KENWOOD KA-701 POWERS ON, NO RELAY CLICK
This topic has been answered.
  • CapLeaker
    Leaking Member
    • 8195
    Ouch!
    • rccrasher65
      • Mar 2014
      • 622
      hardened steel grub screw . try a reverse drill bit
      I'm going to look for a set that will fit , that tiny hole, but I think it's a little late for all that. I've drilled the hell out of it, but still won't let loose. I'll give it a try. Thanks
      • rccrasher65
        • Mar 2014
        • 622
        Ouch!
        Yep, had to walk away!
        • CapLeaker
          Leaking Member
          • 8195
          That’s gotta be glued in with something. Geez… drilling at it for 2 hrs and still no go? Something is holding it tight.
          • rccrasher65
            • Mar 2014
            • 622
            It could be, but I think Petehall is right, I'm using stainless steel drill bits, trying to drill hardened steel, not getting anywhere in depth because of wrong bit, going to try some carbide bits. The darn set screw is only 3mm in length. When I take bit out and measure depth, I'm not even half way. I'll keep at it, till I get it off, may take awhile. I think I'm a little to far gone to try a left hand drill bit.
            • CapLeaker
              Leaking Member
              • 8195
              Yooo… stainless steel drill bit? May not work very well. Cobalt would be better but hardened steel is hard to drill.
              • rccrasher65
                • Mar 2014
                • 622
                I ordered a set of carbide bits, should be here sat. Has anyone had this much trouble with this, or is it just me. In the mean time I'll go back and double check everything, I've done so far, with the components. I'll list all the bad one's that I found. I want to recap the unit, as an ultimate goal for this amp. I've been extra careful not to enlargen the small set screw hole, while doing this, it's at an 1/8in, just a tad larger than original hole by a 1/32, wanted to make sure I got the hole grub screw out, so I can re tap. Have a great weekend guys,and thanks for hanging in there with me, much appreciated. Maybe we can get back to fixing electronics instead of farting with drilling shit out.
                • CapLeaker
                  Leaking Member
                  • 8195
                  Troubles? Today at work I felt like I was surrounded by pussytouch idiots.
                  Hope that makes you feel better now.
                  • rccrasher65
                    • Mar 2014
                    • 622
                    All better now,unfortunately, we have alot of them, I call them entitled little bioches. Glad I'm retired, I couldn't, and wouldn't put up with that shit for to long.
                    • rccrasher65
                      • Mar 2014
                      • 622
                      Carbide drill bits arrived, I have a mini camera that I'm going to try and get a peak under that knob, and see what's holding up the removal. Drilling blind sucks, and could cause too much damage. I'm going to see if this will help see what's going on. I'll post those bad components this evening.
                      • rccrasher65
                        • Mar 2014
                        • 622
                        Well got a few more components to check, and I will be ready for a dim bulb test. Hope for no light, and good working amp. I will also list, all the damaged components I found. There wasn't as many as I thought 6 or seven, but I replaced alot, even if they were good. Caps, transistors, a few resistors, that were bad ,or burned up dark looking,but still working.Goinf to post some pics as well of the board.
                        • rccrasher65
                          • Mar 2014
                          • 622
                          Haven't seen anybody on here responding, Cap, you still with me. Pete you still here?
                          • rccrasher65
                            • Mar 2014
                            • 622
                            Here are the components that were found to be bad. First the two output transistors near Q11. The two were completely dead no readings at all when removed. Q11 was deemed to be ok, but with low readings. It was changed, as was all the rest. Q10, Q9, Q12. Q9 also tested ok ,but with low readings. Next were resistors R23, burnt black, open no reading.R1as well. R3, 21,5,19,6 were all dark and replaced. Transistor Q5 was dead as well as Q1. I replaced all 8 of them anyway. All caps were replaced, one tested bad, C 6. Those are the components that were found to be bad. I replaced all 4 output transistors to keep things even. I want to check a few more things before I use the dim bulb tester. I will post some pics of the board as well.
                            • CapLeaker
                              Leaking Member
                              • 8195
                              Yep, still here... just didn't pay attention as I got busy with other things and events at home. Working on a 160pin IC for a entertainment / control system for a BMW X5 right now.
                              • rccrasher65
                                • Mar 2014
                                • 622
                                Those are nice to do, love those multi pin Ic's, get to use hot air, and drag solder techniques. Monday I think will be the day I test the amp to see how we did. All the best on your project.Did you get that welder figured out?
                                • CapLeaker
                                  Leaking Member
                                  • 8195
                                  No... I was about to fiddle around with the programmable input and output pins, dragging them into the opposite direction on the ATMEGA and see if something changes on the blue LED or on the gas valve. I was hoping to find a problem with a pin, then backtracking the circuit. Then I was on the road and never made it back to the welder.
                                  • rccrasher65
                                    • Mar 2014
                                    • 622
                                    Guess what I got done in a few min, with the correct tool? Yep it's off no damage, now to retap.
                                    • CapLeaker
                                      Leaking Member
                                      • 8195
                                      Oyyy…. What tool did you use?
                                      • rccrasher65
                                        • Mar 2014
                                        • 622
                                        1/8 carbide drill bit, had to go another 1/8 in to drill it out. Came right off. All that bullshit for an 1/8in.
                                        • CapLeaker
                                          Leaking Member
                                          • 8195
                                          Haha! For an 1/8”
                                          • jm1234
                                            9V relay temperature 40C
                                            by jm1234
                                            Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                            I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                            05-09-2024, 03:03 AM
                                          • edugimeno
                                            Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
                                            by edugimeno
                                            Hi everyone!
                                            I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
                                            I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
                                            This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
                                            To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
                                            I respected the polarity, positive to cathode of protecting diode
                                            So provided all...
                                            04-18-2024, 01:15 PM
                                            Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                            by sam_sam_sam
                                            I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                            The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                            Found shorted diodes on main controller relays there are 3 of them that...
                                            01-07-2023, 05:43 PM
                                          • DrDos
                                            Kenwood KR-6030 vintage stereo ,Old Man Trying to Save a Buck
                                            by DrDos
                                            Hello all. I'll try to keep this short. I have no knowledge of electronics. I can use a multimeter and am familiar with caps to some extent. I bought a Kenwood KR-6030 vintage stereo. It need work and so I thought I would recap the thing since I get power to the on switch but nothing else is working. No lights, no sound and so forth. I went to Mouser to order caps and I find I am way over my head. I not only do not know the type of capacitors I need but Mouser and digikey do not accept Kenwood part numbers. I have the info such as 220uF 63v and such but no place to put it. I could buy a recap...
                                            08-08-2025, 03:16 AM
                                          • DXseekerMO
                                            Backlight strip quality, Amazon vs Ebay vs ShopJimmy. Is there really a difference?
                                            by DXseekerMO
                                            Hello everyone!
                                            Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
                                            I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...
                                            Yes
                                            0%
                                            1
                                            All backlight strips are the same quality
                                            0%
                                            1
                                            No
                                            0%
                                            0
                                            12-16-2021, 03:58 PM
