How to check an OP AMP in circuit
  • johnnydiaz
    • Apr 2012
    • 52
    I have a few OP Amps still in circuit and I'd like to check them. How can I do that? They are TL072CN & 5532DD Basically I have a preamp where one of the master outputs is not working so I'm assuming that its the op amp. So I basically want to test it. What else do you think it could be?
    Thanks,
    Johnny
    Re: How to check an OP AMP in circuit
    Do you have diagram of what you are working on? The TL072/5532 are dual OP-AMP, You should download the data sheets so you can see the inputs/outs pin of the IC's. You can start by checking the DC voltages first, Black probe on the metal chassis, Red RED probe to pin 8 (B+ supply for the Op-amp), then check pin 4 (B- supply for the Op-amp).
    • johnnydiaz
      • Apr 2012
      • 52
      I don't have a diagram for this circuit. When you say dual op amp do you mean two outputs? I'm looking at the pinout of the tl072cn and have a few questions? Are pins 1-4 are for output 1? Are pins 5-8 for output 2? Since one output is working and the other isn't is it possible that half the op amp has gone bad or does the whole chip go bad?
      In order to check voltage on pins 4 & 8 I will have to reconnect and power unit correct? What should the voltage be at these pinouts?
      Sorry but I'm a newbie and appreciate all the help.
        Dual op amp, mean one package has two operation amplifiers inside the package, each amp has two inputs (1 Non inverted input, 1 Inverted input), and 1 output. The power supply voltage can be as high as 18vdc. See the spec sheet (TL072 has the same pin out as 5532).
        Pin 1 is the out put for amp#1
        Pin 7 is the output for amp#2
        You will check the voltage with power applied.
        You can see example of the audio circuits in the datasheet.
        If you want to learn more about audio, check this site out.
        http://sound.westhost.com/
        check the ARTICLES button.
        • johnnydiaz
          • Apr 2012
          • 52
          OK so I tested the voltage and on pin 8 I got 15.60vdc & pin 4 -15.35vdc. I'm assuming this is within spec. What would be the next step?
            Ok, the voltages are OK. To find out where you lost the audio, you will need an oscilloscope to trace out the signal, but I do not think you will have one, it will be hard to do.
            So this tool will be your audio tracer. Do you have something like a PC powered speaker of some sort? If you do, you will have a make a small probe, that can be attached to the powered speaker audio input, the input will have left and right channel and one ground. The ground wire will be attached to the metal chassis of what you are working on, then you can use either the left or the right channel wire (you will have to cut the audio cable up to attach the home made probe to this cable). Just to be safe, you can attach 4.7K~10k resistor in series with the probe.
            On the amp you are working on, you will have to feed it with some audio to the input. Then you can use the probe to look at the signal output of the IC and see which output is bad. You will have to adjust the volume on the PC speaker to the desired level.
            • johnnydiaz
              • Apr 2012
              • 52
              I actually have a Tektronix 4 channel oscilloscope but doesn't know how to use it that well. I have a powered speaker which has a single input which I can use. I will have to find a resistor of the value. May I ask what the resistor will do in the circuit? Which pins are the signal input?
              • Radio Fox
                • Jan 2010
                • 281
                What is the make/model of the equipment you are working on?
                What Tek scope do you have?
                I have a 2445 and a 2445A
                Before I could afford my first scope, I used to use a Micronta (Radio Shack) Transistorized Signal Tracer. It is just a high gain amp in a box powered by a 9v battery. Very useful for fault finding amplifiers. I still have it on my bench.
                http://www.eham.net/classifieds/detail/306963
                ________________________________________________
                Invisible airwaves crackle with life
                Bright antennae bristle with the energy
                • johnnydiaz
                  • Apr 2012
                  • 52
                  The make is an generic mixer I don't know. I have a Tektronix 2465 oscilloscope.
                  • cadiman
                    • Mar 2010
                    • 397
                    If you are chasing audio signal any scope will work. A few beers and about an hour and you will be able to chase an audio signal.
