(SOLVED) - Funai FW55D25F - High Pitched Squeal Upon Power-on.
  • JDC
    • May 2015
    • 273
    Issue: Funai FW55D25F - High Pitched Squeal Upon Power-on.
    Solution: Replace C3208 and C3209 on main board. These are surface mounted capacitors. Values unknown so I just used same physical size capacitors from a donor board.
  • nomoresonys
    • 12206
    • U.S.
    Re: (SOLVED) - Funai FW55D25F - High Pitched Squeal Upon Power-on.
    Good work, can you tell us how you figured out those two caps were the problem?
    • JDC
      • May 2015
      • 273
      Thanks for asking. I remember a long time ago I encountered a TV with a similar issue; it was a single solitary surface mounted cap that went out on a main board. I wish I could remember the model number but I do remember getting the answer here in the forums. I just got lucky in that I was able to troubleshoot the exact area instead of hunting for it. Hard to believe something so tiny can take out the entire TV.
      The whining sound would go away if I disconnected the main board from the power board.
      • nomoresonys
        • 12206
        • U.S.
        Ok, thanks JDC.
        • Michale32086
          FUNAI/SANYO FW55D25F Shuts Down Randomly
          by Michale32086
          I have Sanyo 55" TV that randomly shuts off..
          Sometimes it will stay on for 5mins or so, sometimes it shuts off after a min or two...
          When it DOES stay on, it works fine...
          All things being equal, would it be more likely a POWER Board issue or a MAIN Board issue???
          Thanx in advance......
          07-12-2022, 12:41 PM
        • Joho
          HP 255 G10 BIOS password / PowerOn password
          by Joho
          Hi!
          I've got a HP 255 G10 with unknown PowerOn / BIOS password
          Model: HP 255G10
          Product No: 853S9ES#ABD
          Serial: 5CD336QDVN
          Attached the dump.
          Is there a way to read out the password without reprogramming it?
          Anyways, any help is welcome ​...
          05-08-2025, 09:49 AM
        • RetroComputingGrotto
          Viewsonic VA2010wb (High Pitch Squeal At Power On)
          by RetroComputingGrotto
          I've got a monitor on my workbench at the moment that makes a high pitch squeal (that I cant hear as my ears are too old) when you power it on and lasts a couple of seconds before quitening and apparently it can be heard at regular intervals whilst on.
          On opening up the monitor and looking at the PCB the usual suspects showed their heads so I have already replaced all the electrolytic capacitors.
          The other issue that was reported with this monitor was the fact it took ages to start displaying anything after pressing the power button.
          What component(s)...
          02-03-2025, 06:00 AM
        • csmith
          Funai LC3200SSx Shutting Down
          by csmith
          This set won't power up with alternating green and red power light.
          Forced chassis on all voltages are correct except all 6V. It measures 28v.
          on cathode of D661. Anode measures 6v. Mainboard is BA94F0102 4_a.
          Schematic I'm using LC320MEM9 which is not close enough. Any suggestions
          from the Funai experts. Thanks!
          01-25-2023, 03:39 PM
        • NuclearSpartan
          Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
          by NuclearSpartan
          I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
          The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
          I don't see any other visible damage anywhere else on the board....
          11-14-2024, 02:32 PM
