[Marantz SR5012] Center channel keeps going into ASO/Overcurrent protection.
  • acedogblast
    • Feb 2023
    • 56
    First off I would like to thank this community as it has provided me with great information that has helped me greatly on my repair for this Marantz SR5012 AV receiver. I am creating this new thread as the other 2 that I have created here has had their original question/problem solved and I plan that this is the final thread on my repair. Please note that this is my first time repairing audio amplifiers so I may not be aware of common issues and things to know.
    Lets start at what I have done so far. Random speaker popping on all channels is fixed by replacing the 2 large filter capacitors for the power amplifier's power supply. Blown fuses is fixed by insulating the output transistors from the heat sink with thermal pads.
    Now to the current issue which I need to tell the whole story with this AV receiver. This Marantz SR5012 is bought used from Facebook Marketplace with the description describing that it has random speaker popping noise as a defect. This has been addressed with the already mentioned fix of replacing the filter caps. Once I had that fixed I tried playing some movies with it and on parts of the movie where there is loud sounds for the center speaker (and audible distortion) the AV receiver cuts off power and goes into ASO protection which according to the service manual is caused by “a short circuit occurred between the speaker terminals, or speakers with an impedance outside the rating where connected”. I confirmed that all speakers are connected correctly without any shorts and the receiver powers on completely with the speaker relays engaging. A few testing trials latter the receiver will now not power on and will go into ASO protection a second or two after turning on. I took out the amplifier board and found that Q428, the darlington 2SD2560 NPN output transistor for the center channel, has a short between collector to emitter. The corresponding emitter resistors, R511 and R512, have ohm readings in the kilo-ohm range which means they got damaged too from over current. So I had these components replaced thinking that that would be the cause of the problem. Had to replace that transistor twice as I accidentally damaged it since the heatsink had to be electrically isolated from all of the transistors. I also preformed the DC-bias adjustment and set all 7 channels to 8 millivolt as close as I could as specified in the service manual.
    Put everything back together to find out that once again the problem of the ASO protection occurrence again with any loud sound for the center channel. I will not power on the AV receiver again to prevent any further damage to the center channel section of the amplifier as I fear that the original problem is still present.
    Resources that I have looked into so far is this thread on this forum (https://www.badcaps.net/forum/showthread.php?t=73293) and this website (https://alpengeist-tvrepair.blogspot...g-rapidly.html), alpengeist's TV repair blog of a similar issue.
    Taking a look at the service manual (link posted below) on page 31 which shows the schematic for the amplifier. ASO protection occurs if Q405 gets a signal to its base if any one of the over-current detection transistors “opens its gate”. For the center channel this is Q430. I am going to take out the amplifier board once again to probe all of the transistors on the center channel as specified in the above resources. Are there any other points to test before I go full parts cannon on this repair?
    Marantz SR5012 Service Manual PDF: https://cdn.badcaps-static.com/pdfs/...c775c5d540.pdf
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: [Marantz SR5012] Center channel keeps going into ASO/Overcurrent protection.
    Do you know the speaker is ok?
    For example you could connect the center speaker to another channel to see if the problem follows. (Or vice versa with another speaker connected to the center channel)
    • acedogblast
      • Feb 2023
      • 56
      Yes I have used 2 different speakers. Same result.
      • R_J
        • Jun 2012
        • 9608
        Check ALL the resistors in that channel, (you can compare them to another channel).
        Check R502,R528,R519,R522 and R509 (across VR503) Also Q433 may have been damaged causing the bias to change with signal.
        It may be that one of the resistors has changed value and at idle (low current) the channel will operate but as the current changes the bias on the transistors change and the protection happens. When the outputs shorted they likely supplied full B+ or B- back to R516 and R521, so Q419 or any of the supporting resistors may have been damaged.
        This problem is not easy to locate using a meter as I suspect everything will check ok, but at higher current (Loud sound) is when a leaky transistor will not operate as it should.
        Can you access the transistors etc. when the amp is on? if you can, check Dc voltage on the drivers and see what dc voltage is changing when there is audio, The DC voltages should not change very much with or without audio
        • acedogblast
          • Feb 2023
          • 56
          R509 is reads larger that the other channel's counterpart at 207.9ohms. The similar resistors are around 180 to 190 ohms. All other resistors measure fine compared to the similar resistors in other channels.
          • mmartell
            • Oct 2013
            • 3189
            I've been down this rabbit hole. Not every pseudo-random fault is attributable to component failure.
            https://www.badcaps.net/forum/showthread.php?t=75229
            • acedogblast
              • Feb 2023
              • 56
              mmartell are you suggesting that this is just a false positive caused by loose connections?
              Looking at the schematic the ASO_DET pin on N1019 will go though a transistor (Q1025) that will pull down a 3.3V signal voltage that if not giving a high signal to the main CPU will cause the CPU to go to into protection.
