TEA2025B - Heavy noise over V++
  • chozo4
    Nothing Special
    • 134
    Just [rebuilt] my small sound amp after practically ruining the layout trying to debug this issue. Normally it works 100% and performs quite admirably when connected to an external source (Old Raidmax ATX-PSU) and is clear. However, when I powered it from the power source in my desktop where it is intended to be placed there is heavy noise from the internals such as the fans.
    Basically in my setup the sound source is a YMF724 also with a TEA2025B but is bypassed for lineout instead. Breakdown as it stands...
    On-board amp:
    - No Noise from power source
    - (test) Interfaces with external TEA2025b.. no noise
    Off-board amp [external power]:
    - No noise when connected to any source [onboard/lineout]
    Off-board amp [internal power - same as source]:
    - Excessive noise.
    - Feedback from fans both power rail and ground
    - Noise remains after disconnecting input ground
    - Noise remains after disconnecting power ground (use input ground)
    - No noise when input positives are disconnected
    Off-board amp [inputs connected-same source power:
    - Noise mostly removed when a 32guage high wind inductor is placed in series... but the voltage subsequently drops from 12v to just under 3v.
    - Noise somewhat lessened with a 100ohm resistor in series. Drops voltage 0.5v
    - Diode in series does nothing to noise
    - Using an LC setup causes noise in full force again with capacitor connected to power ground.
    - Ground and inputs connected only, can hear the power noise.
    The only thing I could figure that may have some effect is using a couple input isolators but that sounds patchy at best (no pun intended). What I simply don't understand is why the same exact amp and schematic when the onboard amp doesn't exhibit this issue but when using the external amp using the same power source and schematic causes this issue.
    It cannot be an EMI issue however that I know of.. the issue doesn't exist inside the computer when connected to an external power source. It's all being sources from the supply lines.
    The amp will be getting a wakefield 650-B aluminum heatsink attached soon once it arrives. I have a wire clamp point allocated for it between two of the jointed solder grounds. The excess traces behind the inputs and ground lines are used for heatsinking purposes as well and have been augmented with flattened 24 gauge solid core wire and the centre with flattened desoldering braid in the very center.
    General Info:
    Code:
    Input voltage: ~12v +/- 5%
    Output resist: 2ohm (2x 4ohm)
    CAPName    Series Temp   C/V    Location
    Evercon   ME  105c  1500uf/ 6.3v Output Decouple
    Pana/OSCon SEPC 105c  270uf/16.0v SVR
    Rubycon   CE-W  85c  220uf/ 6.3v Feedback
    Rubycon   PK   85c  680uf/16.0v Supply
    UCC(?)   A07C? 105c?  100uf/16.0v Bootstrap
    ?MLCC    X7R  ???  0.47uf/50.0v Freq.Stability
    ?Polyester ??  ???  0.22uf/??.?v DC Decouple
    Miscellaneous
    ST    TEA2025B    Class-AB  W990D0001 Malaysia
    Vishay  Resistor-1/8w MetalFilm  1%/50ppm/562ohm
    Ratshack PCB      276-168B  GeneralPurpose
    Even crap caps can be useful... such as blank rounds for prop gunfights.
  • lexwalker
    • Feb 2011
    • 307
    • Malaysia
    Re: TEA2025B - Heavy noise over V++
    That could be the main cause, a noisy power supply on your desktop. The rest of the symptoms mentioned pretty much points me to that PSU...
    Have you tried a pi filter? Also measure the resistance of the GND connection wires. Semi-floating ground problems can create a lot of noise...
    Code:
    This is an ancient capacitor. Also have quite a few of those, unused...
    Code:
    This is a general purpose capacitor. I would suggest using ultra low impedance/ESR capacitors such as those found on your desktop machine's motherboard (because generally the PSU used for your desktop machine is of SMPS type). Bigger capacitance is recommended, and try adding a 0.1 uF ceramic or film capacitor as close as possible to the power supply pin of that I.C...