                    As said above a scope will make life really easy for checking op amps.
                    What happens in audio is the input signal is small and any chip failure can just short out the signal and you won`t see anything.
                    I have removed the op-amp and check for signal in at the board if you don`t see anything.
                    • smason
                      • 1652
                      I have one of those. Used it about a month ago.
                      • 999999999
                        • Sep 2006
                        • 774
                        You don't necessarily need an o-scope for initial testing, simply apply power, supply input audio signal, measure for AC voltage at the opamp input and whether there's AC voltage at the output pin(s). If signal is getting to the opamp but not coming out, odds are it's the opamp to blame (or else a solder break but that's sort of rare for low powered circuits).
                        Similarly, all along the audio signal path you can probe for AC voltage with a multimeter to find where it stops.
                        • 999999999
                          • Sep 2006
                          • 774
                          ^ When I wrote the above, I took output not working to mean it's silent, not noise. If there is noise, measuring only an AC voltage won't tell you much, except whether it has the right voltage gain relative to the input based on the gain the opamp subcircuit sets it to have, if any.
                          • Radio Fox
                            • Jan 2010
                            • 281
                            Whatever instrument you use to measure the signal, the good thing about one half of a stereo amp not working, is that you have the working half to check against.
                            By putting the same signal into both channels, you can check the same point in the circuit for each channel to see where you are losing the signal.
                            • johnnydiaz
                              • Apr 2012
                              • 52
                              I finally changed the OP amp and now I hardly get any volume out. When I start to increase the volume I start to hear a few pops and static. I know my op amp is good what else could it be that is causing this?
                              • rievax_60
                                • May 2012
                                • 897
                                • australia
                                When everything is working right, feedback from the opamp output to the inverting input via feedback resistors, act to keep the 2 opamp inputs at the same DC voltage.
                                The opamp output should sit half way between the + and - rails.
                                With a split rail supply, +15V 0 -15V, both input pins and output pin should usually all measure 0VDC.
                                • S2udio
                                  • Feb 2012
                                  • 16
                                  Check all the dc blocking caps in the signal path...as you have a scope should take
                                  no more than a few mins to suss where the dead end is !
                                  Most of the time things ain't what they seem to be
                                  • Alimash
                                    op amp circuit function?
                                    by Alimash
                                    I am repairing a ups which doesn't turn on ,it has the following ICs:
                                    SG3525 used to drive inverter mosfets.
                                    couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
                                    A LM358 and TL074 for control mechanism and of course the uController.
                                    The SG3525 is shutting down every time the ups is turned on.
                                    I want your help to know the function of LM358 and TL074 in the system.
                                    I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
                                    07-31-2025, 07:45 AM
                                  • Astonished
                                    Fixing the Charge Circuit of the Batteries of the DC Motor
                                    by Astonished
                                    Hi friends of electronics
                                    What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                    The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                    Please help me fix this circuit.
                                    (the datasheet of the IC: https://pdf.datasheet.live/28...
                                    01-28-2025, 06:24 AM
                                  • rddube
                                    Lenovo L490 Ram voltage circuit malfunction
                                    by rddube
                                    Hello friends,
                                    Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
                                    I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
                                    07-15-2025, 04:41 PM
                                  • dreico33
                                    TL866 II Plus Check ID Error on various IC
                                    by dreico33
                                    Hellow guys , i really need your help here.
                                    Lately i have a problem with My TL 866 II Plus programmer, and to be more specific many times on various IC ( Winbond, Gigadevice Mx) i get Check ID Error while i am trying to read the IC. Has already been detected without any kind of problem, but the only to read them is to uncheck every time the "Check ID " option. After that i can read it erase it and re-program it only to get another error at then end saying that can not verify the programing went well so i have program failed. So i am trying to find out what is going on? I...
                                    11-04-2024, 03:13 PM
                                  • hasel17
                                    CH341a can erase and read but can't write and blank check
                                    by hasel17
                                    So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
                                    Code:
                                    Checking for blank...
                                    (Press
                                    10-26-2023, 06:20 AM