              I'm going to hook up my oscilloscope to the ASO_DET pin on N1019. If this is a false positive then I shouldn't see any activation voltage to Q1025.
              • acedogblast
                • Feb 2023
                • 56
                This is not a false positive. I read 0.72VDC (could be higher) on ASO_DET pin by connecting probes on one leg of C515 and the ground to jumper J584 which leads to the other pin of C515.
                I also do not think this is a loose connection as tapping around the PCBs do not trigger any protection.
                • mmartell
                  • Oct 2013
                  • 3189
                  In the thread I linked the poster at the end said he reflowed the cpu and the problem went away. That wasn't my experience - I could physically push on the boards and make sound come and go AND throw the unit into protection.
                  I went down that path because while the unit was in service I got pissed and was reaching around the back to check for intermittent connections and when there were none I whacked it on the side at the rear right and was amazed the sound returned to full volume in all channels as intended.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8703
                    usually these things trip and lock down so unless you have a quick eye and meter or a logger, you won't notice which channel is causing the trip. After the trip occurs, shutdown happens, and the measured voltages have no meaning.
                    Did you check Q434 if that was bad too?
                    • acedogblast
                      • Feb 2023
                      • 56
                      It tests fine. I know it is the center channel that has a problem as all others work fine.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8703
                        Are you sure it's the center channel? If both Q428 and Q434 are removed, it will not go down into shutdown?
                        • acedogblast
                          • Feb 2023
                          • 56
                          You want me to take out both output transistors for the center channel? Can you please describe how will removing them help me find the root cause? I am just unsure of the purpose of that.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8703
                            There's no way to shut down because of the center channel if you have both output transistors out.
                            • acedogblast
                              • Feb 2023
                              • 56
                              Ok so I disconnected both output transistors and the result is just as I thought. All channels work expect the center one which is to be expected. This just further confirms that the center channel is the one with the problem.
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8703
                                If you set your bias for this channel correctly (note, you should also measure the voltage between the bases of Q434 and Q428 and ensure it's around 3.5 volts ± a half volt or so) and it sounds like crap, you may have a leaky Q434, if Q428 is known good, or vice versa.
                                Right now the data provided doesn't compute or you have multiple failures here - sense circuit too sensitive plus a bad signal path component to cause distortion?
                                • acedogblast
                                  • Feb 2023
                                  • 56
                                  I put in a new Q434 since I bought a few 2SB1647s. Powering up the base two base DC voltage between Q428 and Q434 is 2.3V. Readjusting the DC bias does not change it.
                                  • acedogblast
                                    • Feb 2023
                                    • 56
                                    I measured another channel and it also measured 2.3V.
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8703
                                      oops should be 2.8V ± 0.5V not 3.5V so you're good there.
                                      and you're sure that R511-R512 R517-R518 are all intact and match?
                                      • acedogblast
                                        • Feb 2023
                                        • 56
                                        I have already replaced R511 and R512. Both measure 0.2 ohms as they are in parallel and I have subtracted the meter's lead resistance.
                                        R518 and R517 measure 0.9 ohms which is high. Going to replace them right now. I remembered that they measured fine before though.
                                        • sima112
                                          Marantz pm 6005 right channel not worknig
                                          by sima112
                                          Hi guys,
                                          I need a help with my Marantz pm6005. It started to have weaker the right channel a few months ago, than it got back to normal and now it has lost sound completely on the right channel. At the final stage it was loosing the channel for a while and than it returned. After it has disappeared completely I could forced it back by unplugging the source form CD (which I normally use) to phone and back. It would then work for a few minutes and died again. Now it is possible power up and all function works normally (apart the right channel ) on all inputs, except the phone both channel...
                                          01-30-2023, 12:11 PM
                                        • eccerr0r
                                          old X58 triple channel board... memtest86 memory speed?
                                          by eccerr0r
                                          Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                          Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                          Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                          06-28-2025, 09:06 AM
                                        • spleenharvester
                                          Reverse engineering of 18650 4-channel tester
                                          by spleenharvester
                                          Hi friends
                                          I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                                          05-04-2025, 02:43 AM
                                        • fytonv
                                          7 channel NAD receiver,Need help identifying a suitable cap replacement
                                          by fytonv
                                          My 7 channel NAD receiver has audio quality and volume issues on 2 of the channels. Sometimes they work and sometimes they don't. Sometimes they're at about half the dB level of the left channels, and then they cut out entirely. Powering off and on the receiver fixes it for a bit.
                                          Without much experience to really know for certain, they only apparent issue I can see is with these electrolytic capacitors on the power supply. Bulging = bad, correct? I'm looking for replacements but I'm unsure what leeway I have with the temp ratings. Are there any other specifications I need to worry...
                                          09-08-2022, 09:52 PM
                                        • CDNBrewer
                                          Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                          by CDNBrewer
                                          Hello Everyone,
                                          I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                          Symptoms:
                                          • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                          • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                          • I swapped the Left and Right surround
                                          08-05-2025, 09:29 PM