    • chozo4
      Nothing Special
      • 134
      The PSU has been running reliably since I got it about 2 years ago. It was also built by the OEM Superflower which is top notch, providing for distributors such as Seasonic and others. Even johnny guru gave it high ratings for instance... http://www.jonnyguru.com/modules.php...Story&reid=266
      What I do notice is that it's mostly feedback noise from the fans and that when everything is idle and quiet - there is very little noise from the 12volt rails. Curiously, the same amp built in on a PCI card doesn't get any of this noise from the 12v rail with everything running full bore and does not have a PI Filter beyond a usual n440 diode. There is no noise with my raidmax SMPS on this amp connected seperately which is over 10 years old with bulging (and one leaking) TEAPOs for example. I just use it for a shortterm benchtest PSU but will recap it one of these days. This further hammers it's not a direct issue with either PSU. So for a PSU with both really bad ripple and low wattage and the ilk normally due to poor caps... not producing audible noise says something.
      I tried a basic LC filter rather than a PI filter and that just pulled all the noise back in from the ground line instead. The ground line is a short 18 gauge wire typical of most PSU's so it has no measurable resistance. I will tinker with it again tomorrow with a CLC/Pi filter accordingly and see what I get then. I have a very strange feeling that if I swapped the roles.. putting the amp on the comp PSU rail.. and a source on an external supply there would be no noise the either. Will have to test that theory as well then as it would also explain why my fan controller starts off with a CLC at the molex as well for example.
      Wait... that gives me the idea of disconnecting everything from my fan controller, connecting the amp to that for the variable voltage adjustment and already existing CLC. Then see if it helps with isolating the noise as well accordingly.
      I find they are nifty caps that continue to take a beating and keep ticking. I have one other in my collection sitting around but find they have a nice effect on the feedback. That and.. I was a glutton for their uniqueness and colour. A while back I even used a 25v 47uf green cap from Marcon manufacturered in '84 for the SVR at one point. I kind-of wanted to add a bit of vintage flair to it along the way I suppose.
      I did originally have a 0.1uf ceramic parallel with it but it didn't have any effect so omitted it in my final build. I went with the Rubycon PK as well due to the capacitance and size. There isn't much room as the max space allocated for the power cap on my layout is 8.5Dx12H and the PK ended up being the highest capacitance I could find in an 8Dx11.5H package. Everything else within that size was general purpose 470uf with 3/4 of the ripple or polymers around 270uf maximum from what I could find on mouser/newark. I do have room to increase size of the Supply Voltage Rejection (SVR) cap a bit more however as needed.
      Considering the amp doesn't draw too much, ~650mA ripple is more than sufficient for the purpose for a ~300mA draw when being deliberately pushed hard with bass tests. The schematics actually call for a 470uf normally for the power filter however but don't take into account the amp being pushed beyond typical usage specs. During testing on the last build I figured the heck with it and actually replaced the power cap with both a Teapo SD 16v/2200uf and Rubycon MBZ 16v 1500uf with only very little change in the noise.
        • 31087
        try taking a low impedence cap like 220uf and putting it across a fan plug.
        see if you hear a change.
        the fan is an electronicly pulsed sequence of coils - it probably looks like pure evil on a scope.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          You have a ground loop. When you connect an amplifier to the power supply of your desktop computer, and you also connect the jack to the soundcard, which has ground in a separate place, you create a ground loop.
          Try putting a 10 ohm resistor between the soundcard ground and the amp ground, instead of connecting it directly.
          A working TV? How boring!
          • chozo4
            Nothing Special
            • 134
            I don't have a scope unfortunately but will give that a try to see if there is much difference. The offenders are fans that have a 2A draw on the supply when starting up so makes sense to give that a try.
            I actually disconnected the input ground to break that potential loop and no go. Normally if I broke the ground loop or put a resistor in place of it I would otherwise get mild motorboating/oscillation but that doesn't happen if I break the input ground in this instance. I further tried keeping the input ground connected and the power input ground disconnected to ensure the power ground uses the input ground instead and the same noise occurred.
            Though the one thing I didn't try that I should have like I did long ago when tinkering was to place a capacitor in series with the input ground to break any DC current flow over that ground. I'll have to try that again in this instance and see if there is any positive result from it.
            • lexwalker
              • Feb 2011
              • 307
              • Malaysia
              You may want to consider re-capping that PSU as well (as capacitors do age). The PCI card is attached to the motherboard, which usually has lots of ultra low impedance capacitors (mostly range anywhere from 470uF to 1000uF) along its power rails and as decoupling capacitors at vital sections (can find them often near voltage regulators and big I.Cs)...
              Are you using any voltage regulators before that amplifier I.C? For the pi filter, make sure the inductor/choke has a ferrite core (in other words, not an air core type). Any measureable resistance on the GND connection, especially around 1 Ohm or higher, will always create noise. The amplifier I.C can pick up slight voltage difference between GNDs (especially ripples and noise from other devices like fans). You may want to consider isolating the power supply by using a LDO voltage regulator.
