Faultfinding a Denon AVR-1910 in protection mode
  • Captain Shonko
    • Apr 2021
    • 7
    • United Kingdom
    Hi all
    First off I've never opened a home theatre amplifier before, and what an appalling sight! Taking this thing apart I can see is going to be an absolute nightmare but I'm hoping to get help in diagnosing the fault nonetheless!
    So I've had my Denon AVR-1910 for about 4 years, hooked up to my PC via toslink cable and connected to two large front speakers, and two surround speakers. No problems up until now when a few nights ago I switched it on and after about 10 seconds started hearing buzzing / interference from the speakers. Then a few seconds later the amp switched itself off and went into a red power led blinking every 0.5 second mode. On looking through the user manual it states either a speaker / speaker cable problem, or the amp has gone into circuit protect mode and must contact Denon.
    I checked all cables and connections and they were fine. So I disconnected everything from the unit completely apart from the power lead and tried turning it on. The main relay clicks as it always does / has done within about 5 seconds, get a solid green power led, but then within another 1-10 seconds the unit will power off and resume the blinking red power led every 0.5 seconds.
    Any subsequent attempts with the speakers plugged back in is the same - buzzing \ static noises from them after 5-10 seconds and then a automatic power off within another 5 seconds.
    So I've watched three Youtube videos of people checking other model Denons, whose insides look completely different to my AVR-1910 to my untrained eye , and a lot seem to end up being a voltage regulator issue.
    I think I've found where these are on this amp but I'm not sure. I know I need to probe with my multimeter and check what voltage is being output on the middle legs for each regulator when the amp is powered on - but I don't know what voltage readout I should be expecting, or what would confirm the problem even. The video I watched showed how to expect about 50-60 volts positive on one regulator, same but negative on the other regulator.
    I've attached pictures of the location of the circuit board I've found these and close ups of the regulators in question. They are 7812A JRC transistors. Allegedly I could get them from here in the UK: https://cpc.farnell.com/stmicroelect...0-3/dp/SC08364
    Although note one of the three is a 7912A.
    So I guess my question is am I on the right track, and can anybody help me with what values would show on the multimeter that prove these transistors are at fault?
    Thanks in advance for any help :-)
  • mmartell
    • Oct 2013
    • 3189
    Re: Faultfinding a Denon AVR-1910 in protection mode
    7812 = +12v
    7912 = -12v
    Google those parts for their pinouts so you can measure properly on the device.
    • budwich
      • Jul 2015
      • 3097
      what is the "thing" in the middle picture just above the 3 regulators... it looks like a blown component.
      • Captain Shonko
        • Apr 2021
        • 7
        • United Kingdom
        Sorry budwich, can you point out exactly what "thing" you're referring to?
        • Captain Shonko
          • Apr 2021
          • 7
          • United Kingdom
          Originally posted by mmartell
          7812 = +12v
          7912 = -12v
          So I'm expecting +12v on the 7812, and -12v on the 7912, oh their respective output pins yes?
          • budwich
            • Jul 2015
            • 3097
            its just above the three regulators... it looks blown.
            • R_J
              • 9535
              That's a glass zener diode, looks ok to me.
              • budwich
                • Jul 2015
                • 3097
                probably just the way I looked at the picture and lighting.
                • R_J
                  • 9535
                  The fault is likely in one of the outputs, One the output board there are small 2 pin plugs, check the voltage on one of the pins as you turn on the amp, this voltage should be close to zero volts, If one is either + or - above a volt, this is likely the output section with the fault.
                  • Captain Shonko
                    • Apr 2021
                    • 7
                    • United Kingdom
                    Close up attached of that component above the voltage regs.
                    In fact on looking close up, aren't they burn marks I see on the chassis under the middle chip?
                    Will power her up and check with the probe tomorrow when I have good light, it's no good at night here in this room.
                    Cheers
                    • R_J
                      • 9535
                      There is likely nothing wrong with the regulator ic's . It just looks like a bit of dust on the heat sink compound.
                      • budwich
                        • Jul 2015
                        • 3097
                        Cheers
                        still looks like "broken glass"... if it was a plastic cased component, that would be a sign of failure.
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          I suspect the caps. More suspicious is what looks like custom-branded caps!
