HP W1907V Squealing
+ More Options
Posts
  • selldoor
    Slow Learner
    • 7870
    Re: HP W1907V Squealing
    I agree its probably bulb/s or wiring but its worth having a look. Dont recognise cap brand and they look ok but if the primary voltage to the transformer is dirty it wont help.
    Have you tried turning down the brightness - may reduce the sound and still be bearable to watch.
    • spleenharvester
      • Mar 2010
      • 914
      No change when adjusting brightness. The hiss gets quite loud from 70~90, though.
      Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
      • spleenharvester
        • Mar 2010
        • 914
        I do have a 1 CCFL 15" laptop display here, one connector with white and pink wires, it's an LTN150 something or other. Would I be able to test it on the inverter in place of the other CCFLs one by one?
        • selldoor
          Slow Learner
          • 7870
          Yes that is a good test ( may or may not prove anything as the difference in tube length may detract from the result) It may show up which bulb/wiring is bad
          • spleenharvester
            • Mar 2010
            • 914
            I shall give it a shot when I get back from town.
            Also, managed to flip the LCD round and did a test recommended earlier:
            Top CCFL in bottom sockets - hisses
            Top CCFL in top sockets - hisses
            Bottom CCFL in bottom sockets - hisses
            Bottom CCFL in top sockets - hisses
            • selldoor
              Slow Learner
              • 7870
              #26
              Hiss hiss - BOO!
              • spleenharvester
                • Mar 2010
                • 914
                Hehehe! Just reassembled it, oddly enough the noise isn't so bad now - it's still there, and it's still a pain in the ass, but it's not as loud.
                More accurate description - with a good listen, I wouldn't say it's a hiss now, it's a really high pitched whine with a quiet rattling sound to it (kind of like a hard drive?).
                Reading around, some places say it could be the coils vibrating, and to put something on to stop it vibrating. Should I try this? Is it even possible with this shaped component?
                EDIT: Also, wiggling the CCFL/power cable doesn't change the frequency anymore, so maybe I reseated something.
                • Rtech
                  • Jul 2010
                  • 1095
                  #28
                  Maybe,Still try the other backlight you had,and see if that makes a difference.
                  • spleenharvester
                    • Mar 2010
                    • 914
                    Just tried the other CCFL, no difference unfortunately.
                    • spleenharvester
                      • Mar 2010
                      • 914
                      Right, got the thing open on a test bench, big rectangular inductor chip is most definitely creating the noise here. Some slight whine coming from the coil next to the fuse but it's not really noticeable from afar.
                      Pressing lightly on the chip muffles the sound a bit. So I'm guessing I have to either find some way to silence it, or replace the power board?
                      Yet another realization! When it's turned on without CCFLs plugged in it makes the noise and then goes silent. The same thing it does with only 1 CCFL plugged in. I think we can be pretty sure it's the PSU board now.
                      • spleenharvester
                        • Mar 2010
                        • 914
                        http://www.ebay.co.uk/itm/LCD-Monito...-/120873710445 that look okay to you guys? No sore thumbs sticking out? Just wanna make sure it's not some cheaply made replica.
                        • Rtech
                          • Jul 2010
                          • 1095
                          #32
                          If you are located in the UK, then dont buy this yet ?????//
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            • Romania
                            #33
                            "That large rectangular thing" - is the inverter transformer. And yes, it may very well be responsible for the noise. Unfortunately yours is covered with something - if the windings were exposed, you could have tried brushing on a coat of clear lacquer and letting it dry, in most cases it gets rid of the sound, or at the very least, attenuates it greatly.
                            You know you can buy just the transformer? Look for any codes on it, and it's likely to be available on ebay and other online stores like lcdparts.net .
                            A working TV? How boring!
                            • spleenharvester
                              • Mar 2010
                              • 914
                              There's a small gap round the sides, reckon I could slip some in?
                              I'd prefer not to replace the individual transformer because my soldering skills are tragic to say the least :p caps is about the best I can do!
                              @Rtech - they post to UK.
                              EDIT: Furthermore this link shows one with the top flipped off. Is there any way I can pry it or is it glued on somehow? http://www.justanswer.com/uploads/Pl...erter-Xfmr.jpg
                              Also, is there any way I could just submerge the thing in lacquer, or would this damage it? It's honestly not too loud now, it's just at that pitch that makes me nauseous.
                                Is the noise coming from one transformer or from both?