              I've also have some (unused) ancient Marcon capacitors around, mostly 4.7uF and below. Also had some ancient Nippon Chemicons also...
              The ceramic is for handling very high frequency ripples and noise, and mainly for decoupling function near I.Cs. For 8.5x12mm sizes, you may want to consider 10x12.5mm size capacitors as well. Panasonic SEPF series (ultra low ESR) have large capacitance and are small enough to fit that category.
              Usually in the schematics, the capacitor close to the I.C's power inputs are decoupling capacitors.
              • chozo4
                Nothing Special
                • 134
                While they do age the PSU has been emitting barely any heat that would otherwise contribute to a farmore rapid aging cycle. It's an 80+Gold supply so cap wear should be heavily reduced from lower heat output as it is. I did check though through the vents and so forth too and they seem in good shape visually. Just don't want to kill my 7 year warranty on this thing just yet.
                Good call on the PCI slot though - was thinking something like that but wasn't quite sure. Though this board is all small solid electrolytic capacitors from 560uf to lower accordingly. Was a bit surprised to see the downsizing though but the board is quite stable with a good overclock thus far.
                I actually don't have any LDO's and instead have LVR's by ST for 5v/9v output respectively and didn't want to reduce the voltage too much. I do have an adjustable linear regulator somewhere but I lost track of it so need to hunt it down again sometime (damn cats!). I did however spend time tinkering on the breadboard with an alternative. It was a Discreet noise reduction circuit apparently called a 'capacitance multiplier'(Img1). Changed it up a bit as I tweaked and got a good result at first with a 2.2k resistor to base and the 16v 680uf Rubycon PK. I did test some low esr caps and such but they actually let a bit more of the noise through likely due to the lower ESR and a noisy ground. I had also followed up with a 15ohm 1watt resistor at the end and got a noiseless result without much voltage loss. The transistor used was an ST mje3055T for the start. The noise reducer ground is separate with the amp itself being grounded via the input ground rather than power ground. Testing has all been done using headphones attached to the amp accordingly.
                So while I built it from bread to board... I made a couple more changes...
                -> Replaced the 15ohm resistor with a 10.5ohm enclosed ferrite inductor.
                -> Decoupled the output there with a 0.1uf molded polyester capacitor.
                -> Swapped the MJE3055T with a small TO-92 2SC1213 NPN ~500mA current. Voltage dropped a bit more from that however but its' only a test run for the moment.
                I might make a few more changes later on as I put it through the paces but it's working great thus far. In the end I'll see about reducing its' size to handle only what's needed as I will be needing it for the ST LM358N microphone amp I have wired to the 5v USB at the moment.[/quote]
                Aye, I had a braindead moment when I called it the supply cap. Which while it is a decouple it also acts as a voltage smoother/reservoir cap besides hence my going braindead.
                Ironically I was looking over the SEPF series last night while trying to ID the bootstrap caps I had. Was too late to edit in the changes though. Those were UCC PXA's without the logo on them so wasn't too far off the mark. I have been using an SEPC however on the SVR. I vowed to no longer buy any more parts for this amp however. The only exception were to get parts I wouldn't otherwise come across much if at all such as the vishay resistors and the supply decouple. The rest was purely aimed at being considered the salvage amp.. built from all used or otherwise salvaged parts save for the PCB of course.
                Though I may have to invest in a decent LDO however as all I have on hand are a bunch of mosfets and linear regulators on these half destroyed projection TV boards. Are there any that you would suggest for the task with the highest possible PSRR? Also, as one has probably noticed... I'm a bit biased and prefer products by ST whenever possible.
                (IMG1 Source: http://www.edn.com/electronics-blogs...or-noise-floor )t
                edit: After more testing I might need to revise it for sure. While the voltage output was good when idle I didn't check on load. During load with a bass test to push the heat/power draw.. the voltage is dropping out to between 5-6volts while the inductor is getting quite toasty so might need to reduce the base resistor a small bit to increase current flow and/or swap in the MJE. Seems I might end up going with a low dropout regulator soon afterall if I cannot tweak this a bit more. Then again, would reduce size using a single LDO and couple ceramics in comparison.
