KENWOOD KA-701 POWERS ON, NO RELAY CLICK
This topic has been answered.
  • rccrasher65
    • Mar 2014
    • 621
    Haha! For an 1/8”
    Yep, cost me $24 for an 1/8in, 2 carbide dill bits I'll probably never use again.
    • CapLeaker
      Leaking Member
      • 8176
      Could be worse. Not sure when I get back to the TIG, but it’s not happening the next 2 weeks… maybe on the weekend. It’s firewood splitting time and got to mow my fields off.
      • rccrasher65
        • Mar 2014
        • 621
        Yea, I haven't got much done here, I still have a few components I want to check out before I test. Father's day weekend coming up too. Probable get back at in a few days. I hope you get all your work done as well. Have a great evening.
        • CapLeaker
          Leaking Member
          • 8176
          Yeah… more BBQ and on the weekend. Work was crazy today. I did cheat and started mowing, but must my blades are so dull, I might as well mow grass with toe nail clippers.
          • rccrasher65
            • Mar 2014
            • 621
            Yea, I can't wait , my daughter makes a fantastic steak , and shrimp. Wash that all down with a cold one. Relax! That's my plans. Get out that grinder, and file, sharpen
            those blades, makes it easier on you, and that mower. Have a great Father's day weekend. I'm going to get a few more components this afternoon. I'll let ya know what I find.
            • CapLeaker
              Leaking Member
              • 8176
              i figured out why my mower was mowing so shitty. The blades were bent! Had to order a couple of new ones. Funny you say shrimp... The last time I made shrimps, the whole table got quiet, no left overs and got request as birthday meal. lol
              • rccrasher65
                • Mar 2014
                • 621
                Steak, and shrimp one of my faves.Daughter does it outside camp style, open fire, baked potatoe in fire, so good with Ice cold beer. Did you get any vibration with those bent blades.
                • CapLeaker
                  Leaking Member
                  • 8176
                  Yummy… yeah… I bought a bag of shrimps. Surf ‘n turf… with shrimps, steak, a baked potato and an ice cold beer? I am coming down for a visit. lol.
                  • rccrasher65
                    • Mar 2014
                    • 621
                    You're welcome to anytime. Plenty to go around. Bring my favorite with you, some Crown Royal. I got a few things over the weekend done. Replaced some caps on the Power supply, and a few that have that corrosive glue all over the place, mostly the big caps. Some on the control board. Then re check the components we changed, then I'm testing on dim bulb. Praying for a successful test.
                    • CapLeaker
                      Leaking Member
                      • 8176
                      I’ll keep my finger crossed that all your work paid off!
                      • rccrasher65
                        • Mar 2014
                        • 621
                        I hope so as well, don't know what else would be wrong, I changed everything, bad, plus! We will know this week!
                        • rccrasher65
                          • Mar 2014
                          • 621
                          Do you know if the tester I use, can test components in circuit? It's the FNIRSI.
                          • CapLeaker
                            Leaking Member
                            • 8176
                            Components as MOSFETs, BJT’s etc have to be always out of the circuit. Even with capacitors it depends on the circuit. I am using the Peak DCA Pro and even with that the component has to come out.
                            • rccrasher65
                              • Mar 2014
                              • 621
                              Yes,I just did a little more research, and no, all components must be out of circuit, reason I asked I wanted to check those white plate resistors behind the 4 big main filter caps, hard to get anything back there. I'm not suspecting any damage, but just want to be sure!
                              • CapLeaker
                                Leaking Member
                                • 8176
                                Resistors? Just use your DMM?!
                                • rccrasher65
                                  • Mar 2014
                                  • 621
                                  I will, two of them are directly under the heat sink, can't get to them easily.
                                  • CapLeaker
                                    Leaking Member
                                    • 8176
                                    Odd place for them to be right under the heatsink where you hardly can get to.
                                    • rccrasher65
                                      • Mar 2014
                                      • 621
                                      Yea , every thing is packed in pretty tight, just behind filter caps, and heatsink. I have a pair of long clip on grabber leads, so I think I'll be able to get at them. If not I'll just remove the caps , and replace them now , instead of later.
                                      • CapLeaker
                                        Leaking Member
                                        • 8176
                                        I think it's time to replace now, rather than later... just saying... you put this much effort into the amp, a few new filter caps wont break the bank.
                                        • rccrasher65
                                          • Mar 2014
                                          • 621
                                          I have the caps, I guess I'll replace them now, makes things so much easier. I'll have to delay the dim bulb for a few more days, getting anxious now. I'll have some pics of my work as well. When I'm done that is.
                                          • jm1234
                                            9V relay temperature 40C
                                            by jm1234
                                            Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                            I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                            05-09-2024, 03:03 AM
                                          • edugimeno
                                            Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
                                            by edugimeno
                                            Hi everyone!
                                            I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
                                            I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
                                            This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
                                            To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
                                            I respected the polarity, positive to cathode of protecting diode
                                            So provided all...
                                            04-18-2024, 01:15 PM
                                            Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                            by sam_sam_sam
                                            I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                            The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                            Found shorted diodes on main controller relays there are 3 of them that...
                                            01-07-2023, 05:43 PM
                                          • DrDos
                                            Kenwood KR-6030 vintage stereo ,Old Man Trying to Save a Buck
                                            by DrDos
                                            Hello all. I'll try to keep this short. I have no knowledge of electronics. I can use a multimeter and am familiar with caps to some extent. I bought a Kenwood KR-6030 vintage stereo. It need work and so I thought I would recap the thing since I get power to the on switch but nothing else is working. No lights, no sound and so forth. I went to Mouser to order caps and I find I am way over my head. I not only do not know the type of capacitors I need but Mouser and digikey do not accept Kenwood part numbers. I have the info such as 220uF 63v and such but no place to put it. I could buy a recap...
                                            08-08-2025, 03:16 AM
                                          • DXseekerMO
                                            Backlight strip quality, Amazon vs Ebay vs ShopJimmy. Is there really a difference?
                                            by DXseekerMO
                                            Hello everyone!
                                            Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
                                            I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...
                                            Yes
                                            0%
                                            1
                                            All backlight strips are the same quality
                                            0%
                                            1
                                            No
                                            0%
                                            0
                                            12-16-2021, 03:58 PM