                                http://s807.photobucket.com/albums/y...cpZZ1QQtppZZ36
                                • spleenharvester
                                  • Mar 2010
                                  • 914
                                  Just the one matey, the rectangular inverter transformer. There's a small amount coming from the smaller transformer but not loud enough to really hear in front of the monitor.
                                  If I do find a way to lacquer the inverter transformer I'll probably do that one too.
                                  EDIT: Very odd, you seem to have a different revision of W1907. Mine only has one transformer and the audio is on the logic board instead.
                                  • Rtech
                                    • Jul 2010
                                    • 1095
                                    #37
                                    One is normal in the UK,Varnish is the thing to use,if you want to try flooding it with that,it may work, otherwise your choices are:-
                                    Live with it as it is, new transformer or new Board,I think we can get cheaper and quicker than China, if you want to go down that road ?/
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      #38
                                      The top is not flipped off yours is like the middle top one in the picture.
                                      Top picture is the underside - the top does not come off.
                                      You would have to unsolder the eight pins and resolder after varnishing.
                                      Hardest bit is getting it unsoldered you have to be firm but gentle easing the whole thing up a bit at a time.
                                      • spleenharvester
                                        • Mar 2010
                                        • 914
                                        Damn :/ I can't find any boards that are in the UK though :p
                                        I have some of this stuff, guessing it's the wrong stuff but it's worth a shot - would it work? http://www.amazon.co.uk/HYCOTE-SPRAY.../dp/B005C9B3BE
                                        • selldoor
                                          Slow Learner
                                          • 7870
                                          #40
                                          This is more what you need - if you want to take that route.
                                          http://www.ebay.co.uk/itm/TRANSFORME...item19d4beb879
                                          • kotel studios
                                            Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
                                            by kotel studios
                                            Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
                                            State I got it in:
                                            Squealing from the PSU
                                            After logo I get a blank screen
                                            After 10 seconds of having a blank display w/ backlight the TV dies
                                            Give it 7-10ish seconds again and it starts to bootloop.
                                            What I did so far:
                                            Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
                                            Checked all voltage rails:
                                            5VSB - 4.8V
                                            AMP+13V - 14.4V
                                            13V - 12.98V (in manual 12V)...
                                            09-21-2025, 02:00 AM
                                          • RetroComputingGrotto
                                            Viewsonic VA2010wb (High Pitch Squeal At Power On)
                                            by RetroComputingGrotto
                                            I've got a monitor on my workbench at the moment that makes a high pitch squeal (that I cant hear as my ears are too old) when you power it on and lasts a couple of seconds before quitening and apparently it can be heard at regular intervals whilst on.
                                            On opening up the monitor and looking at the PCB the usual suspects showed their heads so I have already replaced all the electrolytic capacitors.
                                            The other issue that was reported with this monitor was the fact it took ages to start displaying anything after pressing the power button.
                                            What component(s)...
                                            02-03-2025, 06:00 AM
                                          • JDC
                                            (SOLVED) - Funai FW55D25F - High Pitched Squeal Upon Power-on.
                                            by JDC
                                            Issue: Funai FW55D25F - High Pitched Squeal Upon Power-on.
                                            Solution: Replace C3208 and C3209 on main board. These are surface mounted capacitors. Values unknown so I just used same physical size capacitors from a donor board.
                                            02-01-2022, 10:25 AM
                                          • dcapper
                                            LN-32A550P3F No screen and squealing
                                            by dcapper
                                            The blue Samsung led in the center at the bottom lights up and the red power light blinks but no backlight. Then after a few seconds, it starts to squeal. I changed all the power supply caps even though they were not bulged. I metered the coils on the inverter board, and all reading fine. So I found another mainboard that I had. I installed it and went into the service menu to change it to the model I that I am working on. Well now the tv turns on, it doesn't squeal and I get video except the video is red. Is the tcon bad?...
                                            03-15-2020, 11:47 PM
                                          • neilc6
                                            Philips 40PFL4908 Power Supply Problems
                                            by neilc6
                                            Reported as TV not turning on and power supply squealing.
                                            Check all transformer output diodes and not shorted.
                                            Schematic and service manual in this thread https://www.badcaps.net/forum/showth...ight=40PFL4908
                                            Disconnected power supply outputs and there is a very quick squeal when plugged in. AMP+13V and P-ON+21V measure half their expected output.
                                            Bridge rectifier diodes test ok. Fuse F602 not blown. Main switching transistor Q601 not shorted. Measuring 168V on drain (expecting 292V from schematic) so the input is half...
                                            05-18-2019, 01:30 PM
