Inverter tester using old CFL
This is a sticky topic.
  • tn245
    • Oct 2013
    • 530
    Re: Inverter tester using old CFL
    Can I use this method with a CFL to test this inverter? It's from a 42 inch TV. There's one transformer driving all the bulbs. Would I just hook one CFL up between the two inverter outputs?
    • multimeter
      • Jan 2011
      • 739
      • united kingdom
      #42
      Originally posted by Measuray
      Would a device like this workout more better?
      http://www.lcd-pdparts.com/ViewDetai...ProductID=1813
      CCFL & LCD TV Monitor Backlight Tester
      VIP Price:$16.30
      thats for testing ccfl tubes,the bulbs in question will test the inverter for soundness
      fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
      please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
      • farman
        Banned
        • Aug 2013
        • ksa
        #43
        thanksssssssssssssssss
          Another tips for using CFL for testing:
          https://www.badcaps.net/forum/showth...x+dx-40l261a12
          • Agent24
            I see dead caps
            • Oct 2007
            • 4951
            • New Zealand
            #45
            Do you know if these bulbs cause any more stress to the inverter than the correct CCFLs?
            I ask because I had the idea to use this to test a couple of monitors which shutdown after 10-20 minutes rather than a few seconds. Would it be OK to run the monitor with these CFLs for that long?
            -David VanHorn
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              #46
              from my studies on arc tubes you should be fine. just don't expect much lite out of that CFL tube.
              Follow the white rabbit.
              • Agent24
                I see dead caps
                • Oct 2007
                • 4951
                • New Zealand
                #47
                Do you mean "Light" or was that a typo of "Life"? And if the latter - why?
                -David VanHorn
                • goontron
                  5000!
                  • Dec 2011
                  • 4108
                  • US
                  #48
                  that was an auto carrot of light, sorry.
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4951
                    • New Zealand
                    #49
                    No worries, might give it a go tomorrow then.
                    -David VanHorn
                    • mmartell
                      • Oct 2013
                      • 3189
                      Lol too funny.
                      • goontron
                        5000!
                        • Dec 2011
                        • 4108
                        • US
                        #51
                        Originally posted by mmartell
                        Lol too funny.
                        sometimes i wonder if the google devs are screwing with people.
                        • vusi
                          • Jan 2015
                          • 9
                          • South Africa
                          #52
                          Originally posted by budm
                          Do not throw away those broken CFL (14Watts or smaller), you can use them for testing your LCD monitor inverter circuits without buying spare lamps for testing.
                          You can solder the wires directly to the connectors on the inverter board or you can get the correct connectors but then you have to have more than one type.
                          I tested it out on my lamp tester board as you can see in the pictures.
                          I open up the lamp assembly using small hack saw just enough for me to crack it open, just be real careful.
                          Enjoy!
                          great stuff,
                            Useful info - stickied
                            • lalin
                              M
                              • Apr 2015
                              • 20
                              • us
                              #54
                              I guess you can use the same method on an LCD TV but there are many more lamps, is that practical?
                              • SteveNielsen
                                Retired Tech
                                • Jun 2012
                                • 2327
                                Yes, that is the point of the thread isn't it? It is for testing inverter outputs, not replacing bad tubes.
                                • 2014Sorentolover
                                  • Aug 2015
                                  • Egypt
                                  #56
                                  Great idea, Thank you.
                                  • bruvinsk
                                    • Nov 2015
                                    Do all these techniques will apply to testing inverter for 40" TV or I need to use different bulbs?
                                    • waldoalvarez00
                                      • Dec 2015
                                      • 57
                                      • Dominican Republic
                                      #58
                                      VIP Price:$16.30
                                      Seems so, but i think an old monitor inverter could do the same.
                                      • orangecomputech
                                        • Jan 2016
                                        • 7
                                        • india
                                        #59
                                        Thanks man well good information ........
                                        • Roman123
                                          • Oct 2015
                                          • 7
                                          • RUSSIA
                                          #60
                                          Good idea todai check
                                          • Yanleb
                                            Sharp LC-60LE810UN Lamp Error
                                            by Yanleb
                                            I have this Sharp LC-60LE810UN that stays off and blinks a Lamp Error (1 long flash followed by a short flash, in a loop).
                                            I already confirmed that the first backlight strip has an open LED using a LED strip tester. The other 3 LED strips are fine.
                                            Before tearing the LCD panel apart, I want to make sure that the rest of the TV set is good. I've tested the power-supply/LED inverter board by sending 5 volt to PS-ON, to PNL-POW (that commands power the T-CON board only), OFL and STB pins. The power-supply is good.
                                            I've tried all the key...
                                            08-24-2021, 11:48 PM
                                          • vestaviascott
                                            Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
                                            by vestaviascott
                                            Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
                                            Here's what happens:
                                            1) Power on
                                            2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
                                            3) Blue status light flashes for appx 4 minutes...
                                            07-29-2020, 06:08 AM
                                          • Gentian
                                            APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                            by Gentian
                                            I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                            It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                            03-06-2023, 07:07 AM
                                          • valvashon
                                            Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                            by valvashon
                                            For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                            History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                            01-04-2024, 01:44 PM
                                          • AJ847.63e
                                            BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
                                            by AJ847.63e
                                            Hi All.
                                            Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
                                            The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
                                            09-18-2023, 06:42 PM
