Dell E228WFPC goes dim after 10 minutes, not 2 seconds
  • POM_MJ
    • Aug 2009
    • 228
    Re: Dell E228WFPC goes dim after 10 minutes, not 2 seconds
    pictures uploaded for reference.
    | AMD Phenom II X2 550BE | GIGABYTE GA-MA790FXT-UD5P | GeIL DDR3 Ultra 2x2GB 1600C7 |
    | XFX GTS250 DDR3 512MB | Dell H525EF-00 | Lancool PC-K62 Black | Samsung 2232GW |
    | 2xWD7500AYYS | 2xHD322GJ Raid0 |
      Edited: Thanks for in pictures, POM MJ.
        I look at the SCH, PIN 4 is the Dead time controller pin, per SCH, it is setup as SOFT-START mode since R818 is not used. It is interestin that C806 caused the lamps to go dim, it must have change the ON time of the lamps.
        • POM_MJ
          • Aug 2009
          • 228
          When BAD C806 (in my case) warmed-up, it has leakage current flow through it then cause the voltage at PIN4 goes higher than normal and pulse duty cycle goes wrong, that make lamps current incorrect, then protection scheme shutdown the oscillator, I thought.
          edit: IPboard 715G2594-1-4 (HUDSON8) schematic uploaded for reference.
            That makes sense since it is hooked up as softstart, but with resistor in place (leaky cap), then it is setup as Deadtime control.
            • smalltownguy
              • 127
              • US
              #26
              FYI - I replaced C805 and C811 today (470uf 25v each) and no change. On the off chance that POM_MJ meant C805 instead of C806. I didn't check this thread for updates until AFTER I'd swapped out those caps.
              OK, I'm pretty handy with a soldering iron, but WTF?
              How am I supposed to change that surface mounted cap?
              Metal tweezers and a low temp iron with a pencil tip?
              Where can I find said cap?
              • Jasgriff
                • Feb 2012
                • 578
                These are easy to do if u smother the end in solder and quickly heat up both sides then lift using tweezers or push to the side with the soldering iron.
                Smd caps can be bought from the usual places. Can't see ur location on your profile so not are where to suggest.
                Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
                How to resize your pictures guide click HERE
                Retiredcaps Ideal post example click HERE
                • selldoor
                  Slow Learner
                  • 7870
                  #28
                  Are c805 and C 811 the two caps on the inverter section.
                  Did you measure the voltage at them yet
                  I dont think we know yet that the c806 is a problem on your board.
                  Try easy things first.
                  I suppose setting it up then heating where c806 is to see if it makes it go off would be a test
                  • smalltownguy
                    • 127
                    • US
                    #29
                    Yes, C805 and C811 are in the inverter section. They're both located right next to the CCFL tranformers.
                    You want me to measure the voltage at each cap while the monitor is on? That might be kind of a trick, but I think I can pull it off.
                    • smalltownguy
                      • 127
                      • US
                      #30
                      I live very close to DigiKey, so most of my orders are 1-day shipping from them. If you can get me a part number, I just placed an order with them a few hours ago, I'll see if I can add the item to my order.
                      Thanks!
                      • selldoor
                        Slow Learner
                        • 7870
                        #31
                        Yes - I was told you had 3 arms and 4 pairs of hands and were brilliant at twister.
                        • Jasgriff
                          • Feb 2012
                          • 578
                          And if you can do all that and take a pic of ur multimeter at the same time Retiredcaps will defo allocate you some extra points.
                          Which SMD cap do you want us to find on Digikey for you?
                            I think he he is talking about C806 in post 21, 1uF 16V MLCC. But I think he should try heating up the cap as suggested in the post by POM_MJ, that was how he found out that he has leakey cap.
                            • smalltownguy
                              • 127
                              • US
                              #34
                              Yeah, I'll heat the cap first before ordering it.
                                @smalltownguy, do you have any through hole type caps? Anything like 0.47uf or so?