                • chozo4
                  Nothing Special
                  • 134
                  Did another rebuild of the noise isolator due to the issue with output and did more tinkering over the hours trying a bit of everything (also got a migraine that could down a giant). Initially tried a double-pi.. being C-L-C-L-C prior to the transistors and it made very little difference. The main reason the output was so low was due to the higher resistance to base. Downing to 1k caused far more noise in the output too.
                  Now initially, because of the noisy ground the capacitors in the CLC's were removing only a small bit of the noise. Lower ESR caps resulted in even less noise filtered through which shows higher ESR general purpose caps caused the noise reduction purely from their inherent resistance. I swapped in the bigger transistor (MJE3055T) without much change at all which shows the base current is too low still *shrug*
                  Went back to square one and started looking more into the transistors and figured that if a 2.2k resistor helped with noise but 1k let more in and provided more current there should be ways around it. Needless to say.. apparently feeding the AC noise from the Emitter output to the base with a Rubycon MBZ 16v1500uf removed a good 80% of the noise and output was higher than before. However, being NPN transistors with a common base ended up causing a small bit of clicking as if a 2 clicks/second pulse was going off.
                  It then hit me.. wait.. the ground is noisy and we're still getting noise feedback from all this so why not just the decouples to ground? I then for the heck of it tried decoupling the output to the transistor base.. and it made quite some difference. I removed the ground altogether from the filter removing the potential for a ground loop in this case and... the noise is drastically reduced now which made every capacitor but the one disconnected. Output is also up and better regulated now bottoming out around the low-end of 8volts rather than 5v on full load. Might end up returning to the idea of a pi filter after the emitter now and using the transistor base as the ground as that's working good for that purpose.
                  Then after might consider adding a third transistor (2SC1213) or try it now with just the one MJE again and see how it goes.
                  Afterthought: This is turning more into a discussion about power supply troubleshooting than anything. Perhaps I should split to another thread or just move this to the appropriate forum?
                    • 31087
                    instead of filtering the noise, why not try to find and kill the source of the noise.
                      Do you have scope so you can probe the power supply line and the outputs to see what kind of signal you are getting?
                      • chozo4
                        Nothing Special
                        • 134
                        I know the fan noise is from the two fans on voltage control over the fan headers. The other noises are from the mechanical HDD activity and other miscellaneous signal noise from other case components.I'm being picky mainly since the noise is AC and making its' way through power into the amp and being amplified as it's a single rail amp. While I can take the fans off the headers and put them on the fan controller that leaves out individual speed control through speedfan. The rest of the sources there isn't anything I can do about otherwise.
                        That's one thing I don't have. All I have at my disposal is a cheap multimeter by GE (GE2524) and no other utilities but headphones to listen in on the noise in this case.
                        • chozo4
                          Nothing Special
                          • 134
                          .. I'm not sure how spot on my multimeter is. but it could be the PSU over time ended up with poor regulation. After I get back in a month or so from overseas I'll have to look into a potential RMA if it gets any worse as I'm leaving in a week. I just checked the +12 supply rail and it's regulating a bit high at 12.30~12.86v which is close to being out of the 10% spec. I have a 7 year warranty so figure heck with it. Instead of recap just get it replaced and see if that makes much more of a difference.
                          [hate adding an additional post due to the 90 minute edit timeout x.x sorry!]
                            master hoarder
                            • May 2008
                            • 12175
                            Nice project!
                            So you using this to amplify a microphone? Also, what are you intending to drive with this amp? Headphones or speakers? If it's the former, the amp probably won't be loading the V+ rail too much, so you can add a simple passive RC filter (which is similar to LC, but I find these easier to design). Depending on the load, something like a 10 Ohm resistor is series with the V+ rail followed by a 1500 uF cap should filter a ton of noise. Its cut-off (-3dB) frequency is 10 Hz, so anything above that should be attenuated quite a bit.
                            Personally, I find this tool very useful for designing simple filters on the go when I don't have Multisim available at my disposal (or other circuit design software).
                            By the way, is there any way to turn down the voltage gain on the TEA2025B? (actually, I can and probably will look that up in a little bit, just out of curiosity). If you don't need the voltage gain that high, I suggest turning it down to a suitable level - this should help to further reduce some of the noise.
                            Anyways, keep us updated with your project. I really do like home-built audio projects.
                            Hope you don't mind me asking, but where are you traveling to?
