Philips CDM4-mechanism
  • Xenon-Codex
    • 185
    • Finland
    Two totally different cd-players, but the mechanism was almost plug and play, only needed to change the connector for the spin motor. Technics SL-PJ28A -> Marantz CD-40.
    Note: SL-PJ28A is more different with identical looking SL-PJ28 than the Marantz...
  • Xenon-Codex
    • 185
    • Finland
    Re: Philips CDM4-mechanism
    Is there any adjustment, sometimes it skips a bit when "cold" while playing CD-R's. No skips when it has been on for a couple of minutes.
      • 31002
      that will be a capacitor,
      they have better performance when warm
      • Xenon-Codex
        • 185
        • Finland
        Where's that cap? I got the player as it would not play to the end, and made some clonking sounds. I can still hear those occasionally.
        • UNITRAX
          • Jan 2023
          • 64
          • POLAND
          https://www.diyaudio.com/community/t...sports.372412/
          Page one, post three
          • Xenon-Codex
            • 185
            • Finland
            Changed the cap to 22u (which the old one was), but first it went only worse. The original cap had 6% Vloss. Then I changed to 47u which was in the service manual, it seem to work better.
            • Xenon-Codex
              • 185
              • Finland
              It was the clamp. I managed to move the fault to another identical Technics, only by moving the clamp. It had a dip in the middle of the small plastic thing which should be smooth.
              • G33RT
                Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                by G33RT
                Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                It does power up when pressing the power button.
                I already try the power button while plugin the plug with no result.
                Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                Could this be an PSU or eMMC issue ?
                07-19-2025, 03:43 AM
              • acedogblast
                [Marantz SR5012] Center channel keeps going into ASO/Overcurrent protection.
                by acedogblast
                First off I would like to thank this community as it has provided me with great information that has helped me greatly on my repair for this Marantz SR5012 AV receiver. I am creating this new thread as the other 2 that I have created here has had their original question/problem solved and I plan that this is the final thread on my repair. Please note that this is my first time repairing audio amplifiers so I may not be aware of common issues and things to know.
                Lets start at what I have done so far. Random speaker popping on all channels is fixed by replacing the 2 large filter...
                03-01-2023, 08:24 PM
              • aidanmo
                Philips 43PUS7506/12 - Loud blown out sound
                by aidanmo
                I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                I thought maybe the speakers got damaged, so I replaced them - no dice.
                • Using the internal speakers, it always happens.
                • Using the headphone jack, it never happens.
                • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                02-28-2025, 03:13 PM
              • Mark R
                Marantz Model 150 Tuner "NULL" Adjustment..
                by Mark R
                I am not ashamed to say this is my first FM alignment I have ever done. I am well versed in electronics and repair. Been doing it for many years on Pro Audio Live sound equipment. Worked on Power amps EQ's musical gear and Large format Mixing Live consoles Etc. But now I can see this is a whole different world when it comes to tweaking this kind of gear. I do have the proper gear like the SENCORE SG 80 and HP Generators and Scopes Etc.
                Look below at Adjustment 12:8. The Null adjustment. I have a Heathkit IM-28 VTVM that was rebuilt and has new Burned in tubes that I used for this...
                12-30-2024, 03:18 PM
              • BigOof
                Marantz SR5007 popping on volume change and mute in Direct Mode
                by BigOof
                I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
                12-12-2024, 06:15 AM
