Dell Inspiron 3542 Turns on works for 30 seconds to 1 minute then turns off
  • Kambi13
    • Aug 2022
    • 134
    • Portugal
    Hi all need some help, I've got a Dell insprion 15 3542 that turns on works for about 30 seconds or sometimes a minute or two and then turns off and wont turn on again until I remove and replug the power connector
    Not heat related, everything is ok regarding to that.
    All voltages are present.
    Wondering if this as anything to do with one wire circuit, the charger is not original, but it was working fine
    Motherboard is Cedar 13269-1 F3XMC Rev A00
  • mon2
    • 14677
    Is the charger for use with a DELL? What is the power rating? It was working fine with THIS laptop? The PSID line will share details of the power adapter using a 1-wire protocol. If the adapter does not match the requirements, the unit will power off.
    • Kambi13
      • Aug 2022
      • 134
      • Portugal
      Yeah it's a compatible one, usually there's a warning when you turn on Dell laptops with those universal power adapters, but this one works with no warnings, it's specific for Dell's. This one as 90W, 19,5V with 4.62A
      • mon2
        • 14677
        Does it boot like normal in the 30seconds - 1 minute? You see the Dell graphics / power on text?
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          First try out a genuine 65W dell adapter and check in bios setup whether its detected as 65W.
          • Kambi13
            • Aug 2022
            • 134
            • Portugal
            Yes it does look pretty normal, I do see the Dell Logo and Windows spinning wheel and no power messages as I stated before. I'll try to source an original Dell adapter to see if that helps
            • Kambi13
              • Aug 2022
              • 134
              • Portugal
              Here's a Bios screenshot
              • mon2
                • 14677
                The reason for the comments by mcplslg123 is that the adapter ID can be faked by software. It is simple enough to take a $1 worth of hardware to make ANY adapter appear to be 90w rated. There are public articles on the internet to build your own fake style cables for testing with a lab bench power supply. It is vital for you to test with a stable 90W or higher rated power adapter from Dell which can be trusted. See the laptop specs for the proper adapter selection.
                • Kambi13
                  • Aug 2022
                  • 134
                  • Portugal
                  Ok, will do and post results asap
                  • janaka
                    • Dec 2020
                    • 36
                    • sri lanka
                    Also you must check immediately after power off if 3/5 is present or not...if it's not present it may be Q2402 faulty
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Yesterday only i received a dell PS_ID dongle which when used with dc supply,detects as 240W allowing gaming boards to power on from a 65W/90W adapter.To top it all,it even charges the battery. So there is no end to this fake business.
                      • zklgfs
                        Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                        by zklgfs
                        I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                        08-11-2025, 02:14 PM
                      • twonk9098
                        Lenovo Legion 5 high fan spin turns off after 34 seconds
                        by twonk9098
                        I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                        I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                        I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                        I have tried a few new bios but exactly...
                        07-14-2024, 11:19 AM
                      • hoarderteks_kyriakos
                        Dell Latitude E5570 - No display, turns off after a minute of pressing the power button.
                        by hoarderteks_kyriakos
                        Hello.
                        Yesterday my mother encountered a problem with her laptop, which led to it not turning on and expressing the behaviour mentioned in the title (you press the power button and then it turns off after a minute)
                        Here is what happened:
                        At one point i was fixing a setting on the laptop to make the laptop properly recognize the NVMe drive i put in months ago. All worked until all of a sudden the computer blue screened. The screen said it would reboot, but it never did. So she held down the power button, powering it off. Pressing it again, the screen briefly turned...
                        10-08-2025, 07:33 AM
                      • riko 656
                        Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                        by riko 656
                        I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                        Laptop Model:
                        • Model: Lenovo Legion Slim 5 16APH8
                        • GPU: NVIDIA GeForce RTX 4070
                        • Main BIOS chip size: 32MB
                        • VBIOS chip size: 16MB
                        Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                        What I Have Tried So Far:
                        1. I
                        Today, 05:14 AM
                      • Stephen
                        A1466 MacBook Air 13" 2017 Backlight issue works but then turns off
                        by Stephen
                        Hello, got a weird MacBook Air here
                        board looks fresh and no water damage, backlight works and turns on and stays on when installing OS etc. However, when the os is installed and when the system files are loaded before the login page the backlight goes out. I have wiped it, NVRAM reset, etc and even took some other instances and this blows my mind, never seen this before. Backlight just turns off once the OS is loaded. Anyone come across this and if so what would be the cause? I am certain its a board issue since I tested the LCD on another board and it stays on. Again the backlight works...
                        08-23-2023, 09:12 AM
