No signal right output master channel - TRAKTOR KONTROL S4 MK1
  • afminguela
    • May 2023
    • spain
    HI,
    i have a S4 MK1 and suddenly don't have signal at the right channel main output, both in rcd and trs outputs.
    One day I was plugging all the set ( Macbook air+ traktor kontrol) and when I play the first song, right channel was silent.
    i made all the silly checklist (SW mapping, connectors, swapping channels...etc)
    and I concluded that is a hardware issue.
    As both physical outputs are affected, I suppose it's something at the mainboard BEFORE the split. No item seems to be burned, or broken, at sightsee.
    Does anyone have the same problem?
    Does anyone solve the problem?
    Does anyone have a pinout of this equipment in order to solve the problem?
    Thnx!!
  • eccerr0r
    old X58 triple channel board... memtest86 memory speed?
    by eccerr0r
    Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
    Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
    Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
    06-28-2025, 09:06 AM
  • kooroshi60
    Traktor Kontrol S4 MK1 Flash dump
    by kooroshi60
    Hi guys
    I need the Flash Dump (.bin) file of the Traktor Kontrol S4 MK1. SPI chip number is 25DF041A from Atmel (4Mbit)
    So please let me know if you have the .BIN Dump of this model and its price and the payment method.
    I appreciate your help.
    10-01-2024, 10:17 AM
  • spleenharvester
    Reverse engineering of 18650 4-channel tester
    by spleenharvester
    Hi friends
    I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
    05-04-2025, 02:43 AM
  • mikey5791
    Help on car amplifier only one channel works
    by mikey5791
    Hi all forum members,
    Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
    My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
    08-06-2025, 10:36 PM
  • dicky96
    Hitachi V19B01922 Channel Tune problem
    by dicky96
    Hi Guys
    I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
    He also has an LG TV, so three screens in the bar
    I installed three Satlink ST-6503 DVB-T Modulators
    This model https://www.aliexpress.com/item/32916553905.html
    These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
    02-09-2023, 09:20 AM
