HIFONICS ZXi 1008 car amp has output on one channel only
    • 31024
    Re: HIFONICS ZXi 1008 car amp has output on one channel only
    trace the base input to the power trasistors back.
    • tfs2015
      • Feb 2015
      • 135
      Here are a couple of better pictures to aid with the troubleshooting.
      Computer and Small electronics troubleshooting and repair
        Can we get straight shot pictures of the whole board top and the bottom side? hard to trace when pictures are in the angle and badly focused.
        If you look at your pictures and cannot read the labels or prints on the board, we cannot read them either.
        • tfs2015
          • Feb 2015
          • 135
          Hopefully those are a little better if there is specific parts of the board that you want me to take a picture of please let me know. My cell camera is about 4 years old.
          Thank you for the help and being understanding with me while I work the bugs with the pictures.
          Thank you
          Tom S.
            Well the good thing about the board layout is that the designators for the components are easy to know which one for which channel, for example: R100 for channel 1 amplifier has the same value and use for the same function as R200 for Channel 2 amplifier, so you can at least do the resistance comparison reading between the power amp sections to see if if the bad channel has much difference reading than the good channel, same for the Voltage comparison readings.
            Looking at the pictures, I am not if those are dark brown glues being used on the board or not, if they are, they are corrosive (eats up trace and component leads) and conductive.
            BTW, what DCV reading do you get at the speaker terminals of each channel?
            • tfs2015
              • Feb 2015
              • 135
              ch 1 -3.5 mv dc
              ch2 10.3 mv dc
                Originally posted by tfs2015
                ch 1 -3.5 mv dc
                ch2 10.3 mv dc
                If the output or driver devices has leakage or bad then you will have lots more offset Voltage in the Volt range.
                  BTW, are both line outs OK? if one is dead then the problem is in the pre-amp section.
                  • tfs2015
                    • Feb 2015
                    • 135
                    I will check and report back
                    • tfs2015
                      • Feb 2015
                      • 135
                      Line out on both channels has output so what should I check next?
                      • tfs2015
                        • Feb 2015
                        • 135
                        Well I did some more checking and testing on this Amp and as far as I can tell everything on the one channel is working perfectly. The other channel has no output, the power transistors are cold to the touch. They are getting the supply rail voltage as far as I can tell. Without a schematic on this amp it is really hard troubleshoot it. Some componet(s) has had to fail to cause the bad channels power transistors no to function at all I just don't know where to start checking. I do get a signal from the op amps but after that I have no clue. If anyone has worked on this model of amp please let me know if there is anything else on it that I can check.
                        Tom S
                          I have a hard time tracing the board due to the board is double sided (copper traces on both sides of the board).
                          • tfs2015
                            • Feb 2015
                            • 135
                            Trying to draw up a rough schematic using MultiSim and other programs that I have.
                            • tfs2015
                              • Feb 2015
                              • 135
                              Amp is now in protect mode. I have removed all of the power transistors on one of the two channels, but it still has the red protect light on. What should I do now?
                              Tom
                              • tfs2015
                                • Feb 2015
                                • 135
                                Amp is still in protect mode. I have removed the driver transistors, biasing transistors, and output transistors what else do I need to check? All ready verified that I Have 12V going into the transformers of the power supply and it looks like I am getting 12 volts out of it.
                                In the picture, What does the transistors do that I have highlighted?
                                • tfs2015
                                  • Feb 2015
                                  • 135
                                  rectifiers D11, D12, D13, and D14 are removed now along with all of the power and driver transistors and amp is still in protect mode. How would I check for any voltages going into and coming out of power transformers or the power supply section of the amp. Any help in troubleshooting this would be greatly appreciated. By the way this is a class AB amp.
                                  • tfs2015
                                    • Feb 2015
                                    • 135
                                    Desperately need help to troubleshoot the power supply circuit on this amp. It has two transformers in it with each having 2 Primary 2 secondary's on each of the transformers.
                                    How can I just check the transformers themselves for issues?
                                    Tom
                                    • tfs2015
                                      • Feb 2015
                                      • 135
                                      Rectifiers are out amp is out of protect mode. When I try to put any one of the four rectifiers back into the circuit the amp goes into protect mode again. What would cause this and what do I need to check? Rectifiers tested fine so now where do I check?
                                      Any and all help would be greatly appreciated on this.
                                      Tom S.
                                      • joshnz
                                        • Feb 2011
                                        • 969
                                        • New Zealand
                                        #39
                                        is there a fault on the primary of the switching converter?
                                        My pc
                                        CPU : AMD PHENOM II x4 @ 3.5Ghz
                                        MB : ASUS M4A89TD PRO USB3
                                        RAM : Kingston ValueRAM 16gb DDR3
                                        PSU : Cooler Master 850W Silent Pro
                                        GPU : ATI Radeon HD 6850
                                        • tfs2015
                                          • Feb 2015
                                          • 135
                                          how would I test for that? Any help would be greatly appreciated.
                                          Tom
                                          Wells, MN
                                          • FrancescoV
                                            Onkyo HT-R390 no sound output, video output ok
                                            by FrancescoV
                                            Good morning everyone,
                                            I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                            The firmware reported is the following:
                                            M:1.00/11107BLP
                                            D:?.??/????????
                                            O:1.00/11107AL
                                            The DSP firmware given the question marks seems corrupt.
                                            On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                            05-11-2025, 02:59 AM
                                          • eccerr0r
                                            old X58 triple channel board... memtest86 memory speed?
                                            by eccerr0r
                                            Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                            Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                            Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                            06-28-2025, 09:06 AM
                                          • spleenharvester
                                            Reverse engineering of 18650 4-channel tester
                                            by spleenharvester
                                            Hi friends
                                            I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                                            05-04-2025, 02:43 AM
                                          • afminguela
                                            No signal right output master channel - TRAKTOR KONTROL S4 MK1
                                            by afminguela
                                            HI,
                                            i have a S4 MK1 and suddenly don't have signal at the right channel main output, both in rcd and trs outputs.
                                            One day I was plugging all the set ( Macbook air+ traktor kontrol) and when I play the first song, right channel was silent.
                                            i made all the silly checklist (SW mapping, connectors, swapping channels...etc)
                                            and I concluded that is a hardware issue.
                                            As both physical outputs are affected, I suppose it's something at the mainboard BEFORE the split. No item seems to be burned, or broken, at sightsee.
                                            Does...
                                            05-11-2023, 05:58 AM
                                            NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                                            by sam_sam_sam
                                            I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                                            I bought this from an eBay seller but unfortunately they only had one
                                            I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                                            I bought three of from them to also make battery packs with this output power limit in mind
                                            I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                                            04-23-2025, 05:50 AM