                            • chozo4
                              Nothing Special
                              • 134
                              To update, the noise issue has been completely resolved... and took me 3 days to realize I had it right the first time. I also derped and forgot that I changed out sound cards to a different one that was causing additional feedback noise. Apparently the YMF744/754 chips are a lot more noisy than the YMF724 chipsets. The only similarity between the 744.754 I can see that would cause noise is them both using puny 0.2w amplifiers that pick up a lot of background noise. The 724 doesn't and lets you bypass the amplifier so no background noise at all. Switching back removed the extra minor background noise leftover after the noise reducer that it couldn't possibly remove otherwise.
                              The end result is a minor variation of the 'capacitance multiplier' circuit but the ground is the output instead so it is in no way isolated but rather reduces noise through base feedback. There is only a 1.1v dropout with this method as per the saturation voltage on load. Reducing the resistor more results in little to no reduction of the noise due to breaching the saturation gap.
                              May try with a lower saturation voltage transistor at another time to be able to increase voltage output more without using an LDO. it only takes 3 components being a 150ohm 1/8w resistor, 16v/270uf Polymer cap, ST MJE2055T BJT. Will look into replacing the MJE with a 1A+ TO-92 package BJT to reduce size as the 2SC1213 using this method isn't providing enough output unless I double them up.
                              Also, in reference to my previous statement about the PSU overshooting voltage... my multimeter was way off. The 9v battery needed changing as the bios and other sources show the +12v at 11.98v *shrug*
                              Originally posted by momaka
                              Nice project!
                              This is intended for powering a pair of generic 4ohm 1-way stereo speakers I found on the curb aeons ago. Built one so I won't have to use the one on the soundcard anymore and so I can use it with any other input source. I will eventually rebuild it for dual output bridges down the line however when I salvage another TEA2025B. At that point I may just integrate the noise filter onboard as well with smaller components as well without increasing size. Only so few sources of old soundcards to get them from as the original Malaysia (not China/CHN) made TEA2025's are long out of production. What bothers me though about the idea of using a TEA2025b in bridge mode in that there is no output capacitor specified to prevent flow of DC through the headphones. In this case should I be concerned or would putting a capacitor on the positive output have any negative impact on output while blocking DC?
                              I also found a pair of full -size 'MCS Series' 3-way studio speakers from back in early 80's made by JCPenny that I eventually intend to use with it too. Tested them and they work fine aside from what sounds like one of the braces inside broken off as shifting one of the speakers causes rattle. Chassis is made from particle board while the front mesh is molded to it and not removable. Must have been on of the cheapest bottom line speakers of their series.
                              The output voltage is normally 1/2 VCC but the gain is adjustable with a resistor in RC Series from the feedback pins to ground. I actually cannot understand the math behind figuring out the actual gain after adding a resistor or the cutoff of changing the capacitor. According to specs it shows R=0, C=100uf for 46db/32hz cutoff yet in my case I used R=562, C=220 to reduce gain and lower the cutoff point for low frequency so as to increase the bass response as well. I'd love if anyone can help me figure the gain/cutoff point result.
                              I did however build a microphone amp with a tiny footprint based on an ST LM358N that I salvaged from a thermistor based fan speed controller in old power supply years ago. Still does the job quite well.. can't say the same for the controller I salvaged it from though as the transistors on it could burn someone from touch.
                              I tried the RC (and CLC) filter method but the ground was causing heavy noise as well due to an AC ground loop between both power ground and input ground. I've actually never really used a simulator before. I tried SpiceLT but couldn't wrap my head around it at all and I'm more of a trial/error person when it comes to figuring things out.
                              As for you asking where I'm going - Bangkok/Thailand for a month due to needing surgical work is all I'd be willing to divulge publicly. Feel free to PM me if you have any further questions regarding it however.
                              Added attachments regarding the MicAmp mentioned. Also showing the final results of the amp with heatsink. Heatsink is mounted with a thin layer of ArcticSilver5 Thermal paste and fastened down tight with copper wire soldered down to the two outward ground traces closest to the resistors. This will also indirectly assist in more effective heatsinking along the ground traces and mounting wire accordingly. Solder work isn't the best considering the generic general purpose PCB from radioshack but the best I can get for the final build on the TEA2025. Had to be extra generous on cleaning up the PCB with 91% Isopropyl Alcohol, Swabs, and a Toothpick considering my flux is Zinc Chloride and made from the early 19th century, using silver bearing solder without a flux/rosin core. Had to use a microfine soldering tip made for a generic 20/25w iron fitted into a 30w and a blunted pencil-tip for the bulk work on flowing the ground traces.
