Gateway FPD2185W inverter or ccfl lights?
  • hide08
    • 12
    Hello everybody Ive got a Gateway FPD2185W monitor that displays no picture Flashlight test didn't work. It has a constant blue light when turned on.
    It had bad caps in the power supply which I replaced with Nichicon and United Chemi-Con capacitors. I also replaced the ones on the logic board.
    Still the some problem...
    checked voltages
    5V rail 5.05V
    12V rail 12.03V
    15V rail? 14.4V
    I measured 14.4V on the source pin of mosfets U301 and U304
    I also checked the voltage regulators on the logic board
    voltages were fine
    I checked for shorts across the MOSFETs
    G-S D-S G-D
    U305 14.56M 7.13M O.L
    U302 14.3M O.L 7.8M
    U304 4.72k 12.9M 13M
    U301 4.75k 12M 12.2M
    Checked the transformer windings
    primary secondary
    T301 0.4ohm 160ohm
    T302 0.5ohm 157ohm
    T401 0.4ohm 223ohm
    T402 0.5ohm 222ohm
    T403 0.4ohm 225ohm
    T405 0.5ohm 222ohm
    T406 0.3ohm 220ohm
    T404 0.5omh 223ohm
    checked the states of the BL and N/F pins
    BL=5v
    N/F=0v
    I looked up the part number of the inverter controller I checked pin 6,VDD, and found it was 0.6V hmm...what if I pulled pin 6 to 5V?
    here is a video showing it
    http://www.youtube.com/watch?v=Wfjej...ature=youtu.be
    part number is BIT3193G
    other pins
    1=0v 16=0v
    2=0v 15=0v
    3=0v 14=0v
    4=326mv 13=0v
    5=0v 12=1.17v (should be 1.3v or higher according to datasheet)
    6=283mv 11=0v
    7=0v 10=0.616v
    8=0v 9=0v
    I think its a ccfl issue.
    Please comment any help is appreciated!
    Re: Gateway FPD2185W inverter or ccfl lights?
    Did any one of the lamps even flash for a second?
    • hide08
      • 12
      no backlights at all
        Even with bad or worn out lamps, if the inverter is OK it will try to fire up the lamps, and if the lamps do not stay lit, just take one bad lamp, the circuits will go into shutdown protection mode.
        Power supply voltages are OK, so it can be the logic is not sending the BL_ON to turn on the lamp or bad PWM circuits in the inverter section, need to do some probing.
        • Rtech
          • Jul 2010
          • 1095
          If the BL_On signal is ok, the only other thing that seems odd to me is the Secondary windings resistance on T301 and T302..I have never seen windings less then 450 ohms and usually more than that,but there again have never had this board !1.
          • retiredcaps
            • Apr 2010
            • 9271
            You mean pin 10? Pin 10 is Vdd and pin 6 is onoff according to page 3
            It is certainly a pleasure to read a well written post #1 with
            - punctuation
            - paragraphs
            - periods
            - homework done
            - video showing the problem
            - clear focused pictures using manage attachments
            - actual voltage readings
            - datasheets attached
            Now for suggestions.
            1) See if pin 10 (Vdd) is shorted to GND (pin 7).
            2) See if you can trace pin 10 vdd to the next component (maybe C323)? See if that component is good or has 5V DC on it.
            3) I recognized the chip PWM (scary) and there are some threads on this forum regarding the BIT3193 if you want to read them and get some ideas.
            --- begin sig file ---
            --- end sig file ---
            • retiredcaps
              • Apr 2010
              • 9271
              My working Benq FP71G+ has winding measurements of 200 ohms for all 4 so 160 ohms is possible.
              • selldoor
                Slow Learner
                • 7870
                I seem to be missing something here. What were you doing to get the lamps
                to light up touching 5v wires together? Were you using a separate inverter?
                If the lamps all light why do you think they are the problem?
                • hide08
                  • 12
                  Hi again ive gotten some sleep but im back
                  oops I typed in the wrong pin but I connected the wire to pin 10
                  the ccfl controller chip is not getting enough power on, its only getting 0.6v instead of 5v
                  and ISEN is 1.17v, should be higher than 1.3v
                  ok ill try them out
                  • hide08
                    • 12
                    Looks like its the logic/video board because there is no image displayed on the monitor using the flashlight test and no output to turn the back-light on from the main IC chip. I can turn on the back-light manually. by apllying 5v to the N/F pin
                    voltages are all fine.
                    The main IC is probably fried.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      voltages were fine
                      You don't seem like the kind of person to make this mistake, but since 3 others have in the last 72 hours, do you mind sharing the actual readings results for all 4 voltage regulators along with their part numbers?
                      • ttmi100x
                        HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                        by ttmi100x
                        Greetings everyone,
                        I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                        The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                        Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                        Upon closer inspection...
                        07-31-2024, 06:36 PM
                      • x_orange90_x
                        by x_orange90_x
                        01-29-2025, 09:24 PM
                      • Gentian
                        APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                        by Gentian
                        I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                        It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                        03-06-2023, 07:07 AM
                      • valvashon
                        Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                        by valvashon
                        For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                        History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                        01-04-2024, 01:44 PM
                      • eccerr0r
                        A modified sine wave inverter + a grid tie inverter?
                        by eccerr0r
                        If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                        Next thing is trying to charge the batteries using solar power, but that's another issue ...
                        08-31-2023, 09:14 PM
