It just keeps blowing...
  • madan1
    • Nov 2016
    • 682
    • Bulgaria
    Howdy everyone.
    I got a non-working denon avr2801 from ebay. Since it was (almost) for free I just changed the fuse, powered it up and I got a pretty good bonfire from one of the "non-burning" resistors . OK, I have another blown amplifier.. cool, change the blown parts and I'm good.. at least that's what I thought back then .
    While I was waiting for the parts, I removed the blown transistors, assembled it and hooked it to my home audio setup... maaan this denon sounds great!
    I got the parts ( the power transistors, the diodes and the zener diodes were all substitutes ). Soldered everything on the pcb, checked it for any visual damage ( after the fire ), crosschecked the resistance of every component with the same on a working channel.. everything was good to go. Powered it up and.... bang! another bonfire from a brand new "non-burning" resistor.
    Removed the new set of blown transistors and just left it for a resident amplifier.
    A week ago I was out of things to repair and decided to finally fix that receiver ( I also wanted to try a new music setup for which I needed one more working channel ).
    Alrighty.. got new transistors, new resistors, new diodes.. well pretty much the standard thing. This time I also thoroughly checked the pre-amp board and the output circuitry for faulty elements. I also tested out of the board TR540 and TR528 together with a set from a working channel.
    This time I was totally sure that everything should be fine... and while I was brushing out the flux residue I noticed that there was something wrong with the path between R614 and ZD506. The path is less than 1mm wide / ~10mm long and was interrupted right in the middle of its length. So I guess this explains the enormous amount of damage the channel had ( indeed this is the first time I'm changing that many elements on a blown channel ). Made a bridge, checked again all paths for interruptions and assembled everything back.
    Power.. bang!... only smoke and a flash from the fuse this time .
    At first glance, this time, it blew only the power transistors and few resistors ( R622, R620, R624 and most likely the emitter resistors ). The pre-stage ones ( tr534/532 ) seem to be fine and currently the receiver is working with them on the board ( but with removed R620 ).
    So I already purchased the emitter resistors ( turned out those are hard to find ) and in the next days I will also get the power transistors, but... damn, I do not want another fire.. I almost have paid for transistors what I paid for the whole receiver.
    How do you proceed when fixing blown channels?
    Are there any procedures you do before powering up the unit?
    From the damage, do you see an element which might be faulty?
    Any advices are welcome!
    Also, with what standard parts would you substitute ZD506/508 and D534/536?
    The first picture is with the damage after the first repair attempt ( before I discover the broken path b/n r614 and zd506 ) and the second one - after the second ( with fixed path ).
    specs:
    https://www.hifiengine.com/manual_li...avr-2801.shtml
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: It just keeps blowing...
    Are you sure TR536 is a NPN and TR538 is a PNP ? It would seem both transistors are turning on at the same time
    • madan1
      • Nov 2016
      • 682
      • Bulgaria
      Well... here is the service manual and it says tr532 - 2sd1763a and tr534 - 2sb1186a. Those at least are easy to find, so no replacements here.
      p.s. Oh, you mean the main power transistors.
      The original are TR536 - 2sc3855, TR538 - 2SA1491.. let me see if I can find here ( at the office ) what I got last time as a replacement
      ithe manual is too big to upload here, so use these links
      http://www.filedropper.com/hfedenonavr-2801981serviceen
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        Are you doing the adjustment on page 12? So your problem is happening on the surround sound R channel? This is happening when no speaker are connected?
        • jiroy
          • Jun 2016
          • 2416
          • Lebanon
          Originally posted by madan1
          Howdy everyone.
          Using a variac would spare you lot of excessive costs . It let you also localize the gradually heated area ..
          • Khron
            • Sep 2006
            • 1350
            • Finland
            A variac and/or a series "bulb tester"... Not to mention the thought of NOT just swapping a fuse if the previous one blew.
            Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
            • petehall347
              • Jan 2015
              • 4426
              • United Kingdom
              remove outputs and tack in a 1k resistor between base and emitter connections for each output .
              check dc voltage on output ..
              • madan1
                • Nov 2016
                • 682
                • Bulgaria
                So just checked what main transistors I got last time from the local shop - they are a pair of SanKen 2SC3856 - 2SA1492
                No, I adjust the bias once I have a fully working channel.
                The maiden power-up is always without speakers attached.
                Yes, the SurrRight is the blown channel.
                Yes, variac would be perfect, but the electronics repair is still just a hobby and I'm trying to keep my hobby running costs low .
                can you provide more info about the "bulb tester" ( good link would be just fine ).
                Yes, just swaping fuses is not a good idea, but back then, when I got the AVR I needed to see if there is any life left in it ( the seller did not provide any information about the unit's faults ) and the thing was so cheap I really didn't care if it will live or die on me .
                By "outputs" you mean the main transistors, right? What power rate should be the 1k resistors?
                What should I check on the dc?
                and here are some good screenshots from the last bonfire
                It looks like this time one of the emitter resistors blew.
