Short Circuit tester
  • Tarot Superstars
    • Aug 2023
    • 60
    Hello.
    I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
    The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
    Link
    The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
    https://www.youtube.com/watch?v=0eixDdCpiO4
    My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor in series with one of the probes the meter now shows the difference. I think it's about 1/1000 th of an ohm or more.
    I don't have the meter or the circuit for the 1st design so I can't tell you the exact values. So, then I see the very small differences between the resistance to each component on a circuit.
    My question is, is my method good enough?
    Do I need to add the batteries as was in the first design and the voltage regulator component (I think it was a LM317)?
    Any advice is appreciated.
    • 31316
    Re: Short Circuit tester
    if your putting more than 1 or 2 volts into the board your risking damaging some components
    • hcs77
      • Mar 2017
      • Hungary
      Many RAM, ROM, SOC, etc ic datasheets contains an absolute maximum ratings for voltage, for 5V SRAM is VCC+0.3V. This is a theoretical upper limit.
      If you want to find internal connection in the pcb (eg. reverse engineering), a simple way to connect 2 schottky diodes antiparallel to the multimeter probe. This will limit the multimeter output voltage to a safe level, 0,2-0,3V. You can use silicon diodes like 1n4001, but it gives a bit higher voltage.
      • Tarot Superstars
        • Aug 2023
        • 60
        Originally posted by Tarot Superstars
        Hello.
        Link
        I quoted the voltage incorrectly. It's 3 x 1.5 V batteries in series.
          • 31316
          that's still too much for modern 3.3 or 1.8v parts
          the multimeter already outputs 2-3v
          • RetroComputingGrotto
            • Aug 2023
            • 108
            3*9V batteries could be 27V which is far too high! In the video you linked to, Learn Electronics Repairs uses 3*1.5V giving a max of 4.5V.
            Don't modern CPUs run at 1V so even 4.5V probed in the wrong place could zap a CPU?
              • 31316
              1.8v is common, but yes - some stuff like cpu/gpu cores are even less
              • aaronkatrini
                Help me find the short circuit on this WORKING Nvidia GTX1650
                by aaronkatrini
                Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
                Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
                04-18-2024, 03:15 PM
              • fab13
                Nintendo Switch lite charging chip heats up and does not short circuit
                by fab13
                Hello everyone
                Small technical problem on a Nintendo Switch lite
                Here's what I noticed: the USB port has been damaged internally, with a short circuit on the power supply line to the small fuse.
                After replacing the USB connector, the short circuit went away and I can't see any other short circuit in the whole motherboard.
                When I charge the console, it seems to be charging: I get 15 volts and an amperage of 0.450 A.
                Then, after a while, the amperage increases to 1.1 A and the BQ24193 charging chip starts to heat up, as evidenced...
                09-16-2023, 04:59 AM
              • M1NEBLANK SHOW
                MSI B250 Gaming M3 Short circuit in CPU power supply circuit
                by M1NEBLANK SHOW
                Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
                (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
                Schematic and Boardview here
                04-04-2025, 03:57 PM
              • rumpumpel1
                Fault source of a short circuit
                by rumpumpel1
                I have a mainboard with a short circuit (approx. 0 Ohm) on the 3.3V rail. As usual, I injected current and observed the mainboard with the thermal camera. Instead of individual components becoming warm, I observed that an area of several square centimeters became evenly warm from approx. 2A.
                Has anyone ever seen anything like this? Is it possible that there is a short circuit between two layers of the mainboard? The visual inspection of the mainboard did not reveal any abnormalities....
                10-21-2025, 01:38 AM
              • Geeker007
                9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
                by Geeker007
                Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
                I am new to electronics repair, so my queries could be naive but I am ready to learn.
                So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
                01-28-2025, 03:31 PM
