HP 2311 display, 3.3v regulator fried, need help to replace
  • disorder
    • Sep 2015
    • 156
    • france
    hello,
    i have a hp display 2311 to repair, totaly dead
    on the board, il have 2 capacitor 470µf that are dead and the 3.3v regulator : ax6630-33
    i have no such regulator, can i replace this one with a mic5209-33 (3.3v outpout regulator too) ?
    thank you
  • lotas
    • Jan 2016
    • 4786
    • Russia
    It won't work according to the current, 1.5A versus 0.5A.
    • disorder
      • Sep 2015
      • 156
      • france
      ok thank you
      • tamerelapute
        [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
        by tamerelapute
        I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
        Except the cpu, I cant feel anything getting warmer.
        I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
        I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
        I believe that if the cpu was fried,...
        07-08-2024, 03:28 PM
      • taurtnt
        Help identifying AMCH073 regulator or finding a compatible replacement
        by taurtnt
        I’m trying to identify a step-down regulator marked AMCH073. It’s used on the PEX power rail of a graphics card. I can’t find any datasheet or info online.
        Here’s what I’ve observed:
        • It has a QFN-16 footprint, similar to NB670.
        • Pins 1, 2, 15, 16 are connected together and go to the inductor, so likely SW (switch node).
        • Pin 9 is connected to GND, which doesn’t match NB670 (where pin 9 is SW).
        • Pin 8 also seems to be tied to the same GND plane.
        • The chip only says AMCH073, no manufacturer logo or other markings....
        08-24-2025, 03:06 PM
      • playit
        diy - voltage injection possiblity with voltage and ampere regulator - possiblity ?
        by playit
        hello ,for diy voltage injector for short killer/finder -- is it possible to use something like this - LM317 DC Linear Regulator, DC-DC 4.5~40V Turn 1.2~37V, Step Down Power Module, Adjustable
        and ampere controller along (to make it zero amps ) with some addons(transistors diodes etc.) for it -- and use some 5v adaptor or 3.3v volt rail of my smps power supply as input and finally get 1v and zero amps for injecting voltage to find out short circuit component ? ..
        for source input -- can we use 3.3 -4 volt 18550 battery ?( i have some of those ) and then adding ampere regulator...
        02-26-2025, 05:39 AM
        ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
        3+1 Voltage Regulator for IMVP-7/VR12 CPUs
        Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
        core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
        configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
        serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
        Based on Intersil's Robust Ripple Regulator...
        11-05-2024, 03:24 PM
      • artvandalai
        Help identifying voltage regulator on this concept 2 pm5 monitor pcb board?
        by artvandalai
        This Concept 2 rower pm5 monitor doesn't shut down. It keeps turning on and stays on after being turned off. I read on another forum by another user that replaced the same component to check the voltage regulator.
        The monitor should pull around 35mA when turned on and in shutdown it should drops to around 0.060mA. Any advice on finding the voltage regulator on this board to check if it needs to be replaced?
        11-05-2024, 07:38 AM