                                • smalltownguy
                                  • 127
                                  • US
                                  #36
                                  Sure I do - what are you thinking?
                                    If the C806 is bad after heat test, then you can use just one 0.47uF or two in parallel to see if that will work, you just have to find solder pads that are connected to the C806 and solder in the through hole caps in place.
                                    • smalltownguy
                                      • 127
                                      • US
                                      #38
                                      I rigged up the monitor with clear access to the back of the inverter board and turned it on. I hit it with the hair dryer and within seconds, it shut off.
                                      So...heat is definitely causing a problem.
                                      I'll see if I can get a better look at the board to find a suitable location to add a .047 cap to it, unless someone else thinks it's a better idea to just wait and order the surface mount cap?
                                        You will will have to remove bad cap from the board, then install a new cap in place, like I said, try using the cap in place of the bad one you find just to verify that the cap will fix your problem.
                                        • jetadm123
                                          • 2169
                                          #40
                                          I think I see a few things that should be clarified:
                                          1) I think when POM_MJ mentioned "0805" back in post #19, it might have been interpreted as "C805". 0805 defines the case style of the smd cap he used. It defines a specific length and width.
                                          2) Since the original cap is 1uf 16V, budm specified connecting two .47uf caps (not the 0.047uf that you mentioned above) in parallel, which gives a total of 0.94uf (close enough to the desired 1 uf). Also, pre-bend the leads of the caps before you solder them in, as bending them afterwards will lift the pads off the circuit board.
                                          3) To remove C806, if you have access to a second soldering iron, hold an iron in each hand and heat both ends of C806 at the same time.
                                          4) If you opt to order a surface mount cap for C806, then the proper value is: 1uf 16V, case style 0603.
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • aaronkatrini
                                            DELL Nvidia GTX 750Ti Mosfet goes short after a few minutes
                                            by aaronkatrini
                                            I have recently picked up this Dell OEM Nvidia GTX 750Ti 2GB Video card. Its an old card I know but still wanted to get it working if possible. The problem is the following:
                                            - Put the card in my testing motherboard and start running Heaven benchmark
                                            - Benchmarks seems to run smoothly up until half way then the motherboard completely shuts off immediately
                                            - Try to start it again and I get a slight move from the PSU fan - a clear short
                                            - A little troubleshooting later I find one shorted Mosfet - Replace them both - short is gone
                                            - Put the...
                                            05-18-2025, 04:18 PM
                                          • DrFalken
                                            Dell Inspiron 5593 shutdown after 5 seconds
                                            by DrFalken
                                            Hello everyone!
                                            Motherboard model: FDI55 LA-J081P
                                            Today a customer delivered this laptop completely dead, with the original power supply shorting when plugged into the connector.
                                            I found and replaced a shorted MOSFET (PQZ3).
                                            Now the laptop turns on (fan runs fine but no video signal) and after 5 seconds it turns off.
                                            BIOS has already been updated (both 64MB and 128MB IC)
                                            +3VALW and +5VALW are still present.
                                            +VCCIN = 1.8V stable (measured on PLZ1 at power up)
                                            Abnormal readings:
                                            PLZ1 to GND = 0 Ohm
                                            PLZ2 to GND = 0 Ohm
                                            04-09-2025, 10:45 AM
                                          • Kambi13
                                            Dell Inspiron 3542 Turns on works for 30 seconds to 1 minute then turns off
                                            by Kambi13
                                            Hi all need some help, I've got a Dell insprion 15 3542 that turns on works for about 30 seconds or sometimes a minute or two and then turns off and wont turn on again until I remove and replug the power connector
                                            Not heat related, everything is ok regarding to that.
                                            All voltages are present.
                                            Wondering if this as anything to do with one wire circuit, the charger is not original, but it was working fine
                                            Motherboard is Cedar 13269-1 F3XMC Rev A00...
                                            07-12-2024, 06:10 AM
                                          • master3112
                                            by master3112
                                            07-29-2025, 01:55 PM
