          LN-32A550P3F No screen and squealing
                                          by dcapper
                                          The blue Samsung led in the center at the bottom lights up and the red power light blinks but no backlight. Then after a few seconds, it starts to squeal. I changed all the power supply caps even though they were not bulged. I metered the coils on the inverter board, and all reading fine. So I found another mainboard that I had. I installed it and went into the service menu to change it to the model I that I am working on. Well now the tv turns on, it doesn't squeal and I get video except the video is red. Is the tcon bad?...
                                          03-15-2020, 11:47 PM
                                        • neilc6
                                          Philips 40PFL4908 Power Supply Problems
                                          by neilc6
                                          Reported as TV not turning on and power supply squealing.
                                          Check all transformer output diodes and not shorted.
                                          Schematic and service manual in this thread https://www.badcaps.net/forum/showth...ight=40PFL4908
                                          Disconnected power supply outputs and there is a very quick squeal when plugged in. AMP+13V and P-ON+21V measure half their expected output.
                                          Bridge rectifier diodes test ok. Fuse F602 not blown. Main switching transistor Q601 not shorted. Measuring 168V on drain (expecting 292V from schematic) so the input is half...
                                          05-18-2019, 01:30 PM
