It just keeps blowing...
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: It just keeps blowing...
    Originally posted by budm
    If you look at the service manual, you will see for example, the BASE of Q534 goes out to the Collector of the driver Transistor TR828 another section as shown in PDF schematic 6/13 PDF page 91, if that transistor has bad leakage it will bias on Q534 on hard and will cause the direct couple circuit have bad chain effect, so you should check that transistor and the other two differential pair Transistors. All the amps has the same setup, the driver Transistors are on another section.
    It is hard for me to see could you show the leakage path? Please!
      If TR828N is stuck fully on or has low resistance between E-C then TR534 and the chain will be turned on hard.
      It is very simple amplifier with diff input running on dual supplies.
      http://sound.whsites.net/amp_design.htm
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        That is not what I am talking about. In order for the E to C to have leakage current there has to be a path from +57 volts to -57 volts. It will have to go through resistors which will be dropping voltage and lower current in the path between these voltages. There is a 47 ohm swamming resistor on the emitter of the transistor.
          What do think when audio signal is fed into the amplifier, those transistors will be full conducting or partial conducting (depend on audio level) with the signal, but if one of the device in the chain is stuck on what do you think it is going to happen?
          What happen if that TR828 has leakage resistance of lets say 100 Ohms
          TR532 (Clooector is connected to + supply) is bias on by R606/608/C542 Bootstraping so you have current flow through R620, E-B junction of TR534 so it is turned and give more current flow through R620 , and through 100 Ohms leakage, and then then through R888 (47) to - supply, at the same time when T534 is on, TR538 will also be on. It does not take much current to burn up that 330 Ohms resistor. At static, the circuit is balanced to give center point output to be at 0V, when thing gets out of balance due to static shorts or leakage then the circuit will get out of balance instead of swinging with the sync with the audio signal.
          • keeney123
            Lauren
            • Sep 2014
            • 2536
            My understanding is he is not putting a signal in it he is just turning it on and it does this. Thank you for the path I will lock at it closer.
              If one of the semi is bad then it does not matter if he has signal or not, the circuit will be thrown out of balance when you have bad device in the circuit.
              • keeney123
                Lauren
                • Sep 2014
                • 2536
                Would it not charge through C542 readily and when the two zeners and two diodes get to the correct voltage It would conduct lowering the voltage on C542 so it would charge again? And at some time TR528 will conduct?
                  TR528 is part of the active Bias circuit for the output section, and it is conducting already to maintain bias.
                  What do you that what that TR528 is for?
                  I guess you did not read those links I provided.
                  More:
                  http://www.eetimes.com/document.asp?doc_id=1272214
                  • petehall347
                    • Jan 2015
                    • 4446
                    #29
                    here you go this should help anyone learning ....
                    • keeney123
                      Lauren
                      • Sep 2014
                      • 2536
                      More:
                      It is very obvious that it is a bias circuit I already knew that. We are talking about your theory of TR828 leaking, not a normally operating circuit. We now have a 100 ohm transistor with C524 conducting so the bias circuit is a mute point as a pond power up it is getting shorted out by the capacitor. At some time when enough voltage is built up of the cap. for the bias to take effect the resistor bias and zener and diodes conduct. The voltage on the cap will dump and charge so this is a oscillation. I have not tried to figure out the exact voltage when all of this will happen if TR828 is indeed leaking because I would not be able to figure out exactly what resistance it would have.
                      All I was asking was if you could draw a path for the leakage current which you had suggested and then I asked would not C542 cap be the major path of conduction with the leaky transistor as the power was applied.I will not be working on this amplifier equipment so going into a detailed understanding of every part of every type of amplifier circuits would not be worth it as I would forget that knowledge in a very short time. I find somethings interesting and wanted to explore your theory. I know how these device work, meaning how each component works and understanding how they work together is a matter of study. For me I have a very difficult time at looking at all these crossing lines that do not connect or things that are omitted and the schematic broken in pieces. That is something I was born with. Instead of me trying to go through all that trying to see the leakage path I ask you as you had already saw it. I also thought in the process of you showing me this you would also be showing anyone that was interested in this thread. Also, your links are available for any young technician wishing to learn the operation of these circuits.
                        When that 100 Ohms is in place then you will have understand how that will affect the bias scheme of all the transistors after that, I do not have the time to explain. All you have to do is to calculate what the Vdrops will be on each components.
                        C524 conducting, what do mean by that? It is part of the Boostrap circuit, its jobs has nothing to do with DC Voltage when the failed transistor has 100 Ohms is in place of the transistor, it has to do with the impedance of the circuit, that cap can be left out and the circuit will still go out of balance.