                • Khron
                  • Sep 2006
                  • 1350
                  • Finland
                  http://www.ppinyot.com/dimbulb/dim_bulb_tester.htm
                  https://antiqueradio.org/dimbulb.htm
                  http://www.geek-tips.com/2015/11/22/dim-bulb-tester/
                  • petehall347
                    • Jan 2015
                    • 4426
                    • United Kingdom
                    i have used 1/4 watt resistors in place of the output transistors no problem ... they are used to keep the feedback path intact whilst testing . it also saves on output transistors blowing up .
                    check dc volts where the emitter resistors join together .it should be zero volts .. few mv is ok .
                    • keeney123
                      Lauren
                      • Sep 2014
                      • 2536
                      I would concentrate on were your second picture is. That is the two transistors. To blow both transistors it tells you to much current went through them. They are connected together. One connected to the B+ voltage and one to the B- voltage VR504 as all the VR adjustments need to start fully counter Clockwise. When you measure at TP 504 you then need to bring it up to a very low voltage. If these transistors are fully turned on I only see a 0.22 resistor between them.
                      • keeney123
                        Lauren
                        • Sep 2014
                        • 2536
                        Resistor R620 333 ohms fried. I am not sure what NB means. Yet the two front end transistors did not fry. I am not sure why R 624 or R 622 did not fry unless their wattage is higher then R620. To fry R 620 the current path had to go through TR538 collector/base, R 624, R620, R 622 and TR 536 Base/Collector
                        • madan1
                          • Nov 2016
                          • 682
                          • Bulgaria
                          NB = non-burning ( which seems not to be always the case )
                          R620 - Carbon film 330 ohm 1/4W(NB)
                          R622,624 - Carbon film 1 ohm 1/4W(NB)
                          I have not checked any of the resistors with e multimeter... just the transistors. I checked the resistors only visually and cut R620 so that I can close the hood.
                          When the parts arrive, I will disassemble the boards and test everything.
                          By the way, could faulty emitter resistors cause this damage?
                          Now I remember that I got good ohm readings on them and decided not to change them.
                          • keeney123
                            Lauren
                            • Sep 2014
                            • 2536
                            So the amount of current needed to fry the 330 1/4 watt resistor would be 27.5 mA at 8.33 volts or any combination of voltage and current that would give 1/4watt. The other 1 ohm resistors must of had less voltage on them and therefore did not get to 1/4 watt.
                            Also, when you get the new transistors very with ohm meter that they are NPN and PNP.
                            On the original PNP the base can take up to 4 amps of current.
                              If you look at the service manual, you will see for example, the BASE of Q534 goes out to the Collector of the driver Transistor TR828 another section as shown in PDF schematic 6/13 PDF page 91, if that transistor has bad leakage it will bias on Q534 on hard and will cause the direct couple circuit have bad chain effect, so you should check that transistor and the other two differential pair Transistors. All the amps has the same setup, the driver Transistors are on another section.
                              • keeney123
                                Lauren
                                • Sep 2014
                                • 2536
                                Question wouldn't C506 stop that from happening with just DC?
                                  C506 is just filter cap, if you at the other page of the schematic, you will see that the Base is connected directly to the Collector of the driver circuit.
                                  • petehall347
                                    • Jan 2015
                                    • 4426
                                    • United Kingdom
                                    what is all short open all about ? i never seen that before
                                      The schematic is the master schematic that has all the parts (so the PCB foot-print of all the parts will show in the PCB CAD program) for making PCB, then you stuff the board with parts for the board assembly (PCBA) with the particular function that you need per BOM of the PCBA, so one blank board can be stuffed hundred ways.
                                      • keeney123
                                        Lauren
                                        • Sep 2014
                                        • 2536
                                        Sorry these dyslectic eyes played tricks on me. I had thought C506 was connected to the B+
                                        • eccerr0r
                                          old X58 triple channel board... memtest86 memory speed?
                                          by eccerr0r
                                          Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                          Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                          Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                          06-28-2025, 09:06 AM
                                        • spleenharvester
                                          Reverse engineering of 18650 4-channel tester
                                          by spleenharvester
                                          Hi friends
                                          I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                                          05-04-2025, 02:43 AM
                                        • karatzdi
                                          Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                                          by karatzdi
                                          I know some might say... just buy another one. Sell it as parts..!
                                          So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                                          Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                                          Spent some time downloading the Service...
                                          06-11-2024, 08:38 AM
                                        • acedogblast
                                          [Marantz SR5012] Center channel keeps going into ASO/Overcurrent protection.
                                          by acedogblast
                                          First off I would like to thank this community as it has provided me with great information that has helped me greatly on my repair for this Marantz SR5012 AV receiver. I am creating this new thread as the other 2 that I have created here has had their original question/problem solved and I plan that this is the final thread on my repair. Please note that this is my first time repairing audio amplifiers so I may not be aware of common issues and things to know.
                                          Lets start at what I have done so far. Random speaker popping on all channels is fixed by replacing the 2 large filter...
                                          03-01-2023, 08:24 PM
                                        • CDNBrewer
                                          Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                          by CDNBrewer
                                          Hello Everyone,
                                          I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                          Symptoms:
                                          • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                          • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                          • I swapped the Left and Right surround
                                          Yesterday, 09:29 PM
