Philips CDM4-mechanism
  • Xenon-Codex
    • 185
    • Finland
    Two totally different cd-players, but the mechanism was almost plug and play, only needed to change the connector for the spin motor. Technics SL-PJ28A -> Marantz CD-40.
    Note: SL-PJ28A is more different with identical looking SL-PJ28 than the Marantz...
  • Xenon-Codex
    • 185
    • Finland
    Re: Philips CDM4-mechanism
    Is there any adjustment, sometimes it skips a bit when "cold" while playing CD-R's. No skips when it has been on for a couple of minutes.
      • 31077
      that will be a capacitor,
      they have better performance when warm
      • Xenon-Codex
        • 185
        • Finland
        Where's that cap? I got the player as it would not play to the end, and made some clonking sounds. I can still hear those occasionally.
        • UNITRAX
          • Jan 2023
          • 64
          • POLAND
          https://www.diyaudio.com/community/t...sports.372412/
          Page one, post three
          • Xenon-Codex
            • 185
            • Finland
            Changed the cap to 22u (which the old one was), but first it went only worse. The original cap had 6% Vloss. Then I changed to 47u which was in the service manual, it seem to work better.
            • Xenon-Codex
              • 185
              • Finland
              It was the clamp. I managed to move the fault to another identical Technics, only by moving the clamp. It had a dip in the middle of the small plastic thing which should be smooth.
              • G33RT
                Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                by G33RT
                Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                It does power up when pressing the power button.
                I already try the power button while plugin the plug with no result.
                Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                Could this be an PSU or eMMC issue ?
                07-19-2025, 03:43 AM
              • acedogblast
                [Marantz SR5012] Center channel keeps going into ASO/Overcurrent protection.
                by acedogblast
                First off I would like to thank this community as it has provided me with great information that has helped me greatly on my repair for this Marantz SR5012 AV receiver. I am creating this new thread as the other 2 that I have created here has had their original question/problem solved and I plan that this is the final thread on my repair. Please note that this is my first time repairing audio amplifiers so I may not be aware of common issues and things to know.
                Lets start at what I have done so far. Random speaker popping on all channels is fixed by replacing the 2 large filter...
                03-01-2023, 08:24 PM
              • double_DD
                Philips curling iron - is this a common AC cable?
                by double_DD
                Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                08-18-2025, 10:04 AM
              • janos6662000
                Philips 47PFS7509/12 LCD TV problem
                by janos6662000
                Hi
                I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                When i applied cable signal to check image, i had normal picture, but TV was restarting.
                I downloaded original firmware and applied the update, but the problem remained.
                From a colleague i received a "factory package software" which is a lot bigger.
                I made another firmware update, but still did not solve the problem.
                Somewhere on the way the error got worse, because at the moment the...
                08-12-2025, 12:54 PM
              • aidanmo
                Philips 43PUS7506/12 - Loud blown out sound
                by aidanmo
                I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                I thought maybe the speakers got damaged, so I replaced them - no dice.
                • Using the internal speakers, it always happens.
                • Using the headphone jack, it never happens.
                • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                02-28-2025, 03:13 PM
