TEAC AG 980 going protection mode
  • Supradin
    • Dec 2021
    • Espainia
    Hi everyone. I'm new on this things, this is my first amplifier after I start offering repair service almost for free, just for learning purpouse
    So I have a amp that is going to protection mode. I saw that if I remove the ribbon cable which sends from main board B+,B- and signal for amplifiers card, is not going to protection mode.
    So, from that ribbon cable y disconnect everything but b+ b-, and amp goes again to protection mode. So my guess was something is wrong in the amp board.
    I disconnect all transistors and amp is ok.
    After, I connect the transistors of channel 1...again fail
    So I disconnect chanel 1 and connect channel 2...fail again
    Another clue could be that only with main board, I have to tap standby button twice. First time, with main capacitors empty, the amp goes to protection mode, but the second time, with capacitors with 60V more or less, the amp stars ok, the voltage rises to 82 in b+b-
    Documents here
    https://elektrotanya.com/teac_ag-980.../download.html
    So....any guess?
    Electronics forum for electronics experts to repair defective appliance.
  • Supradin
    • Dec 2021
    • Espainia
    So...i´m going to check this relay... is the only thing that i see which is related with channel 1 and 2...if the coil is burnt...could cause a failure.
    • acedogblast
      [Marantz SR5012] Center channel keeps going into ASO/Overcurrent protection.
      by acedogblast
      First off I would like to thank this community as it has provided me with great information that has helped me greatly on my repair for this Marantz SR5012 AV receiver. I am creating this new thread as the other 2 that I have created here has had their original question/problem solved and I plan that this is the final thread on my repair. Please note that this is my first time repairing audio amplifiers so I may not be aware of common issues and things to know.
      Lets start at what I have done so far. Random speaker popping on all channels is fixed by replacing the 2 large filter...
      03-01-2023, 08:24 PM
    • eccerr0r
      old X58 triple channel board... memtest86 memory speed?
      by eccerr0r
      Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
      Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
      Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
      06-28-2025, 09:06 AM
    • mikey5791
      Help on car amplifier only one channel works
      by mikey5791
      Hi all forum members,
      Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
      My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
      08-06-2025, 10:36 PM
    • CDNBrewer
      Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
      by CDNBrewer
      Hello Everyone,
      I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
      Symptoms:
      • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
      • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
      • I swapped the Left and Right surround
      08-05-2025, 09:29 PM
    • dicky96
      Hitachi V19B01922 Channel Tune problem
      by dicky96
      Hi Guys
      I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
      He also has an LG TV, so three screens in the bar
      I installed three Satlink ST-6503 DVB-T Modulators
      This model https://www.aliexpress.com/item/32916553905.html
      These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
      02-09-2023, 09:20 AM
