Samsung Syncmaster 245B Black screen and blue Power LED
  • enif
    • Switzerland
    #41
    Re: Samsung Syncmaster 245B Black screen and blue Power LED
    Great - my 245B is up and running again! I just had to replace the burned out resistor RB805. Thanks to all who contributed to this discussion!
    • terry
      • Oct 2007
      • 91
      • Milton Keynes, Bucks
      #42
      Help please,
      I have just been given a Samsung 245b and CM802 is missing, where can I get a CM802 (18n 630V capacitor). or any info on this item.
      Thanks for any help
      Terry
      • selldoor
        Slow Learner
        • 7870
        #43
        For info just type cm802 into the "search" above.
        Where in the uk are you - perhaps update your profile?
        • terry
          • Oct 2007
          • 91
          #44
          Thanks I have just updated my profile. I have typed in CM802 in the search. Lot of things about replaceing it. but as mine is missing I an not 100% sure what it is.
          • Toasty
            • Jul 2007
            • 4171
            #45
            Mouser: PHE450PA5180JR05
            http://www.mouser.com/Search/Product...E450PA5180JR05
            Datasheet:
            Works just fine. Bend the leads a bit to match.
            T
            veritas odium parit
            • selldoor
              Slow Learner
              • 7870
              #46
              Dont follow - you have said it is 18nf 630v with a cm board description,
              so it is a capacitor. If it is missing how did you know 18nf 630v?
              When you say missing - has it disintegrated or does it look like its never been on there?
              I think it is not easy to find bur 22nf 630v is more common and can be used
              I think retiredcaps says in one of the posts.
              Ebay - from china
              RS Electronics Watford might have them 35 miles?
              Cricklewood electronics might have them
              Farnell
              Digikey
              • terry
                • Oct 2007
                • 91
                #47
                All I know is that it is missing, you can see that something has be unsoldered.
                I found out is was 18nf 630v on a Badcaps post. I will have a look at the websites and see if I can find one.
                Thanks for the help
                Terry
                • selldoor
                  Slow Learner
                  • 7870
                  #48
                  there is this 22nf one on ebay
                  http://www.ebay.co.uk/itm/Panasonic-...item20c4ce855e
                    Terry, Did you see the SCH of the board in post 40? What is the board #? BN44-XXXXXXXX?
                    • terry
                      • Oct 2007
                      • 91
                      #50
                      Yes I have looked at the SCH board in post 40, same as my power board BN44-00173A. I have orderd the parts, I should get them in the next couple of days.
                      Thanks for all your help
                      Terry
                      • terry
                        • Oct 2007
                        • 91
                        #51
                        Just got the parts very fast delivery from CPC, replaced 3 x 68 OHM resistors with 3W ones and replaced CM802 with a panasonic capacitor ECQE6223JF.
                        All working now.
                        Thanks for all the help.
                        Terry
                        • selldoor
                          Slow Learner
                          • 7870
                          #52
                          Great news - well done! You may want to consider replacing all the middlesize caps to give it a bit longer life.
                          • swilson5
                            • australia
                            #53
                            Thanks Guys
                            This and similar thread prompted me to to have a go at repair of my 245B which broke down yesterday with same description. ie: blue light no display.
                            Caps seemed ok no change from new, Changed the three resistors with 68 Ohm 1 watt (only had monster sized ceramic in larger wattage) and now all working fine again.
                            cheers
                            Scott
                            • WiseguyTom
                              • Jun 2014
                              • 3
                              • Belgium
                              #54
                              I had the same problem with my syncmaster 245B (which has a BN44-00195A power supply).
                              Blue light came on but no image on the screen.
                              I was able to fix it and want to share my experiences.
                              At first, the problem was intermittent.
                              Sometimes an image was displayed and then suddenly it went black again.
                              Hitting the back or side of the screen a few times, often brought back the image.
                              But I had to hit it harder and harder to get the image back and after a few weeks I deciced to have a look inside.
                              After visual inspection I saw nothing special, no bad capacitors or resistors.
                              Also the fact that hitting it often/sometimes brought back the image made me believe it's not caused by an electronic component but by something else.
