Samsung 2253bw black screen
  • e3gsr
    • Aug 2012
    • 36
    • N Wales
    Hi guys i have been reading this forum with great interest the last couple of days, The reason I am here is I have a problem with a monitor I was given. The problem is the screen is permanently black, Back lights don't come on at all. I stripped it down and found bad caps so far I have replaced 4x820 1x330 and 2x1000. Lamps have been tested on another good monitor and are all working fine. When plugged in and turned on you can hear a feint squealing from the board but its hard to make out where it is coming from.Now I have 13.4v to my inverters but still no lighty. Anyone any ideas what to go for next before i give it .Apologies if I haven't put enough info if you need to know anything just ask. Forgot to say i am not totally green when it comes to electronics but i am no expert, so please go easy on me and any help to get my monitor working would be much appreciated.
  • Rtech
    • Jul 2010
    • 1095
    Re: Samsung 2253bw black screen
    Measure the resistance of the Secondaries on the Inverter transformers.
    • e3gsr
      • Aug 2012
      • 36
      • N Wales
      Thanks for the reply much appreciated I have done that and they both read around 1k with a fluke 87v dmm. Any other ideas would love to hear them, Would be great to get to the bottom of this problem.
      • selldoor
        Slow Learner
        • 7870
        Does it not even flash on for 1 second?
        With it all connected and on, test voltages out on power board sockets see if they agree with any board markings for the socket.
        Welcome to the forum-
        We can sometimes help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
        Examples of what is needed
        https://www.badcaps.net/forum/attach...1&d=1290283049
        https://www.badcaps.net/forum/attach...7&d=1280167246
        • e3gsr
          • Aug 2012
          • 36
          • N Wales
          nope doesn't even flash. I will test what i can later and report back and try to take some pics too.
          • e3gsr
            • Aug 2012
            • 36
            • N Wales
            right just had 5 mins so i tested the board voltages. on the connector to the front panel i get
            gnd-0v
            key 2-1.82v
            key 1-1.82v
            led ranges from 2.7 to 0v obviously
            3.3v-3.3v surprisingly enough
            on the 12 pin connector i am getting
            1-1.5v
            2-14v
            3-0v
            4-0v
            5-5.29v
            6-5.29v
            7-4.4v with led on
            8-0.01 with led off jumps to around 1v when led on hard to measure accurately in time given
            9-3.3v with led on drops when led goes off
            10-2.7v with led on
            11- around 1.8v with led on
            12- around 1.8v with led on
            does not flash on when turned on at all.
            I have 14.9v at F301 and 13.4v at inverter connections not tested output for obvious reasons.
            The led on the front panel flashes on and off even when connected to the pc.
            I will take pics now and post them up.
            Thank you for your help in trying to solve this matter.
            • e3gsr
              • Aug 2012
              • 36
              • N Wales
              pics of boards as requested
              • Rtech
                • Jul 2010
                • 1095
                Although you have given the voltages on the 12 pin connector, you need to qualify them by stating what they are supposed to be....ie what is written on the Board..eg Dim, 5,1 volts. gnd etc etc.
                • e3gsr
                  • Aug 2012
                  • 36
                  • N Wales
                  ok sorry here we go
                  1- b-dim
                  2- 13v
                  3- gnd
                  4- gnd
                  5- 5.1v
                  6- 5.1v
                  7- a-dim
                  8- on/off
                  9- 3.3v
                  10- led
                  11- key 1
                  12- key 2
                  • selldoor
                    Slow Learner
                    • 7870
                    Very good pictures -thanks have you tested the small green fuse in the middle of the power supply board.
                    • e3gsr
                      • Aug 2012
                      • 36
                      • N Wales
                      F301 yes I have its fine.
                      • selldoor
                        Slow Learner
                        • 7870
                        Can you test the voltage at each side of the F301 fuse use a ground screw for the black probe
                          pin8 is for backlights on/off. 0v = off, I expect it to be >3vdc. It will go high when the monitor is first turn on, it will go low later if it does not detect the video signal from the PC, same thing for the voltage to the T-CON board on the LCD panel. If you remove (do not do it with the connector connected due to output drive may be at logic lo) that connector from the main board and use 1K resistor between pin8 and 5V, that will force the backlights to come on.
                          "on the 12 pin connector i am getting
                          1-1.5v
                          2-14v
                          3-0v
                          4-0v
                          5-5.29v
                          6-5.29v
                          7-4.4v with led on
                          10-2.7v with led on
                          12- around 1.8v with led on"
                          • rogfanther
                            • Jul 2006
                            • 458
                            • Brazil
                            Board IP-49135B, seems I had one of these in a 743-something display.
                            Just to be sure, you are measuring the voltages with the two boards connected, right ?
                            • Rtech
                              • Jul 2010
                              • 1095
                              As suggested Pin 8 switches the Inverter on, and is usually about 3volts Dc from the Logic Board.What you can do is plug in your lamps,switch Power onto the Board leave the logic board not connected and the on off not connected,then apply 3v DC from a Bty between Pin 8 and one of the Ground connections, tha latter being a substitute for the Logic Board 3v, and the Lamps will normally light if all is well with the Power board ??
                              • e3gsr
                                • Aug 2012
                                • 36
                                • N Wales
                                selldoor the voltage at both sides is a little over 94v is that right?
                                rogfanther yes all connected up and tested live.
                                budm and rtech i will try that now and let you know how i get on, That is if i dont end up in casualty lol. In fact I wont try it just yet until someone can confirm the voltage is correct on f301 at 94v.
                                • rogfanther
                                  • Jul 2006
                                  • 458
                                  • Brazil
                                  From your pictures, it should measure about 13-14V, considering that screw hole near the logic board connector.
                                  Possibly your meter was in a wrong scale ? was it in AC maybe ? 94V should have blow the caps in that line.
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    I agree - the caps should be 25v and even upgraded to 35v would still have blown.
                                      Check your Voltmeter aging by measuring know good batteries, that voltage cannot be 94V for the inverter circuits, It should be around 15~20V for 22" Monitor.
                                      • e3gsr
                                        • Aug 2012
                                        • 36
                                        • N Wales
                                        oops yes your right again i was on ac doh!
                                        just tested again and it is just over 14v. is there any point on the board i can pick up a 3v supply to feed pin 8 or does it have to be external supply?
                                        • turmix
                                          AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                                          by turmix
                                          Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                                          The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                                          At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                                          During another reassembly, I made a mistake, and...
                                          01-29-2024, 03:48 AM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • HTR-Informatique
                                          by HTR-Informatique
                                          02-09-2025, 06:51 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • totof
                                          Samsung UE50KU6070 black screen
                                          by totof
                                          I have my TV model UE50KU6070 which I am trying to repair.
                                          BN41-02528A / BN94-10800C motherboard.
                                          If I disconnect the motherboard from the power board, the backlight works. When the motherboard is connected the backlight works but the screen remains black.
                                          When I plug the TV into the electrical outlet, the standby LED lights up but no reaction to an attempt to start it with the remote control for about 1 minute. During this minute the TV consumes about 20W.
                                          After one minute the consumption drops to 0W and the TV can turn on with the remote control but...
                                          09-26-2022, 02:34 PM
