Genius SP-HF1250X - 2.0 speakers
  • bocca
    • Mar 2012
    • 107
    • Serbia
    Hi all. First post in this section
    My home speakers died recently.
    First of all here are the specs from the official website
    What's going on?
    Well, one morning i turned on the speakers and there was a incredibly loud buzzing sound. Constant, deep and vibrating. Almost exactly the same as when you touch metal part of the computer case with the audio jack, but way louder.
    I tried everything... Unplugging speakers from computer, changing cable, unplugging left speaker from the right (problem is in the right and main one), problem stays. As soon as it gets the power it starts with the noise and that's it.
    So... I unscrewed it, and took some photos of the board for starters
    Re: Genius SP-HF1250X - 2.0 speakers
    What are mounted on that heat sink? Transistors? need pictures of the whole board, top side.
    • bocca
      • Mar 2012
      • 107
      • Serbia
      I don't kknow what these are, but here's the pic attached
      • bocca
        • Mar 2012
        • 107
        • Serbia
        first two pictures are topside of the board. 1st is above the heatsink, and the second one is below.
        But I'll make one whole, just to get my camera. Iphone camera will not do. Flash messes everything up
          That is the power amplifier IC TDA2030, there should be two of them for 2 channels.
          The 8-pin IC is more likely to be dual-op amp (generic 4558 IC) for the preamplifiers to drive the power amps which drive the speakers.
          The noise is from both speakers?
          • bocca
            • Mar 2012
            • 107
            • Serbia
            Yes, there is two of them, sharing the same heatsink. 8pin IC indeed is 4558.
            I think the noise comes only from the main speaker but I have to check it out as soon as the afternoon nap passes Small apartment, can't wake everyone up
              If just one speaker is making noise, then the problem can be the power amp IC or the dual op-amp, but look real close at the solder joints first.
              • bocca
                • Mar 2012
                • 107
                • Serbia
                well it's generally sloppy soldering job... I'll do all the joints again and see if it helps
                thanks
                • bocca
                  • Mar 2012
                  • 107
                  • Serbia
                  joints redone, checked, but to no avail...
                  Plugged in the speakers again and noise definitley comes from both
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    Try desoldering the OPAMP chip and see if there is no hum.
                    Muh-soggy-knee
                      Do you hear the noise with the Volume control is all the way down? You can also try heating or cooling the OP-Amp to see if it does have any affect on the noise.
                      One thing I do not see are the Cotrol panel board pictures, there should be some Op-amp for the Bass/Treble controls circuits.
                      • bocca
                        • Mar 2012
                        • 107
                        • Serbia
                        I changed the op amp yesterday with brand new 4558. When i seitched everything back on noise was way quieter for about a second and then it was back on the loudest.
                        I guess it's not the op-amp
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          Perhaps a smaller filter cap is bad, causing the thing to self-oscillate.
                          Muh-soggy-knee
                          • bocca
                            • Mar 2012
                            • 107
                            • Serbia
                            well, i replaced both power amps, and all the smaller caps (9 of them, 2 types). Results - tonight
                            thanks!
                            • bocca
                              • Mar 2012
                              • 107
                              • Serbia
                              no changes Only thing I didn;t replace are resistors and two big capacitors. I'm out of ideas
                                I still do not get the response if the noise is there no matter what the Volume control or tone controls are set to. Are there more than one OP-AMP? Some thing bad that is common to both channels.
                                • ben7
                                  Capaholic
                                  • Jan 2011
                                  • 4059
                                  Most likely the resistors will be fine.
                                  I would be surprised if the rectifier bridge diodes are bad, although they might be cheapo-chinese rubber electrode ones.
                                  Of course I'd replace the main filter caps also, if the rectifier is bad then the caps could be damaged also.
                                  Can you take out the diodes and measure them with a diode-checker? (I'm referring to the big black ones)
                                  Muh-soggy-knee
                                  • ben7
                                    Capaholic
                                    • Jan 2011
                                    • 4059
                                    On a side note, did you replace these caps did you?
                                    They are used in the voltage regulator for the LM4558.
