LN-32A550P3F No screen and squealing
  • dcapper
    • Dec 2013
    • 496
    The blue Samsung led in the center at the bottom lights up and the red power light blinks but no backlight. Then after a few seconds, it starts to squeal. I changed all the power supply caps even though they were not bulged. I metered the coils on the inverter board, and all reading fine. So I found another mainboard that I had. I installed it and went into the service menu to change it to the model I that I am working on. Well now the tv turns on, it doesn't squeal and I get video except the video is red. Is the tcon bad?
  • neilc6
    • Nov 2015
    • 1550
    Re: LN-32A550P3F No screen and squealing
    Search C102 in the forums since this cap on the main board can cause squealing and green screen.
    • dcapper
      • Dec 2013
      • 496
      But I replaced the main board and now I have a red screen. Should I find an old Samsung mainboard and replace C102 on the board I pulled out?
      • R_J
        • 9609
        It could be a mismatch between the main board and t-con, or it could be a service menu setting that is still wrong. Check the other settings in the service menu IE: LVDS OUT Format, Panel Option.
        The cap at location C102 is only on a certain main boards, not all of them.
        This thread has pictures of the main board and the model: https://www.badcaps.net/forum/showth...highlight=c102
        • dcapper
          • Dec 2013
          • 496
          I wish I knew what the original settings were. I'm going to look at some old Samsung mainboards I have laying around and change the cap on the original board.
          • dcapper
            • Dec 2013
            • 496
            Do these settings look right? Maybe I'm missing something.
              • 12307
              • U.S.
              Too hard to see the settings, it's sideways.
              • dcapper
                • Dec 2013
                • 496
                I know I'm trying to set it straight. Let me repost.
                  • 12307
                  • U.S.
                  Maybe the LVDS out format, make note of what it is now, see if you can change it, on some when you change it the picture clears up and you can see it right then.
                  • dcapper
                    • Dec 2013
                    • 496
                    I ended up doing Budm's mod on the original board from the other thread. The tv is working perfectly now! The only difference I see is the 32A CV vs. 32A C and Gamma .95 vs. .90
                    • R_J
                      • 9609
                      So are you saying that your main board DID have the cap at C102?
                      • dcapper
                        • Dec 2013
                        • 496
                        Yes the original one had the cap so I did the Budm mod. I tried replacing the mainboard originally with one I had but I got the red screen. I couldn't get rid of the red screen so I tried the mod and it worked.
                          Just for FYI about NEC Tantalum caps used on Samsung main board:
                          https://www.badcaps.net/forum/showth...sung+LN52A650A
                            • 12307
                            • U.S.
                            Oh, ok, I read it as neither of your boards had c 102.
                            • Ryan.man
                              by Ryan.man
                              02-04-2025, 12:23 PM
                            • kotel studios
                              Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
                              by kotel studios
                              Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
                              State I got it in:
                              Squealing from the PSU
                              After logo I get a blank screen
                              After 10 seconds of having a blank display w/ backlight the TV dies
                              Give it 7-10ish seconds again and it starts to bootloop.
                              What I did so far:
                              Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
                              Checked all voltage rails:
                              5VSB - 4.8V
                              AMP+13V - 14.4V
                              13V - 12.98V (in manual 12V)...
                              09-21-2025, 02:00 AM
                            • reformatt
                              by reformatt
                              07-31-2025, 08:37 PM
                            • smic717394
                              by smic717394
                              07-25-2024, 10:16 AM
                            • Chrissygizmo
                              by Chrissygizmo
                              02-10-2025, 12:33 AM
