Need Help with this Circuit Please
  • SteveNielsen
    Retired Tech
    • 2327
    Re: Need Help with this Circuit Please
    Just out of curiosity can you show pictures of the damage? Traces on audio boards are ofter repairable. They are not multi-layer computer boards with tiny traces.
    • Khron
      • Sep 2006
      • 1350
      • Finland
      Well, despite that, even IF you had to retrofit a separate power amp, are you really sure you wanna take quite SUCH a "cheap" route, amp-wise?
      For what it's worth, for about 40$ shipped it seems, you can get a pair of P3A pcb's - http://sound.westhost.com/pcb/pp3a.htm
      You could potentially re-use (at least) the good silicon from the stock amp board, perhaps also some of the passives, so even the component cost wouldn't be all that much extra But that's just my pair of pennies...
      Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
      • SteveNielsen
        Retired Tech
        • 2327
        Indeed, there's more than one way to skin a cat.
          • 30941
          oldskool design.
          http://www.ebay.com/itm/161852896480
          • tfs2015
            • Feb 2015
            • 135
            stand By for picture
            Computer and Small electronics troubleshooting and repair
            • keeney123
              Lauren
              • Sep 2014
              • 2536
              Some amps in the 60's just had a board with no circuitry. The board was used just to mount the components and wires were soldered point to point.
              • tfs2015
                • Feb 2015
                • 135
                Looks like I did damage on top of damage when I removed the burnt transistors. Tell me can this be fixed or am I looking at a total rebuild of the board and or circuit.
                Tom
                  • 30941
                  tracks look o.k. - just loads of sludgy solder all over them that needs cleaning off.
                  then clean the flux off with IPA and take fresh foto's
                  • SteveNielsen
                    Retired Tech
                    • 2327
                    Yeah, get rid of the blobs of solder and clean the board. Go easy on the pads with the heat so they don't pull up but I don't see damage to traces either, if there are they can be repaired on this board.
                    • tfs2015
                      • Feb 2015
                      • 135
                      The pads are the parts that I am concerned about because some of them pulled up when I was desoldering the bad power transistors.
                      • keeney123
                        Lauren
                        • Sep 2014
                        • 2536
                        I would use solder wick to clean the solder up. Just do not let iron stay to long on the braid. You would want to put a little flux on the solder joints and make sure the tip on the solder iron is tinned, place the braid on the solder that you want to pull up, then put the iron on the braid. The heat will transfer down through the braid heating up the solder. The solder will suck up into the braid as the braid becomes full you will need to feed unused braid into the solder. This should happen in one quick motion. Just make sure you have enough braid out so when you fed it in you do not burn your fingers. If it seems like it is taking to long then you will have to let the solder cool down again and try again. You do this to prevent burning of the board or pad.
                        • tfs2015
                          • Feb 2015
                          • 135
                          If I am unable to repair this circuit board to get the amp working, is there an amp circuit that I can use to put onto a new circuit board maybe one that is not as complicated as this one?
                          • tfs2015
                            • Feb 2015
                            • 135
                            Some of the pads have broken off of the traces
                              • 30941
                              fine, use jump wires - those transistors are mounted on a heatsink.
                              if you give up, look at the ebay link i posted in post#24
                              • tfs2015
                                • Feb 2015
                                • 135
                                can't use that eBay item says that it uses AC power and the only power I have available is DC Power. I appreciate the information.
                                • tfs2015
                                  • Feb 2015
                                  • 135
                                  What size wire would I need to use as the jumper Wire? I have 18 ga. solid right now.
                                  • SteveNielsen
                                    Retired Tech
                                    • 2327
                                    18 ga is too big. I use clipped off leads from parts like small resistors or caps for that.
                                      You just feed the DCV directly to the two main filter caps. Your amp has SMPS power supply or linear power supply?
                                        • 30941
                                        i think ebay add is wrong, i dont see any rectifier diodes in the foto.
                                        even if it had some you could bypass them.
                                        i think the chinese just meant use a split suppy.
                                          The bridge is attached to the heatsink.