                          (not known to be a cap manufacturer)
                          ASRock B550 PG Velocita
                          Ryzen 9 "Vermeer" 5900X
                          Arc A770 16 GB
                          eVGA Supernova G3 750W
                          Alienware AW3423DWF OLED
                          • Captain Shonko
                            • Apr 2021
                            • 7
                            • United Kingdom
                            Ok, I've got the readouts, are the 7912 values looking suspect...?
                            After realising that the pinouts are not the same between a 7812 and 7912 (why would they do that ), I can see that on the INPUT pin on the 7912, it gets negative 20 volts but only for a second or two after powering up the amp. Then my meter just reads "-1", and this is before it has powered down itself.
                            Now I'm only assuming this is wrong based on what happens on the two 7812 input pins. They show a permanent positive 20 volts consistently when the amp is powered on.
                            • Captain Shonko
                              • Apr 2021
                              • 7
                              • United Kingdom
                              Hi R_J
                              I don't even know what / where the "output" board is, note I am a complete noob to this. If it's one of these smaller boards connecting the power cable in and front panel power buttons together then I'm guessing it's the one shown here. Although I see no small 2-pin plugs. Maybe they are there but the line of sight is obscured, I'm getting to the stage to start taking stuff out so will soon know.
                              Cheers
                              Mark
                              • R_J
                                • 9535
                                Look at the first picture in your first post, See that upright board with the large heatsink mounted to it? that is the output board. If you look at that board you will see a small white 2 pin jack (there are no wires attached) this is a test point (don't short the pins together) Just check the voltage on either pin.
                                If you are going to attempt repairs to this amp, you should at least download the service manual.
                                • Long AMD
                                  Acer AL1916W - Two seconds to black - Voltage regulator problem?
                                  by Long AMD
                                  Hello all. Excellent forum you have here - it has already been a great help to me. I am posting the details of my situation before I go and start buying parts to see what suggestions the great minds here may have on diagnostics or otherwise.
                                  I have an Acer AL1916W monitor which has recently failed in the following way: the screen comes on at power on, but after a couple seconds the screen goes black. Using a flashlight, I can easily verify the LCD is fine but there is simply no backlight.
                                  The power supply board is of the type ILPI-025 Rev C (Date of manufacture was...
                                  09-13-2020, 05:59 PM
                                • twonk9098
                                  Lenovo Legion 5 high fan spin turns off after 34 seconds
                                  by twonk9098
                                  I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                                  I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                                  I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                                  I have tried a few new bios but exactly...
                                  07-14-2024, 11:19 AM
                                • disorder
                                  HP 2311 display, 3.3v regulator fried, need help to replace
                                  by disorder
                                  hello,
                                  i have a hp display 2311 to repair, totaly dead
                                  on the board, il have 2 capacitor 470µf that are dead and the 3.3v regulator : ax6630-33
                                  i have no such regulator, can i replace this one with a mic5209-33 (3.3v outpout regulator too) ?
                                  thank you
                                  Yesterday, 04:34 AM
                                • Supradin
                                  TEAC AG 980 going protection mode
                                  by Supradin
                                  Hi everyone. I'm new on this things, this is my first amplifier after I start offering repair service almost for free, just for learning purpouse
                                  So I have a amp that is going to protection mode. I saw that if I remove the ribbon cable which sends from main board B+,B- and signal for amplifiers card, is not going to protection mode.
                                  So, from that ribbon cable y disconnect everything but b+ b-, and amp goes again to protection mode. So my guess was something is wrong in the amp board.
                                  I disconnect all transistors and amp is ok.
                                  After, I connect the...
                                  Electronics forum for electronics experts to repair defective appliance.
                                  05-01-2024, 08:34 AM
                                • JidhinGeorge
                                  Denon RCD-M40 "Protection Mode: Power", couldn't reset.
                                  by JidhinGeorge
                                  I have this Denon RCD-M40 with protection mode: power ON always! I cannot reset and I can't use the system by any means! Anyone has a fix? There was line voltage fluctuations for the past couple of days and is now fixed. The receiver was working fine even after that on reset but now this error again and stays ON all the time, right away on plugging the power cord....
                                  11-21-2020, 12:24 AM