                                    Muh-soggy-knee
                                    • bocca
                                      • Mar 2012
                                      • 107
                                      • Serbia
                                      @budm:
                                      I'm sorry. Somehow I completely skipped answering you. Yes, noise is there no matter what volume, bass or theble setting are.
                                      @ben7:
                                      I'll take them out today when I get to work and post the results.
                                      As for the second post, yes, I replaced those 4 caps after I changed the LM4558.
                                      • ben7
                                        Capaholic
                                        • Jan 2011
                                        • 4059
                                        @budm:
                                        @ben7:
                                        Do you have visual access to the speakers? If so, when you first plug them in, does the speaker cone suck in, and buzz? or does it push out? If they do one of those, unplug them immediately because there is DC voltage being fed to the speakers, and they wont do well with that!
                                        Ok, do you have a multimeter?
                                        If so, put your black probe where the black circle is, and measure each spot marked in red with the red probe. One should measure anywhere from 15v to 5v, and the other should measure anywhere from -15v to -5v. Please report back the readings.
                                        Muh-soggy-knee
                                          Philips F9217L-50R speakers – build quality impressions and DIY surround repair
                                          by momaka
                                          More Lo-Fi speakers and another DIY surround repair. The patient this time: a pair of Philips F9217L-50R speakers from a budget Philips rack/component system from the '80's. The system belongs to my brother in-law… or actually his parents. However, they didn't want it when they moved houses and he liked it anyways, so he ended up keeping it. It's a pretty cool-looking vintage system with a wood/veneer cabinet and shelves for records and cassettes. Unfortunately, I didn't get a chance to take a picture of it or get the model #'s (but maybe next time I visit, if anyone is curious?)
                                          02-15-2022, 12:43 AM
                                          Connect pc speakers to tv without 3.5 jack
                                          by nomoresonys
                                          Currently trying to connect pc speakers to 2015 vizio tv, tv has no 3.5 headphone jack. Does have rca audio out, tried connecting thru a Y rca to 3.5 cable but getting odd results(probably just need a dac for decent audio, not sure?) not too educated on audio. With that hookup I'm getting 2 problems, can't get the speakers to increase in volume so it's very low even when turned up and when using both tv and pc speakers the pc speakers only put out the music part of the broadcast and not the vocals/talk of the program. Have you run into this before or know what it might be, Thanks.
                                          09-19-2025, 05:17 AM
                                        • Widget
                                          Logitech R20 speakers - Replacing one of the speakers.
                                          by Widget
                                          Hi guys,
                                          I have a set of Logitech R20 speakers, one of the speakers wasn't working, so I took it apart & there was no continuity or Resistance when probing the Tinsel Wires. Plus looks like the speaker was exposed to liquid as there's rust on the metal speaker frame.
                                          Just in case, I removed the other speaker and installed it in place of the damaged speaker to make sure the PCB of the damaged speaker was ok & it seemed to work fine, so it looks like it's just the speaker for now.
                                          Printed on the back of the Logitech speaker is;
                                          LOGITECH...
                                          05-29-2024, 07:07 AM
                                        • RetroComputingGrotto
                                          Behringer MS16 Speakers - Low Volume on One Speaker
                                          by RetroComputingGrotto
                                          I've had a set of speakers come in with the fault of not powering on.
                                          I could hear something wrattling around in the speakers so we played a game called Guess What's In The Speakers! and this is what we found:
                                          1 random loose nut and part of a BIC Biro pen.
                                          After removing these foreign objects I plugged in the speaker and powered it on and found the volume to be quite low. On plugging in the other speaker it was very loud, but only out of the other speaker, this side was still very low.
                                          05-20-2024, 07:29 AM
                                          Acoustic Audio GX-400 speakers
                                          by momaka
                                          Part 1 - Acoustic Audio GX-400 build "quality"
                                          Not going to lie – this will be another silly audio post/thread. If you thought the cheap Panasonic Thrusters speakers I posted about last time were bad enough, then you are about to explore some new depths in lo-fi audio here. Ladies and gentlemen, I present you the Acoustic Audio GX-400 speakers... or speaker (only pictured one for better details )
                                          Before I continue any further, perhaps you might be asking why I even bother to post about such crap audio gear (let alone keep it). The answer...
                                          03-07-2019, 09:04 PM
