64' Ford Falcon Radio Buzzing
  • caphair
    • Nov 2011
    • 1249
    Hi guys my friend's dad wants me to try repairing this radio from a 1964 Falcon.
    He says it only buzzes and there's no audio.
    I tested the PNP part# 8P404V TO-3 transistor that's mounted to the back of the case and all measurements from B to C/E seem fine but from C to E I get .018 one way and .044 the other in diode mode. When I ohm test C to E I get a reading of 43ohms.
    Shouldn't it be a higher reading? A replacement transistor is $35 so want to verify its bad before ordering a replacement.
  • R_J
    • 9551
    Re: 64' Ford Falcon Radio Buzzing
    Is that measured in circuit or out?
    is there a model number on it somewhere
    • caphair
      • Nov 2011
      • 1249
      Out of circuit and there's a label on the underside but it's all faded and can't make anything out.
      Would like to repair it as my friend wants it to be a Christmas gift to his dad. But it's so old school with wires everywhere and no circuit board that it's hard to follow lol
      • R_J
        • 9551
        That does seem like its shorted e - c
        • caphair
          • Nov 2011
          • 1249
          Wouldn't it show shorted from B to C/E too though or no?
          Also when the radio is powered on it makes little crackling static sounds when the volume is turned up and down. Would that happen with a shorted output transistor or would there be no noise at all?
          • goontron
            5000!
            • Dec 2011
            • 4108
            • US
            Sounds like the IF stage is gone.
            Have you tried injecting audio into the audio amp/mixing stage?
            Follow the white rabbit.
            • caphair
              • Nov 2011
              • 1249
              IF stage? I haven't tried injecting audio. I wouldn't know where to inject it. Never worked on audio stuff before
              • goontron
                5000!
                • Dec 2011
                • 4108
                • US
                Ah, sorry. The IF stage is an intermediate step in reception. It shifts the carrier frequency.
                Does the chassis have a nameplate with a chassis model number? I can look up the schematic for it.
                • caphair
                  • Nov 2011
                  • 1249
                  I'm not seeing anything on the chassis with labeling unfortunately. So you don't think the transistor is bad but the IF stage?
                  • goontron
                    5000!
                    • Dec 2011
                    • 4108
                    • US
                    No, that transistor is definitely leaky. Actually that doesn't look like the an audio amp transistor, it's attached to an RF coil. And the transistors in the amp section are usually bigger, or non existent if it's a hybrid set. If i had to guess you may be looking at the IF section.
                    More than likely the majority of them are leaky like that. i count four on that side alone. Exact replacements (germanium IIRC) are expensive, i would go through the datasheet and try to find some modern equivalents. I would also do a recap.
                    EDIT: Digging on the radio forums it could be one of many.
                    5TBD, 5TPD or if Motorola made any for that year, 5TMD.
                    BTW, The model number is stamped on the side of the radio, towards the rear, followed by the serial number.
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      start by replacing all lytics.
                      including the multisection can.
                      old germanium transistors like to leak.even develop tin whiskers inside.
                      the to-3 is the output.many pnp ge will work.
                      • caphair
                        • Nov 2011
                        • 1249
                        What would be the multi section can?
                        How do I find an equivalent pnp? I have some from a monitor that were part of the push-pull inverter section
                        • caphair
                          • Nov 2011
                          • 1249
                          That transistor was screwed into the back of the radio on the outside of the case. I'll double check for the model number tomorrow
                          • goontron
                            5000!
                            • Dec 2011
                            • 4108
                            • US
                            That is output then.
                            • caphair
                              • Nov 2011
                              • 1249
                              Does that mean the other 4 are part of the preamp? Also would I need an antenna for testing? They didn't give me one but I imagine AM radio would be picked up fine?
                                • 31063
                                just start with a full recap - use 105' types.
                                then re-test.
                                it may just be caps - it's 52 years old!!!
                                • R_J
                                  • 9551
                                  I misread the readings, actually that output may be ok. I forgot it was a flower.
                                  What did you have hooked up for an antenna? you will need a couple feet of wire, those things did not have a very sensitive front end
                                  also what are you using to power it up, a car battery? or 12 volt power supply? (not a battery charger)
                                  try injecting signal at the volume control, you can just use your finger and touch the center of the control and you should get a 60 cycle hum coming through the speaker.
                                  • keeney123
                                    Lauren
                                    • Sep 2014
                                    • 2536
                                    So here is a forum that may help.
                                    http://www.oldclassiccar.co.uk/forum...a166fb9ce0ee08
                                    I remember vaguely that a large capacitor was used to suppress emf noise coming from the electrical system. This noise interfered with radio signals even in the home.
                                    • kc8adu
                                      • Nov 2003
                                      • 8832
                                      • U.S.A!
                                      its right above the ground bolt in your second pic.
                                      the transistors are germanium.wont find them in modern stuff.
                                      • caphair
                                        • Nov 2011
                                        • 1249
                                        I'm using 12v from an adjustable power supply. If I just touch the volume knob I don't hear any hums just little static at initial touch
                                        • shelby5041
                                          clock radio / radio lifespan?
                                          by shelby5041
                                          hi
                                          ive got a modern digital clock radio approx 15yrs old
                                          my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                                          since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                                          the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                                          it uses very little power just a few watts i would imagine that may have something...
                                          09-14-2024, 03:30 AM
                                        • UserXP
                                          Vintage SONY Digital Clock Radio ICF-C12W no audio
                                          by UserXP
                                          Dear all,
                                          I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                                          i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                                          My question is, do you know of this brand of capacitors and how bad are...
                                          07-21-2025, 08:35 AM
                                        • praveenramavath
                                          Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                                          by praveenramavath
                                          Hello All,
                                          I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                                          https://www.hifivision.com/threads/m...-screen.98243/
                                          Troubleshooting Summary: Majority Internet Radio - Flash Chip
                                          04-26-2025, 09:08 AM
                                          HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point EliteDesk 800 i7-7700T Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                                          09-12-2024, 02:00 PM
                                        • Omron
                                          Kenwood KDC 3051G Car Radio permanently stuck in Demo Mode please help
                                          by Omron
                                          Hello Guys! I have trouble with my car radio Kenwood KDC 3051G I hope someone more knowledgeable can help me, I tried everything in my power that I stumbled upon online.
                                          My radio is permanently in demo mode, it says Press Volume Knot Cancel Demo and when I press it nothing happens.
                                          - Tried to unplug radio and plug it back in into power,
                                          - Tried to reset radio by holding reset button key for 5,10,30 seconds while in power and without power, plugging it back in, it wouldn't work.
                                          - Tried to hold 3,6 while turning it back on and then pressing 1,2...
                                          05-23-2024, 01:27 PM