                              But what? A bad or loose transformer was my first guess.
                              I took out a DVM and started measuring on the stand-alone power board.
                              Standby 5.2V was ok. Connected it to the Pwr-On line to activate the other output voltages.
                              Nada, no 24V.
                              Then I started bending the PCB, pulling up one side while holding down the middle.
                              Don't do this with you bare hands or you'll get electrocuted!
                              All of a sudden, the 24V appeared!
                              Then I stumbled on this blog:
                              http://blog.whitesites.com/How-to-Fi...97265_blog.htm
                              Here they mention soldering joins that went bad.
                              So I re-soldered all big end medium joints and that did the trick.
                              So get your soldering iron out guys!
                              Cheers,
                              Tom
                                • 31214
                                not a good idea to hit lcd monitors - just so everybody knows.
                                • bubblegum_bob
                                  • Sep 2014
                                  • 5
                                  Cheers,
                                  Tom
                                  Thank you very much!
                                  I just resoldered every bigger component like in the image from the blog and it seems to did the trick! Let's see if it will fail in the next three days!
                                  • re-atari
                                    • Oct 2010
                                    • 136
                                    #57
                                    As one of the large caps in the lower right looks bulged, it probably will...
                                    re-atari
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      #58
                                      re-atari
                                      That is NOT his board it is a picture of one out of the blog which was copied from another forum so it is at least 3rd hand.
                                      • bubblegum_bob
                                        • Sep 2014
                                        • 5
                                        That's my board and i think the cold solder joint was in one of the red circles.
                                        Some leg wobbled a little bit.
                                        Would this make sense?
                                        How hot are these components in operating state?
                                        Afterwards I didn't screwed the board properly fix to give a little bit more space for thermal expansion.
                                        Does this make sense?
                                        I'm no pro, therefore my questions.
                                        • dan2k3k4
                                          • Aug 2015
                                          • Switzerland
                                          #60
                                          I have a Samsung SyncMaster SA450
                                          I seem to have the same problem but I don't know how to 'check' the different components with a micrometer (I've done it over 10 years ago...)
                                          Here's a couple pictures I took, it seems the screen had been opened up before as it was not so difficult to open... it's over 3 years old (work 2nd screen) :
                                          I have no idea where I should put the black and red metal points for the micrometer.
                                          • ulthi
                                            Samsung QE50Q60TAU - Flashes black/blue screen
                                            by ulthi
                                            My tv is not able to turn on. I flashes between black and vague blue screen (see video)
                                            I have tried different resets and have also replaced the main board - but nothin has changed.
                                            Any suggestions?
                                            https://youtu.be/acYQ-ImmhWA
                                            Today, 01:48 PM
                                          • Chrissygizmo
                                            by Chrissygizmo
                                            02-10-2025, 12:33 AM
                                          • gbbradshaw
                                            Samsung 65" UE65TU7000KXXU VER:02/UTU7000 TV Blue screen
                                            by gbbradshaw
                                            Hi.
                                            I have the Samsung TV Model: UE65TU7000KXXU VER:02/UTU7000 which has developed the following issue: blue screen while the sound it's still working. This happened after the screen developed some horizontal lines at first and then the next day suddenly turned into blue background. the screen was not damaged or anything. I can't access the menu. I have taken the tv to a local tech to have a look and he said that he thinks that it might be the pcb board as the back-lights are working and the sound aswell . I was hoping maybe you can guide me if I should buy the pcb board or not? Thanks
                                            02-22-2023, 01:31 AM
                                          • mar1in
                                            Samsung TU8000, backlight and sound on, stuck in blue screen
                                            by mar1in
                                            I've got this Samsung here that would be stuck in a boot loop.
                                            After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
                                            Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
                                            Thanks in advance
                                            11-08-2023, 05:43 PM
                                          • Chrissygizmo
                                            samsung galaxy ao2s very temperamental after screen replaced
                                            by Chrissygizmo
                                            Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                            Ive eventually managed to get it on and working but it's very temperamental...
                                            The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                            05-26-2024, 12:05 AM
