I am seeing most major capacitor manufacturers have come up with a different series which are marketed as "for audio". Like Muse. What exactly is special or different about these capacitors then the rest ?
What are "for audio" capacitors ?
Re: What are "for audio" capacitors ?
mostly the price
here is some details
http://www.acoustic-dimension.com/bl...e/techEcap.htmLast edited by willawake; 12-13-2006, 10:36 AM. -
Audio capacitors need to have electrolyte which doesn't have magnetic particles in it.Rubycon Rubycon RubyconComment
Well, there is more abouth the price.... Audio caps do not have that a deeply etched aluminium foil (reduces capacitance, but improves the frequenzy liniarity ort something else...), some have additionall layers of silver or thin foil to avoid coupling.
Duno if that is realy something wich cout`s in real world, but those enthusiast may hear the difference.Comment
Black Gate's are regarded as some of the absolute best electrolytic caps for their application and are often used in power stages for headphone amplifiers or preamps when people are trying to create clean power, while the non-polarized versions are sometimes used in signal paths/crossovers, but even people who use them will admit that if ever possible you should avoid using an electrolytic capacitor in a signal path. Electrolytics are considered one of the worst things for an audio signal to pass through by many. Typically, they are only used when low cost is needed or space requirements have to be met or because of the amplifiers design it's simply impossible to find a cap with the needed capacitance in anything but an electrolytic.
Non-metallized Polypropylene Film are the standard high end cap for signal paths. The drawback is that as a rule they will never be anywhere near as large in capacitance as an electrolytic, will be far larger in size and will cost a whole lot more.
Trying to find a 100uF polypropylene film cap is a joke. The highest you will see is usually 10uF, with some exceptions. Moving to metallized polypropylene you can find 100uF and even 200uF, but you'll pay at least $20 a cap and they are always gigantic axials averaging 50mm in one direction and about the same in the other.
For someone trying to eek out every last bit of quality of their audio equipment, this is worth it. Even crazy things like silver in oil, blah blah crazy caps that cost over $100 each. But the cost vs. return is laughable.
Muse caps are tantalum? Tantalum is not regarded as audio quality, but then Muse' are only listed as a solution for mobile audio which is never regarded as quality either.Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700Comment
interesting info. who has first hand experience in this stuff?Comment
Well, I do know that Tantalums suck for audio... I've replaced tons of them on jukebox amps with Panny FC's after the tantalums caused all kinds of trouble, mostly random static from DC leakage.Comment
not that I have looked into it in any big way in a very long time
There would be true technical reasons as to why a particular cap construction would be better for audio use.
you are dealing with a band of frequencies from 20 Hz to 20Khz
So (mostly) you want them to be transparent to the this and not "colour" the sound (using visual terms for audio...why do we do this?)
How well or how much this is going to effect audio is another story, and were the controversy begins I suppose
So a lot of these "Audio" caps will be more Hype for $$$ and small return.
(as more or less stated above)
But there are types of caps that are better for audio use as pointed out in previous posts and probably some manufacturers may have tweaked them for this application without getting into the hype side of things
herer a link on Capacitors,
it is technical and this site is into Audio but at a technical electronics level
The author does put it in a more lay terms way so it shouldn't be hard to follow.
Here
section 2.4 is probably more relevant here and have a read of 7.0
Main Page HERE
Another page I found Here
Can't seem to find the main page on this one
it can all get quite a bit controversial
Sound is a personal thing I think...find what makes you happy and be happy
When you think most of the world seems to be happy to listen to MP3's through ear buds you have to wonder were audio is going anyway
HTH
CheersYou step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...Comment
For decoupling, you want caps with good linearity but this is often claimed for more than it's worth. It's fairly trivial compared to whether the circuit requires any pariticular level of filtration, has everything to do with the noise frequency on that rail (whether upstrream or induced by the active, powered parts on the rail).
For coupling you want caps with low loss. With small signals, loss matters more than capacitance (given enough capacitance that it doesn't become a high-pass filter), so some construction differences emphasize low loss instead of max capacitance. This is done while simultaneously striving for the higher capacitance of electrolytic caps. If you don't need that high capacitance you're still better off using any generic industrial grade film cap instead of an audiophile grade 'lytic.Comment
As a practical matter, you can get good results with fairly inexpensive caps. Elna Silmic RFS/ROS caps are usually great in the signal path. Lower voltage parts are usually better, if the circuit topology allows it, because the foils are spaced closer. In a pinch, Elna general-purpose RE2/RE3 caps are also acceptable. Bypass/decoupling is great with Panasonic FC/FK (I've recently tried FJ, which offers greater capacitance in the same space, with acceptable results).
If you want to experiment without risking anything expensive, take apart an amplified PC speaker set and try replacing the caps - there are usually no more than 5/6 caps to pay around with, including the main PSU filter cap, 2 DC blocking caps for the speaker, and a few coupling caps. Try out the alternatives one at a time, re-assemble, and listen carefully after each mod - you'll get a feel for what is acceptable and what is regressive.Comment
Originally posted by starfury1When you think most of the world seems to be happy to listen to MP3's through ear buds you have to wonder were audio is going anyway
Originally posted by 999999999If you don't need that high capacitance you're still better off using any generic industrial grade film cap instead of an audiophile grade 'lytic.Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700Comment
The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
The player processes the audio signal using two different reference frequencies. The "R"...2 Photos -
by dragon3xHi, I have some 32 bits computer motherboards that need repair, as they fail to
power on.
Here are some examples :
switching supply area).
than 6.3 V.)
3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA... -
by myth77So, laptop was with dead cpu, replaced. Now everything works except i have problems with audio. The problem is related with long audio cable that from one side is plugged in the motherboard and on the other side is connected to audio daughter board that goes on the top of the laptop(behind screen). The symptoms are:
1. In bios everything ok (with long audio cable on connector j3701 connected or not),
2. With windows installed everything ok if long audio cable on connector j3701 is not connected,
3. With windows installed and long audio cable on connector j3701 is connected... -
by slybundahey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
it has inside:
2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
2 x 470uf 16v LZ105c branded as G.Luxon
not heard of these brands are they any good?
iv attached photos of the charger and the board inside for an idea on the type of...-
by grimacelordHello,
I'm working on a MacBook Air A2337 that had liquid damage on the right I/O board. I ultrasonic cleaned the board and it all functions except the computer has no audio. I tried reballing the audio IC which is TAS5770AC0, but that did not restore audio. I could just replace the entire board, but I wanted to see if replacing the audio IC would fix it first. Mouser has a similar audio IC in stock which is TAS5770LC0YFFR, but I wasn't sure if it is compatible. I was just wondering if anyone knew if I could use the one from mouser as an acceptable replacement or if I need to purchase...12-11-2023, 11:13 AM - Loading...
