How do i complete circut on CCFL test lamp
  • DTLMG
    • Nov 2011
    • 37
    I built a CCFL tester from a computer mod kit. I can only get my lights i want to test to light half way. I am assuming this is because I have not completed the circut. What/how can i complete the circut? What am I supposed to do with the small black/white wires? Can i put a jumper in them?
    I have the desire to relamp a monitor, but need to understand how it works a little bit better before i tackle the job.
    Thanks.. This is a great forum!
  • PlainBill
    • Feb 2009
    • 7034
    Re: How do i complete circut on CCFL test lamp
    This is common. The mod kit doesn't have a high enough output voltage / current to light the lamps to their full length.
    PlainBill
    • DTLMG
      • Nov 2011
      • 37
      BUT..where do i plug the small black and white wires into?
      • lti
        • May 2011
        • 2555
        There appear to be two lamps. The other connector is connected to the second lamp.
        • DTLMG
          • Nov 2011
          • 37
          The two large wires PINK and BLUE are connected to one end of the tubes and the smaller wires black/gray are connected to the other ends.
          • jayoung
            • May 2011
            • 172
            Am I seeing the picture right in that you connected one end of each bulb to the tester instead of connecting both ends from one bulb? It appears that you have the heavy wires (one from each bulb) attached in one connector. Usually both ends of a single bulb are in a single connector.
            Or I may be missing something in the way the tester is set up.
            • PlainBill
              • Feb 2009
              • 7034
              The set of CCFLs you have have an unusual wiring pattern; I missed it before. I've seen this on a few monitors. The usual way is the high voltage and return ends of each tube are connected to the same connector; each connector handles a single tube. Note teh schematic I have attached.
              The tubes you are testing have the high voltage end of each tube connected to one connector, the return ends are connected to the other connector. You could try shorting the contacts of the connector on the end of the white and black wires together, but I think you are going to have to make an adapter so the source and return lines from a tube is connected to a single connector on the tester.
              PlainBill
              • alexanna
                • Mar 2010
                • 1346
                PlainBill,You are correct the hot wires are in one connector and the return wires are in the other on this set up. 19” Westinghouse monitors use this set up frequently.
                The pigtails can easily be removed from the plastic housing by inserting a lead of a small capacitor into the top hole on the front of the plastic connector and pulling the pigtail out.
                The way its wired now is that only the hot leads are hooked up to the inverter, I guess it’s enough to excite the gas in the CCFL, but it has no ware to go.
                If the 2 small wires were shorted together, I think it would be like we doubled the length of the CCFL.
                • DTLMG
                  • Nov 2011
                  • 37
                  Thank you Alexanna and Plain Bill. This helps me understand alot. I went to my local recycler and he let me disassemble a complete gaylord of Monitors so I could learn more about them. (he did have a puzzled look on his face why i wanted to do it for free) What a learning experience it was. All the westinghouse monitors are as you stated with the hot wires in one connector. I was able to score a pretty nice Viewsonic that I hopefully can use as a test PSU and inverter.
                  then there is DELL...the connecters that I saw were different yet. Are all Dells different or is it just the older ones?
                  Thanks for the info.... I learn so much from you guys.
                  • alexanna
                    • Mar 2010
                    • 1346
                    On the DElls it depends on how many CCFLs are used.
                    If it is a 6 lamp system,2 connectors will look like you are accustom to seeing and the other 2 will usually have 2 HOT wires and share return between them in one connector.
                    Edit BTW those local re cyclers are GOOD people to get to know!!
                    • DTLMG
                      • Nov 2011
                      • 37
                      FWIW I scored a 2 dell monitors one with the 2 light wide connecter and one with the 3 light connector you speak of. They both have broken LCD screens, but the PSU, inverter and back lights are fine. Of course I had to get my hands on some of the test CCFLs too!
                      • khelane
                        test active pfc power with lamp test
                        by khelane
                        Hello
                        I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                        Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                        Is there a way...
                        06-03-2025, 01:00 AM
                      • mikey5791
                        Help on Samsung Syncmaster T220 dead ccfl lamp
                        by mikey5791
                        This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
                        Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
                        10-18-2020, 03:17 AM
                      • ttmi100x
                        HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                        by ttmi100x
                        Greetings everyone,
                        I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                        The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                        Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                        Upon closer inspection...
                        07-31-2024, 06:36 PM
                      • chth96
                        How Can I test PWM DM0365R?
                        by chth96
                        Hello
                        I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                        So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                        I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                        I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                        06-18-2025, 04:14 PM
                      • chronic519
                        Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                        by chronic519
                        Hello.
                        GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                        Found issue with a RAM block
                        Replaced, green lines gone.
                        Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                        Used a good card to test and same results low errors 32+.
                        I am just search for some form of command to do a full test on the GPU.
                        I just ran the mats command with my good GPU and passed after roughly 40 min.
                        The repaired one, ran...
                        05-20-2025, 07:56 PM
