Greetings to all i have a klh receiver that when i push the power button it turns on but shuts off. I hear the first click and the second click turns off. I took these pics of the boards. Its raining here in seattle and lighting was an issue. When i disconnect the colored ribbon the receiver stays on. The ribbon is the one in the pic. So i have figured that much out. My tools that i have are limited to a craftsman multimeter and a soldering iron. I would like to fix this and am up to the challenge if someone would guide me through this. I have successfully fixed and hp pavilion monitor, samsung plasma, and zenith plasma through your help and patience.
Klh r5100 turns on then shuts off
Re: Klh r5100 turns on then shuts off
By the pics, you have the signal cable and the power supply lines to the amp disconnected. What happens if you just have the power supply disconnected? Vice-versa?
Sounds like protection is interrupting the amp supply to prevent damage to the speakers. Check those output transistors for shorting or leaky and the drivers before them. The driver transistors are probably the (10 or 20) taller, half-round transistors just in front of the (10) output transistors. A bit of a side shot would help on relative sizes.
The white blocks are 5 watt power resistors at 22Ω. There are also power resistors at the feet of the outputs. Check all of those those for open or too high ohms.
A schematic would help us troubleshoot.
Toastveritas odium paritComment
Hi, I believe the white 5 watt emitter resistors are .22 ohms. Common values for those would be .1 .22 .33 .47 and would be marked accordingly.
Toasty is correct, it sounds like it is going into "protect" follow his advice and check all the output and driver transistors along with the emitter resistors.
Also check the power supply voltages with the cable on and off to see if they are balanced.
How many different speaker outputs are there? It looks like there should be 5.
Good luck
Jon BLast edited by Jon B; 11-19-2010, 08:33 PM.Comment
Yeah, the markings throw me off sometimes. The R takes the place of the decimal point.
R22 = 0.22Ω
2R2 = 2.2Ω
22R = 22Ω
A decent resistor marking guide: http://www.diyaudioandvideo.com/Electronics/Color/
by riko 656Hello everyone,
I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
Laptop Model:- Model: Lenovo Legion Slim 5 16APH8
- GPU: NVIDIA GeForce RTX 4070
- Main BIOS chip size: 32MB
- VBIOS chip size: 16MB
What I Have Tried So Far:- I
11-04-2025, 05:14 AM -
by StephenMacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
by mnciks11Hello guys, i need your help fellow brothers
Im diagnosing a Lenovo G80-50 laptop
ACLU3/ACLU4
Rev : 1.0
when you press the power button, the LED power light turns On and quickly shuts down, no display, fan spins a sec and stop. I haven’t seen any short so far.
PU908 (CPU POWER CORE CHIP) is getting hot the moment you press the power button, the laptop turns off very fast, i changed PU908, still im getting same problem, on output side of the 2 cpu power supply coil i get 1.6v and then goes away as soon as the laptop turns off, still the... -
by ZixuTechSeems like we are dealing with a case of a corrupted BIOS after Intel Driver software attempted to flash the bios (haven't seen that before). The customer reported seeing a BIOS message while the screen was flickering during the Intel Display Driver installation. This was while the BIOS WRITE lock jumper was in place. Resulting in Loop restarting.
Afterwards, the customer attempted flashing BIOS via USB stick, resulting now in turning and immediately shutting down unit NUC8I7HNK4.
Under the thermal cam, I can see that the CPU is initiating a heat signature for a second...-
by wwwI am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....-
- Loading...
Hello everyone I came home from vacation and went to work the next day. When today I went downstairs to work on this thing and my wife chucked it in the garbage. So I guess I will no longer need help. Thanks