                              EDIT: Interesting side note... I think I've built the smallest over-spec TEA2025b based amp despite far wider capacitors and no SMD's compared to the Chinese made tea2025b amps that meet or underspec the capacitors one finds all over Alibaba/Aliexpress, etc. If one wanted to the whole built with heatsink could be reduced down to 10.5mm height with lower height caps only sacrificing capacitance on the output and power decoupler. *scoff* Watch them steal the build and resell it next...
                              1) [FILE] ST-TEA2025b Datasheet
                              2) [IMG] ST-LM358N MicAmp Top
                              3) [IMG] ST-LM358N MicAmp Quarter
                              4) [IMG] ST-LM358N MicAmp Bottom
                              5) [IMG] ST-TEA2025b Top w/ Wakefield 650b Heatsink
                              6) [IMG] ST-TEA2025b Quarter w/ Wakefield 650b Heatsink
                              7) [IMG] ST-TEA2025b Bottom w/ Wakefield 650b Heatsink
                              • lti
                                • May 2011
                                • 2553
                                What's wrong with the newer TEA2025Bs?
                                The DC offset on each output is almost the same (within millivolts), so there will be almost no DC offset across the speaker in bridged mode unless the chip has failed.
                                I don't see why you would remove a TEA2025B from an old sound card just to make a low-power amplifier. What's the advantage to that over something like a TDA1517, aside from being able to run at a lower voltage?
                                • chozo4
                                  Nothing Special
                                  • 134
                                  Thanks for the information regarding the DC Offset as that's good to know.
                                  Nothing particularly wrong with 'newer' TEA2025B's other than the fact that the ones I find 'new' are all from china with the same datecode showing as carbon copy knockoffs. While it's more so just peace of mind it's better to know that I'm able to use one from an otherwise broken/non-working soundcard so as to recycle/reuse than a new one of potential dubious quality. The soundcard I have with it onboard I still use so just in case I still have that backup available. Considering counterfeit components and the same/non-standard datecodes I don't want to risk getting relabeled/rebranded chips. Keeping in mind that ST dropped production of the TEA2025B long ago and has marked it as obsolete despite still being produced in china.
                                  As for not using something like a TDA1517.. while I have one sitting around on a working soundcard I would rather not pull from a working unit. That and I use the Tea2025b because it's the amp I've been most familiar and happy with for the last 15-16 years so I like how it sounds. Further... it's what I had on hand. It fits the overall size I'm aiming for as the TDA1517 is a bit larger than I would like for the intended purpose unless I were to physically remove the heatsinking portion from it.
                                  It also has a special place in my heart in a sense.. (yeah - sad to get attached to an OPAmp series and brand but... I did).
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    Quite frankly, you'll never use the TEA2025 again once you try a LM1877. That too can be found on old soundcards, albeit rarer. It was the cat's meow in low power amplification in that day. I made a headphone amplifier using it... I know, way overkill, but you can never have enough bass. I also used it as a line driver in more than one occasion when the output signal of my laptop didn't cut it.
                                    • lti
                                      • May 2011
                                      • 2553
                                      It looks like everyone discontinued these low-power amplifier chips. They were manufactured for a long time, so you shouldn't have to risk buying fake chips from China. The only one left is the LM386. Everything else I see on DigiKey right now has a minimum supply voltage of 10V or greater. If you want something small, maybe you could try an LM380.
                                        • 31087
                                        i cant find a cheap source of lm1877 anymore!
                                        i used to use them to replace dead lm377 in space-invaders machines!
                                        • tony359
                                          by tony359
                                          11-28-2023, 05:18 AM
                                        • MegaZAC
                                          Onkyo TX-SR805 noise in one channel
                                          by MegaZAC
                                          Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                                          Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                                          There's some logic behind it. As soon as I select an input I get only left...
                                          04-23-2025, 10:09 PM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • courtcircuit
                                          Philips HTS8000 home cinema noise problem
                                          by courtcircuit
                                          Hello
                                          I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                                          Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                                          Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                                          I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                                          Removed each of tyhe boards
                                          02-08-2025, 08:22 AM
                                        • karatzdi
                                          Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                                          by karatzdi
                                          I know some might say... just buy another one. Sell it as parts..!
                                          So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                                          Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                                          Spent some time downloading the Service...
                                          06-11-2024, 08:38 AM