                        bootstrapping principle.
                        http://www.edaboard.com/thread237660.html
                        • rievax_60
                          • May 2012
                          • 897
                          • australia
                          #32
                          Originally posted by madan1
                          NB = non-burning ( which seems not to be always the case )
                          R620 - Carbon film 330 ohm 1/4W(NB)
                          R622,624 - Carbon film 1 ohm 1/4W(NB)
                          I have not checked any of the resistors with e multimeter... just the transistors. I checked the resistors only visually and cut R620 so that I can close the hood.
                          When the parts arrive, I will disassemble the boards and test everything.
                          By the way, could faulty emitter resistors cause this damage?
                          Now I remember that I got good ohm readings on them and decided not to change them.
                          There are many possible faults that can be present in the idle current setting circuit that will cause the output stage to be damaged at power on. The idle current setting circuit can be checked independently or use the precaution mentioned in post 7.
                          • keeney123
                            Lauren
                            • Sep 2014
                            • 2536
                            I am very unconventional how I learn. I learn abstractly. It is the easiest way for me to learn. Thank you your time in providing this and I am sure any technicians and future technicians will find this very useful.
                            • keeney123
                              Lauren
                              • Sep 2014
                              • 2536
                              As I said I was exploring your idea. C524 conducts on power up with your leaky cap. We are not talking about a different circuit then the one we have. We are only talking about one moment in time when the components fail. I am not asking to explain in detail the circuitry. I don't have the time to figure that all out as there are many things happening at the same time and many things happen in the future time with this leaky transistor circuit. If I had nothing to do I would figure it out. I am sorry I wasted your time. I will not ask you any more questions.
                              • rievax_60
                                • May 2012
                                • 897
                                • australia
                                #35
                                In post #3 in that link, the diagram and explanation are incorrect. The capacitor needs to connect to the Emitter of Q2.
                                  What capacitor and what Q2?
                                  • rievax_60
                                    • May 2012
                                    • 897
                                    • australia
                                    #37
                                    The capacitor with the reference "C" and the transistor with the reference "Q2" in the diagram in post #3 in this link, http://www.edaboard.com/thread237660.html
                                      Post 9 explain what post 3 is.
                                      This one is better:
                                      https://cdn.badcaps-static.com/pdfs/...8f9437ce2d.pdf
                                      http://www.tedpavlic.com/teaching/osu/
                                      • rievax_60
                                        • May 2012
                                        • 897
                                        • australia
                                        #39
                                        I had missed post #9. Post #3 is very misleading though.
                                        • keeney123
                                          Lauren
                                          • Sep 2014
                                          • 2536
                                          This part of my statement is incorrect. Once the cap charges it will stay charge because of the DC source. With that said I realize to give an accurate analysis of all the detail of this circuitry as BudM I would have to do a detail study. My choice is to do other things that I enjoy like art and helping people what I can. At this time I feel my contribution would do more harm than good so with that I bid BadCaps Forum farewell.
                                          • eccerr0r
                                            old X58 triple channel board... memtest86 memory speed?
                                            by eccerr0r
                                            Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                            Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                            Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                            06-28-2025, 09:06 AM
                                          • spleenharvester
                                            Reverse engineering of 18650 4-channel tester
                                            by spleenharvester
                                            Hi friends
                                            I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                                            05-04-2025, 02:43 AM
                                          • karatzdi
                                            Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                                            by karatzdi
                                            I know some might say... just buy another one. Sell it as parts..!
                                            So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                                            Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                                            Spent some time downloading the Service...
                                            06-11-2024, 08:38 AM
                                          • acedogblast
                                            [Marantz SR5012] Center channel keeps going into ASO/Overcurrent protection.
                                            by acedogblast
                                            First off I would like to thank this community as it has provided me with great information that has helped me greatly on my repair for this Marantz SR5012 AV receiver. I am creating this new thread as the other 2 that I have created here has had their original question/problem solved and I plan that this is the final thread on my repair. Please note that this is my first time repairing audio amplifiers so I may not be aware of common issues and things to know.
                                            Lets start at what I have done so far. Random speaker popping on all channels is fixed by replacing the 2 large filter...
                                            03-01-2023, 08:24 PM
                                          • CDNBrewer
                                            Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                            by CDNBrewer
                                            Hello Everyone,
                                            I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                            Symptoms:
                                            • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                            • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                            • I swapped the Left and Right surround
                                            08-05-2025, 09:29 PM
