CH341a can erase and read but can't write and blank check
  • hasel17
    • Dec 2021
    • Indonesia
    So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
    Code:
    Checking for blank...
    (Press Esc to cancel the operation)
    Blank check completed,
    checking time 8.555 sec.
    Blank check error at the address: 0 (0x000000)
    Erasing...
    Erasing completed.
    Loaded file TBT.bin 425984 bytes
    File size differs from size of the device!
    Check Sum: CRC16 = 0xE261, CRC32 = 0x64AC3876
    Writing...
    (Press Esc to cancel operation)
    Writing completed,
    Writing time 11.94 sec.
    Status Register1 = 0x00
    Status Register2 = 0x00
    Reading...
    Reading completed,
    reading time 8.562 sec.
    Check Sum: CRC16 = 0x0000, CRC32 = 0xA738EA1C
  • adamski1952
    • Oct 2021
    • 94
    • england
    Re: CH341a can erase and read but can't write and blank check
    Just a guess but maybe chip is write protected.
    Dont know if this will work but try using neoprogrammer click the dropdown on program ic and tick off protect.
    • mon2
      • 14761
      The file size is also not a match for this target. Are you sure you are working with the right flash device?
      What do you see in the read back buffer? Post a few bytes. Then try to write ‘55 AA’. Verify this wrote ok.
      • Benzohev
        • Jul 2025
        • Ukraine
        Try flashing with the program AsProgrammer
        • khaahk
          • Dec 2013
          • 827
          • Estonia
          The original problem was that TB controller wrote to the chip too often, to the extent that some of the chips were warned out. This might be the case, try another chip.
          • ahmedtou
            HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
            by ahmedtou
            help me please
            I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
            When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
            I will share all the details with you, including the disc information.
            Code:
            HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
            Current Profile: BD-R
            Disc Information:
            Status: Empty
            State of Last Session: Empty
            Erasable: No
            Free Sectors: 12,219,392
            Free Space: 25,025,314,816 bytes
            Free Time: 2715:27:17 (MM:SS:FF)
            Next
            08-27-2025, 08:49 AM
          • feherhollo
            WSON8 NEW Bios Chips READ, ERROR, ETC.
            by feherhollo
            I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
            I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
            For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
            11-26-2023, 09:33 AM
          • testaccgta
            Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
            by testaccgta
            Hi, everyone!
            I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
            I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
            09-01-2024, 08:24 PM
          • JoWed
            Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
            by JoWed
            Hello Community,
            I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
            07-01-2025, 09:32 AM
          • Haganai.NMWP
            GA-AX370-Gaming 5 BIOS chip MX25U12873F doesn't erase properly
            by Haganai.NMWP
            Hello
            I can't properly erase BIOS chip MX25U12873F.
            I can read it and write it, but before correct write, it have to been erased, but when I click erase program shows success, but when I try do blank verification I have message "chip disconnected".
            I use CH341A programmer with 1.8V adapter and clips.
            When I try read or write it takes 3~5 minutes and "run" LED on programmer is blinking. When I try erase, it takes up to 15 seconds, but "run" LED isn't blinking and after that, chip isn't erased correctly.
            06-01-2022, 06:43 AM
